Old 02-25-2016, 03:01 PM #16
papichyno's Avatar
papichyno papichyno is offline
papichyno is on a distinguished road
papichyno's Avatar
Originally Posted by flyinhawaiian01 View Post
Does it sound like its gurgling when you hit the throttle? Have you done a radiator service since this issue started?
No gurgling sound and haven't done a radiator service but will do. Thanks.
I don't know what the f&ck I'm doing: amen:
papichyno is offline   Reply With QuoteReply With Quote
Old 02-25-2016, 03:03 PM #17
papichyno's Avatar
papichyno's Avatar
Originally Posted by nevada View Post
likely low coolant, as said above.
though, I HAVE seen a case where the fins on the water pump impeller actually disintegrated, and had the same symptoms. higher rpms would push the water, and give some heat, but not at an idle.
Thanks guys. I'll give you an update
Old 11-08-2017, 04:29 AM #18
COAKScottishrunner COAKScottishrunner is offline
COAKScottishrunner is on a distinguished road
Questions as well,
So I am having the same issue, and I've run through a few checks. Originally had the running water sound in the engine, and I've been keeping the fluid levels up, then had a working heater for like a week. Now it's back to the lukewarm from the front ones. The thermostat seems to work as it shows the correct engine temp, the tubes running to the heater valve are nice and hot, the valve opens and closes, and the back floor heater works quite well. That's as far as I've gotten, query as what to do next, seeing if people have had solutions.
COAKScottishrunner is offline   Reply With QuoteReply With Quote
Old 11-08-2017, 12:32 PM #19
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
maybe the blend door. lay under the dash and cycle the hot/cold controls. watch what moves, and doesn't move. it sounds like a control cable has popped off. I cant remember which side the blend door is on, there are controls on each side, so check them both.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 11-08-2017, 11:00 PM #20
djaye.'s Avatar
djaye. djaye. is offline
djaye. is on a distinguished road
djaye.'s Avatar
I'm banking on a clogged core... for some reason I see so many issues with them in these trucks.
I made a super simple tool for about $5 at Home Depot and it works awesome. 10' roll of 5/8" clear vinyl tubing and one brass garden hose thread x hose barb fitting. Cut the hose into a 2' long pressure line and use the remaining 8' as a discharge so you don't get hosed. Hook up to heater core and let run full blast for a few minutes, then reverse the hoses and do it again.
You'd be surprised how much trash usually comes out...
djaye. is offline   Reply With QuoteReply With Quote
Old 11-10-2017, 01:45 AM #21
Getting to it and the help
Thank you guys for the help,
I did take a look under the dash and everything seems to be moving alright. The two oddities I want to mention first are I did have heat for like two weeks or a week before it went back to lukewarm, also, the rear back seat floor heaters work well. But I am thinking it is the core cloged with gunk after looking through the thred. How do I get to said heater core though?
Old 11-13-2017, 01:37 AM #22
djaye.'s Avatar
djaye.'s Avatar
You can access both heater core connections for flushing right in the engine bay at the firewall. As far as changing said heater core, well that's another story...
Old 01-03-2022, 10:09 PM #23
MattFromPA's Avatar
MattFromPA MattFromPA is offline
MattFromPA is on a distinguished road
MattFromPA's Avatar
Hey guys, new to the forum, I'm having nearly this exact issue with my 2003 4runner SR5.
Just bought it and only noticed the issue this morning.
Air is warm when accelerating but cools down very quickly as the engine winds down. Almost cold coming out when I'm sitting at a light.
I've read so many posts that say so many things(heating core flush, water pump, low coolant, aftermarket stereo), I just don't know where to start.
I've got coolant full in the reservoir, first thing I checked.
In one post I read something about the radiator hoses being different temps.
My in and out tubes in the radiator are not the same temp. One hot one not.
I am not a car genius, any help would be appreciated.
2003 4Runner SR5
MattFromPA is offline   Reply With QuoteReply With Quote
Old 01-04-2022, 02:46 AM #24
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
You can get a bottle of coolant flush at your local parts store or online, very easy to use, just follow directions on it. It's important to use distilled water to prevent deposits, and the right Toyota coolant to prevent corrosion. At dealer or online, aftermarket brands make some that are supposedly compatible but boy worth the few bucks saved imo. If someone removed the thermostat that would also keep car running cooler but shouldn't affect it as quickly as to be noticeable at a stop light so clogged core would be my first guess also. And easiest to fix
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 12:49 AM #25
MattFromPA's Avatar
MattFromPA's Avatar
Unhappy
Just had the heater core flushed today and the guy said stuff came out and he declared it fixed.
After driving for a few minutes to warm it up it was pretty clear the problem hasn't been fixed. It's still inconsistent.
Sometimes warm, sometimes not. High fan speed and foot well seems to not work at all. More warm sure while foot is on the gas.
Is this thermostat, radiator, water pump, or something else?
2003 4Runner SR5
Old 01-11-2022, 02:08 AM #26
YotaKid87's Avatar
YotaKid87 YotaKid87 is offline
YotaKid87 is on a distinguished road
YotaKid87's Avatar
just had this issue, first we found the thermostat was stuck open. got better but still not hot. then found core was plugged. you could also have a heater box door issue
YotaKid87 is offline   Reply With QuoteReply With Quote
rear heater not working peadar Problems & Warranty Issues 1 11-11-2020 01:44 AM
Heater not working! mrRev 3rd gen T4Rs 20 02-02-2018 08:17 PM
Rear Heater? MT4runner Classic T4Rs 8 02-19-2008 11:38 PM
Help! Heater not working! zebra747 Classic T4Rs 4 12-17-2007 11:01 PM
Advice: Things that can go wrong in Winter, and why... Thai Maintenance/Detailing 2 10-28-2004 01:15 AM
