Originally Posted by 4running1990
if its auto place a tranny mount under the transmission then unbolt the tranny and the crossmember and roll the transmission back a few inches then remove the 6 bolts that connect the fly wheel to the torque converter and disconnect all wires from transmission. this will free the transmission from the engine
OK, do you think there is enough play in the front and rear driveshafts to move the tranny/transfer case a couple of inches?, or do you think I have to drop the shafts as well.
