Originally Posted by 1stgenfan
check to make sure your battery connections are bolted on tight and connections to starter solenoid are good. it sounds like a weak battery or bad connection at the batt since you can hear popping but not turning
Thanks, the battery connections are fine. The voltage on the battery was 12.72 this morning after sitting for ~20 hours. Is the solenoid right there on the passenger's side on the firewall? If so, then all of the connections looked good. It's snowing right now so I'll wait and check the connections on the starter itself sometime later.
Thanks for the suggestions.
