12-22-2010, 04:31 PM
No light in dashboard.. 90' T4r V6
Hi, The light in my dashboard stoped working the other day .. but everything else works, what can this be??
44" 1991 Toyota 4Runner Truck , solid front axle and four link , Rear axle moved 10" back ,5.71 Gears + Arb locker rear ,ESAB front , Di ck Cepek Kevlar FC 44" tyres on 15 x 18" wide Wheels , Artic trucks fender flares , 4" lift , cut fenders , K&N Intake,Full 3" Exhaust with Headers,Offroad Skidplate ,
12-22-2010, 07:22 PM
Moderator
Real Name: The Chosen One
Moderator
Which light ??
'89 4Runner SR5 - stock
12-22-2010, 08:11 PM
Id say dirty dimmer switch...
Dave MacLaurin
- 1971 Datsun 240Z (Series 1, EFI, 5mt)
- 1988 Toyota Celica Turbo 4WD (100% stock)
- 1989 Toyota Celica GT-S (Summer Driver)
- 1999 Toyota 4Runner SR5 V6 (Daily Driver)
12-22-2010, 11:58 PM
Originally Posted by fourwd1
Which light ??
Where the speedometer and rpm tachometer are , The light in the thermal center is still there
12-23-2010, 12:38 AM
Moderator
Moderator
If it were the dimmer switch all the lights would be affected.
If just one light is out, well, bulbs don't last forever, they burn out.
12-23-2010, 12:49 AM
strange that all the bulbs in the dashboard go at the same time
12-23-2010, 01:03 AM
Those are all powered by a printed circuit board and I believe they are wired in sequence. As your rig vibrates it can wear through the contacts on the circuit board. if that happened on light bulb #1 you would lose 2,3,4,5, ect.
At least thats what happened to mine. Its pretty easy to test that board with a multi meter.
12-23-2010, 10:51 AM
Moderator
Moderator
All the illumination bulbs are wired in parallel, that way if one goes out, the others remain lit.
You said bulb, not bulbs in your original post.
Either way you will have to take out the instrument cluster to troubleshoot and repair the problem, whether it's bad bulb(s) or bad wiring.
12-23-2010, 11:12 AM
I can only speak from my own experience. I fixed the "wiggled through" spot on the printed board and instrument lights started working again.
