12-02-2010, 07:01 PM
Isr mod
I want to do the mod for my 3.0 but i have no clue where to start.
Will someone post some pictures of the process? thanks
12-02-2010, 07:25 PM
Moderator
Real Name: The Chosen One
Moderator
If you use the Search function in this and the 3rd gen forums you'll find plenty of info.
'89 4Runner SR5 - stock
12-03-2010, 12:06 AM
What is the mod
What is this mod your refering to?
12-03-2010, 02:21 PM
Yeah i dont have a computer at home, but the school computers dont let me go on yotatech :'(
so the mod is pretty much putting a cold air intake in place of the stock intake?
12-03-2010, 02:41 PM
Real Name: Robert
Real Name: Robert
Essentially yes, but at a much cheaper price. It should cost you at most $50 compared to a CAI which are close to $200. It allows the air to flow free from the filter to the engine. Some people have put an aftermarket air filter on the end, but I just used my stock air box.
My 4runner Build Thread 2000 Limited 4runner SOLD
My Tundra Build Thread 2006 Double Cab Tundra SOLD
My Humpty Dumpty 4runner Build Thread 1999 Highlander 4runner
12-03-2010, 06:34 PM
This is mine...
I bought a kit of e-Bay for $60, modified it a little..
The center section with the 2 nipples should be blocked off (I plan on putting a new tube in place without the nipples), the kit has them routed to the breather tubes on top of the timing belt cover, basically a huge vac leak! I also opted to not use the Cone Filter...
I used my stock air box with a K&N factory replacement filter, its also a lot quieter vs. the cone!!!... Works very well!
Dave MacLaurin
- 1971 Datsun 240Z (Series 1, EFI, 5mt)
- 1988 Toyota Celica Turbo 4WD (100% stock)
- 1989 Toyota Celica GT-S (Summer Driver)
- 1999 Toyota 4Runner SR5 V6 (Daily Driver)
12-03-2010, 09:08 PM
okay thanks you guys. helps alot.
12-04-2010, 12:43 PM
so is this mod Ca smoggable? cause I did it this year and smog comes back up next so I hope I dont have to go "find a guy" to smog it for me
12-04-2010, 09:42 PM
Doesn't affect me on our "E-Test"
Dave MacLaurin
12-05-2010, 12:10 PM
Originally Posted by SCRunner12
There are many ways to do it, but here is a good write up. Intake Silencer Removal Mod - 2nd Gen 4Runner - YotaTech Forums
Also check out this thread for some tips. Post your ISR Mod Pics! - Page 2 - YotaTech Forums
I did mine and it is simple you just have to find the right parts. Feel free to ask any questions.
bigbsvo: it is a mod to remove the intake silencer and replace it with a bent pipe. It ends up producing a louder exhaust and helps out with power in the 3k-5k range. Some say it helps gas mileage, but I haven't seen that. It is worth doing for how cheap it is.
After reading the writeup on this mod, from the yotatech, I'd recommend using a tap instead of messing with the o-ring/washer combo. Just put some pipe thread tape on the brass fittings and don't over tighten. I used this same method to mount my nozzle for my water meth on my scion. It sprays at a minimum of 150psi and has held and doesn't leak. Just thought I'd put in my .02
Thought about it and maybe having the muffler guy who bends the pipe weld in a couple fittings on the pipe to have a permanent seal.
I'm thinking I'm going to have to go stainless.
93 4runner SR5- new project
06 Scion tC-turbo
02 Triumph Speed Triple 955i
76 Yamaha xs500-cafe project
He who dies with the most toys, wins!
12-05-2010, 01:29 PM
So, is there a noticable gain to be had?
12-05-2010, 03:17 PM
Real Name: Robert
Real Name: Robert
I have noticed a gain around 3k-5k. It isn't anything real special, but definitely holds my speed at some inclines easier when on the freeway. Also acceleration is better at those rpm's. Plus it creates a nice sound and is worth it for the money.
12-05-2010, 05:53 PM
Agreed, for the cost its worth it!
Dave MacLaurin
12-06-2010, 07:05 PM
Ha, i barely run my v6 over 3k as it is. But I am thinking of doing this one day as I hate dropping to 3rd going up some of the mountains around here.
94' 3vze 5spd, lots of miles
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
