i disconnected the unlock VSV (the red one receives voltage while the transfer case is in 2H) and I connected the actuator directly to the manifold, but it still makes this noise/vibration. I know that it usually happens when trying to go into 4WD, but my 4WD engages just fine (4H and 4L) it only happens when I am drivng from 25-55mph in 2H ONLY, but once it starts doing it, it will make the noise all the way down to 5mph and will not make it again till I speed up to 25mph.
I have one more idea up my sleeve, I completely forgot to loop the vacuum canister into the system while trying to lock it into 2H, so I will try that and see how it works.
I am at my wits end here with this because how can something that slides a collar on a shaft make so much damn noise?!?
