Originally Posted by fourwd1
No, that is not correct.
The ignitor is mounted on the outside of the coil.
It is not inside the distributor.
It appears to be that the ignitor may either be inside the coil or is any of the other components close to it such as a small black square box aprox. 1/2" or less attached to the coil bracket bolted to the wheel well w/ 1 gray lead to ground and the other to a red wire. The other component I believe is the ignition coil module which is attached within the same coil bracket back to back.
Yesterday out of curiosity, I pulled the distributor cap just to inspect it and the noticed that the center spring loaded retractable pin which contacts the rotor was broken like it had been bent.
I replaced it, reset the memory, drove it for a few hours, the CEL hasn't come on any further so far and niether codes 14nor 25 have displayed; however, it continues to tremble some while in gear w/ brakes applied at stop.
The RPM is as follows:
Cold:
P or N = 1100
R or D= 900
Warm:
P or N= 900
R or D= 650
