Old 02-05-2011, 10:09 AM #1
s2kpuddydad's Avatar
s2kpuddydad s2kpuddydad is offline
s2kpuddydad is on a distinguished road
Mercedes Benz 300 Turbo Diesel conversion
What do you guys think about doing the OM617 swap? 5 cyl. 125Hp 181Tq with turbo
Should see 28 to 35 MPG and from what I understand these engines are as rock solid as can be.
I'm not sure all that will have to be done to do the swap but I bet it would be fun and not to crazy challenging......I hope
I am the PuddyDad, Creator of things for the S2000, Part provider to 4 Maltese dogs we lovingly refer to as Puddys. Puddy is a mix of two words, puppy and buddy. Small dogs like Maltese are little like a puppy and all dogs are your best buddy. Put the two together and you have a Puddy.
Rest in peace Cosmo The Wonder Puddy, we love and miss you very much
http://www.s2ki.com/forums/index.php...owtopic=825385
s2kpuddydad is offline   Reply With QuoteReply With Quote
Old 02-05-2011, 12:26 PM #2
turboSR5's Avatar
turboSR5 turboSR5 is offline
Real Name: Todd
turboSR5 is on a distinguished road
turboSR5's Avatar
Real Name: Todd
I always thought the TDI swap would be cool, this would be at a slightly higher level though.
1986 4runner 22RTE Turbo SR5 - R.I.P.
1986 Extra-Cab Pickup DLX - Sold
1987 4runner 22re SR5
1984 2wd Exrta Cab
1982 BJ60
turboSR5 is offline   Reply With QuoteReply With Quote
Old 02-05-2011, 02:44 PM #3
The conversion has been done a few times into Toyota and from what I understand it's not the hard to do.
I just bought a 1982 Benz 300 Turbo Diesel car with 162K on the clock, the car runs great!!
Old 02-05-2011, 05:47 PM #4
here is my new Benz
Mercedes Benz 300 Turbo Diesel conversion-benz-82-1-jpg  Mercedes Benz 300 Turbo Diesel conversion-benz-82-2-jpg  Mercedes Benz 300 Turbo Diesel conversion-benz-82-3-jpg  Mercedes Benz 300 Turbo Diesel conversion-benz-82-4-jpg  Mercedes Benz 300 Turbo Diesel conversion-benz-82-6-jpg
Old 02-05-2011, 07:00 PM #5
cometobanks's Avatar
cometobanks cometobanks is offline
cometobanks is on a distinguished road
Just put the 4X4 stuff under the Benz!
cometobanks is offline   Reply With QuoteReply With Quote
Old 02-05-2011, 10:20 PM #6
elcidsurfer's Avatar
elcidsurfer elcidsurfer is offline
elcidsurfer is on a distinguished road
Ive seen alot of write ups on ppl doing the benz swap into Jeep YJs and TJs but not Yotas... I do know that those things run for ever though, good luck.
elcidsurfer is offline   Reply With QuoteReply With Quote
Old 02-06-2011, 12:02 AM #7
I am still on the fence....I want the added power and the better fuel mileage but I also don’t want to take away from the value and originality of my rig.
If I do the swap it will be the engine only I will keep everything else Toyota in my 4Runner. I will be sure to do the conversion justice by making it look bone stock, like the truck came with a Mercedes diesel engine from the factory. I may have to use the Benz power steering pump and A/C compressor not sure if I will need anything else. I may also improve the turbo efficiency by adding an intercooler.
Old 02-08-2011, 10:35 AM #8
Hey guys here is the engine shots
I think I'm going to fix up the Benz as a driver then tag it for a month or two. I want to drive the car with diesel power to see how I like the performance and drivability. I should get a good idea of the fuel economy as well since the car weight and 4Runner weight is near the same.
Mercedes Benz 300 Turbo Diesel conversion-benz-82-5-jpg  Mercedes Benz 300 Turbo Diesel conversion-benz-82-7-jpg
Old 02-08-2011, 12:12 PM #9
Wow, if the exhaust and intake were swapped it would be configured just like a 22r huh?
Old 02-08-2011, 12:54 PM #10
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
any thought to what transmission your going to use to adapt a merc motor to you toyota driveline?
that would be the big what if for me
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 02-08-2011, 02:06 PM #11
I'm going to keep the 5speed trans that is in the truck and use an adaptor plate to mate the Benz engine.
The exhaust is also not that hard to run even though it is not on the same side as the 22re.
Old 02-08-2011, 04:43 PM #12
Bad_Vision's Avatar
Bad_Vision's Avatar
have you found a place that makes the bell housing plate?
If not that can be a costly little item.
Old 02-08-2011, 04:47 PM #13
turboSR5's Avatar
Real Name: Todd
turboSR5's Avatar
Real Name: Todd
Yeah, those are usually really pricey. I saw a guy on youtube making a trans adapter plate out of 1/2" to 3/4" aluminum for an electric motor (electric car) with a cardboard template and a jigsaw!
1984 2wd Exrta Cab
1982 BJ60
Old 02-08-2011, 05:25 PM #14
We are a machine shop so the plate and pilot bushing is a none issue. The coolant system maybe a bit hard because of the added langth of the Benz engine.
Old 02-09-2011, 02:02 AM #15
zombie's Avatar
zombie zombie is offline
zombie is on a distinguished road
zombie's Avatar
I had a friend up here in Toronto do the conversion into his '89 4Runner. Here is link to his build.
Turbo Diesel 4Runner
'87 4Runner, 22re
zombie is offline   Reply With QuoteReply With Quote
Diesel conversion 1985taylor1925 3rd gen T4Rs 4 09-13-2010 11:26 AM
1985 t4r diesel conversion zeb Classic T4Rs 2 07-28-2008 10:29 AM
Mercedes and Quality Issues--Interesting Article Thai Off Topic 24 02-16-2005 12:00 PM
Another Glitch at Mercedes Thai Off Topic 2 05-30-2004 01:04 AM
New Mercedes: Quality failing? Thai Off Topic 5 09-23-2003 12:20 AM
