Originally Posted by Jabo
guess thats what im going to have to do.Was told it had to be at lease a 4"lift inorder to run the 98 model 4.3 due to the oil pan.What lift would give the best ride this thing is going to be used on and offroad.
Any of the bracket lifts will give you the same amount of lift. They are all the same with a few differences between them. Superlift and I think Pro Comp give you the rear brackets to raise your upper control arms and lower the lower control arms. The fronts are the same in every kit though.
James
