02-13-2017, 11:23 AM
#16
Moderator
Real Name: The Chosen One
Moderator
265/70/17 translates to 31.5" x 10", which should fit height and width wise. But, it's hard to say if the 17" rim will work in place of the normal 15".
'89 4Runner SR5 - stock
02-13-2017, 12:57 PM
#17
Real Name: Ron
Real Name: Ron
The question is, why do you want to go from a 15" rim to a 17" rim? If this is a street queen and you like the look of a larger rim better, then fine. However, if it's for trail use, stay with the smaller rim. More rubber and less metal on the wheels is absolutely better for off-road performance, especially handling rocks. (Look at the rim to tire ratio on your local earthmover for a good example of what serious off-road tires vs. rims should look like.)
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
02-14-2017, 06:19 AM
#18
Agreed. Not to mention much cheaper for 15" tires.
Sent from my Moto G Play using Tapatalk
02-14-2017, 10:06 AM
#19
Originally Posted by _ExpeditionMan
I have a set of 33x10.50 BFG AT2 tires on stock wheels and suspension on mine. No rubbing at all, but I think this also has to do with how much your suspension is sagging. As far as I know my torsion bars are not cranked. That being said I have yet to compress the suspension enough to see if it tucks properly.
I think the tire & wheel setup you have is perfect on your rig. jmho
2017 Silver SR5 Premium
Vietnam 67-68
Greed and corruption are rampant.
02-14-2017, 04:49 PM
#20
Real Name: Jonathan
Real Name: Jonathan
Honestly the stock wheels are pretty badass on their own. Toyota even used specific lug nuts on a lot of their vehicles to ensure the wheels wouldn't sit uneven
02-16-2017, 02:46 PM
#21
98 Limited, DD with Sway Away coilovers, Camburg uniball uppers, OME 891's w/ Bilstein 5100's in back, 285 BFG, KO2, Factory elocker. custom sliders
97 LX450 is the fun toy
02-16-2017, 03:28 PM
#22
how big of a tire can i fit on my 2nd gen?
I've ran BFG 32X11.50 KM2's (mud terrains) for years now. Stock height. Only had to trim the from valance like 1/2-1".
04-19-2017, 09:43 PM
#23
Real Name: PAUL
Real Name: PAUL
1995 33 10.5 15 dick cepek tires all stock suspension
04-20-2017, 12:56 PM
#24
35's on stock suspension.
Who needs up travel?
1994 4Runner AKA: Project Recycle
@503dropzone on IG
06-05-2018, 11:34 PM
#25
good to know on this. i have a 92 4runner and putting 33x10.50 swampers on it. knowing it will fit with out lift and little mods make me feel better.
06-07-2018, 01:18 PM
#26
Originally Posted by Madogmis
Hello, sorry to bring this up but will 265 70 17 tires and rims fit my stock 91 runner?
I had this size on a 91 pickup with grabber at2s and fj steelies, worked well, rubbed the mudflap but never enough to bother me.
As for the 33x10.5 OP, I ran that size on BJ spacers, stock rims and the torsion fully dropped then just a touch put back on it. No mudflaps and never rubbed the body or stock bumper (just the inner fender plastic on the cab side that took very minor trimming) However, I did notice some rub marks on the inner tires from running lower PSI where contact was made at some point with the upper A-arm. Solved with 1/4" slip over wheel spacers.
05-20-2020, 08:40 PM
#27
Did you regear to match the 33s? I have almost the exact same runner as you (blue decals) and am also looking into 33" KO2s on the stock SR5 wheels.
05-20-2020, 09:02 PM
#28
Real Name: Ron
Real Name: Ron
I've had those exact tires on my '94 for about the past 6 years, and they work fine. Stock suspension, no rubbing. I didn't regear, and haven't noticed all that much difference in performance. It was anemic before, still is :-)
05-22-2020, 10:36 AM
#29
I have 33x10.5s on stock rims. 4:56 gears and a 5 speed. I have never felt like I needed to re-gear.
1993 T4R 5 SPEED
05-22-2020, 10:53 AM
#30
Since the 3.0s are so anemic I wanted a light weight tire. My current Dick Cepeks are 2 lbs lighter than a K02 and 7 lbs lighter that a KM3(according to tire rack). I know it doesn’t seem like a lot but I really think it makes a difference.
1993 T4R 5 SPEED
