Just purchased 95 3.0L with 2WD It has a A340E transmission and 217,000 miles on it. I have a question on the transmission solenoids......if one is acting up will it make the transmission slip?
I noticed today that when starting out in Drive it reved higher than normal and very little forward motion. Once I got going I had very little if any passing power. I took it out on the highway and started playing with the ECT and the OD buttons and began testing the limits of the floor board strength.
All of a sudden it began to red line and no more forward motion was noted, I was only doing 50 mph. Then as quick as it started it began acting normal with passing gear downshifts, OD rpm drops and increases with the button action. ECT shifts were different with the ON-OFF of the button also.
I did notice the PO had a bit too much transmission fluid in it and I am going to pull the pan and change the filter after the valve cover gaskets are replaced.
What I want to know is...are the three solenoids replaceable as soon as the filter is dropped out of the way or is there more to it than that? Would it be worth the $138 to replace them as a set? Or do they have any effect on what I described at all? Thanks.
