Originally Posted by nathanmr1977
Gonna check the bulbs. How can I check the dimmer switch?
On the back of the dimmer control behind the dash there will be two wires. One is power going in and the other is power going out.
Easiest way is with a test light. Make sure the lights are on and you have power going into the dimmer. Then check on the output side and move the dimmer up and down and your test light should dim and brighten.
