04-28-2010, 08:25 AM
Synthetic oil?
Any one have any opinions on using synthetic oil? My 95 3.0 uses a little oil and i was wondering if it would make a difference.
04-28-2010, 08:53 AM
Nope, It will still burn oil....
08 4X4 SR5, Bilstein 5100's set at 2-1/2", Toytec 1.5" rear spacer & 3/4" Frt spacer, All-pro wheel adapters, Rack with custom light bar, Frt windows tinted, stock wheels, 265/75-16 Mickey Thompson Baja stz's
04-28-2010, 01:27 PM
a comment....
I use Castrol Syntec 10W-40 which seems to work exceedingly well in the old 3.0. For me, synthetic is a better route due to the fact that these engines run on the hot side Having just pulled the valve covers to replace the gaskets, I got a view inside the engine and it was spotless. The Castrol does a good job of keeping debris in suspension, engine does not use/consume any, and no leaks.
Its nice having it in there, so when I run a little over(mile wise, 5k) it is not a concern(gets annual changes). We've been running synthetic in the 4runner since we got it at 50k with no issues at all.
regards
04-28-2010, 01:57 PM
GTX High Mileage
I got my 3.0 a few months back. I was burning oil from the valve covers. Asked the seller what kind of oil he was running. He wasn't too sure. I replaced the oil over a week ago. I went with the High Mileage GTX 10W-40 which I ran in an old 88 RE motor and was happy with it. Since changing it, the I don't smell oil burning any more. Don't see how this is possible, but so far so good.
67 Chevelle 396 5spd - middle of ground up resto
87 Pickup 22RE Turbo 5spd 70K orig - stock
88 Pickup 22RE 5spd 180K - restoration stock
88 4Runner 3VZE 5spd 90K orig - daily driver stock
99 Tacoma 5VZE 5spd 135K - recently deceased from frame rot
04-29-2010, 09:44 AM
thanks for the info. theres alot of advice and info for the 4th and 5th gens, but not much on how using synthetic in the 2gen 3.0.
05-02-2010, 08:30 PM
Hmm, maybe ill try 10W-40 8)
94' 3vze 5spd, lots of miles
05-02-2010, 09:05 PM
Synthetic is more consistent and doesn't break down over time like conventional, and is in many ways better...
...however...
...Synthetic oil is a bit thinner than conventional, and will usually cause an older engine to leak a bit if you switch to it later on. I went to a synthetic blend at 80k in my '02 Jetta I had, and it started leaking.
I'm at around 220k in my 22RE, and I have no intention to switch from conventional 5W30.
1986 4Runner Deluxe, 5SPD, R.I.P. @ 182k Miles, July, 2001 - November, 2004.
1987 4Runner SR5, 5SPD, 236k. July 2007-Present
05-03-2010, 02:52 PM
...however...
Yeah I think when they did the Head Gasket they switched to Synthetic. There are more drips under the car (leaky rear main seal) than before I did the head gasket, but I still havnt had to top it up so Im not worried.
Oil change is due anyway, so ill ask them to stick with conventional.
Could also be the reason the oil pressure is lower than before the HG was done
01-21-2011, 09:51 PM
I've been running 10w-30 mobil1 synth. for about thre months now, and had the same issue--it's burned about half a quart since I changed it. It's not bad, just enough that I notice it every time I fill up the tank and check the oil. Any opinions about 10W-30?
01-22-2011, 03:46 PM
You might consider going to 10w-40, the 10w-30 is a bit light for these engines. It is also worth checking your crankcase ventilation system for coking or clogging/sludge. If it is failing in any way, you might develop higher then normal, or factory spec pressures allowing the engine to use oil(when it normally would not), or leak out of seals/gaskets.
I tried a number of different oils(standard and syn.) at differing weights, and Castrol's Syntec 10w-40 seemed to work best overall in the 3VZE(aka 3.0 slow).
regards
12-09-2020, 10:53 AM
I switched to synthetic with 150,000 miles on my 2005 runners and switched back to conventional.
Synthetic dripped oil all over the garage floor - until I changed back to conventional (1 drip a week),
Overrated.
Good for new cars - maybe.
kilmer on synthetic - Bing video
12-09-2020, 08:18 PM
Overrated.
Don't listen to anything this DB says. A quick search here will show you he's a nut job. Been running synthetic since day one, on both rigs, and never a drop of oil anywhere or loss of oil between changes.
*2017 4R TRD Pro, 01H5 Cement w/ Shrockworks dimpled tread plate sliders, Moroso oil catch-can, black powder-coated roof rails. (summer runner).
*2005 4R Sport Edition w/ Bilstein 5100's, Gen-5 brake upgrade, K&N cold air intake, cabin air intake mod, Falken Wildpeak AT3. (winter runner).
*1965 Pontiac GTO convertible, 4-speed w/tri-power, PHS documented. (born in Freemont CA).
*1962 Chevrolet C-10 (short-step) pickup, 4-speed, survivor. (born in Oakland CA).
12-09-2020, 09:14 PM
Real Name: Howard J. Turkstra
+1 on the synthetic oil. My 4th gen hasn’t used or leaked a drop of oil in 114k miles of driving. Synthetic might not be appropriate in a 1st or 2nd gen, but it should be fine in 3rd gens and newer.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
12-09-2020, 09:33 PM
FWIW, I switched to Mobil 1 in my 1988 4Runner at about 100k miles (bought it new, drove it a little past 300k). I've owned a bunch of Toyotas since then, all pre-owned vehicles until my current 2019. Used nothing but Mobil 1 synthetic in all of them. Never have experienced a problem in a million+ miles. I have a gravel driveway, so any occasional drips I wouldn't have noticed. But a search reveals that there are about 18,900 drops in a quart of oil (anyone out there have OCD?). I simply check the level now and then, keep it topped off like you would do for any vehicle, and do the required changes. No oil-related problems ever, aside from the engine design flaw in my 2002 Prizm. Honestly, oil may be the most over-thought concern there is regarding engines.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
