Old 02-05-2005, 12:11 PM #1
r1burden's Avatar
r1burden r1burden is offline
r1burden is an unknown quantity at this point
r1burden's Avatar
Front Brake caliper sticking?
I just replaced the front brakes and right side rotor on my 95 4runner, after only 12 thousand miles, the right side pad was completly gone. Has anyone had a caliper stick. or could it be something else? How much to have a caliper rebuilt. or is cheaper to but a new one?
thanks
r.1. burden
r1burden is offline   Reply With QuoteReply With Quote
Old 02-05-2005, 12:18 PM #2
r1burden's Avatar
r1burden's Avatar
another brake question
I was looking on advanceautoparts.com
what is the diffrence between a loaded caliper and an unloaded caliper
Cardone 171601
Reman.; Front; Left; Loaded; OE Metal Piston
Lifetime Limited Warranty 66.00 with a $50.00 core
Cardone 191601
Reman.; Front; Left; Unloaded; OE Metal Piston
51.88 with a $50.00 coreurdem
thanks
r.1. burden
Old 02-05-2005, 02:20 PM #3
nogard nogard is offline
nogard is an unknown quantity at this point
Lightbulb TRY THIS!
I've had this problem before. Not on a 4Runner, but at least on a toyota. Your calipers are most likely fine. And I think if you would get a "loaded" set it wouldn't fit your problem anyway.
Here is what you need to do. Know I don't know the exact way the calipers are put together on a 4Runner. I just got mine and I haven't done any brake work. But usually the caliper is held on by two bolts. And the caliper floats on these. The bolts actually goes through a small tube called a slide or sleeve. And the caliper slides on the tube. There is a little boot on each side of the caliper, a pair at the top and bottom. If anything these might be riped. If they are replace them. When ever you do a brake job doen't just replace the pads. Take the caliper off too and check the slides. Pull them out, if they are really pitted replace them. At the very least take them to a wire wheel on a bench grinder to clean them up. And then lube them up, I know they make a special lube for this, I can't remember the name. But this is what make pads wear out, and brakes drag and squeek, it is usually not the pads. Hope this helps, or gets you going in the right direction.
nogard is offline   Reply With QuoteReply With Quote
Old 02-05-2005, 02:24 PM #4
Question Loaded or Unloaded?
The difference is brake pads. Loaded comes with pads, unloaded doesn't.
Old 02-05-2005, 08:39 PM #5
r1burden's Avatar
r1burden's Avatar
I did sand the pins down just to knock off some rust
and to make sure that they did slide through with no resistance,
maybe this will fix the problem.
thanks
brad g
Old 06-05-2005, 05:15 PM #6
2WICE 2WICE is offline
2WICE is an unknown quantity at this point
ever had a piston stick all the way out
anyone ever had a piston on a brake caliper stick all the way out when pushing the other in? i have 4 piston calipers on my 4runner, and when doing my pads today i opened the bleed to push the calipers open so i could fit the new pads on the roter. on one of the psitons when i pushed it in, the other piston, on the same side, stuck all the way out and now i cant get it to go back in. any help?
92 4R 172k a/t 3.0 v6
OME 901 +2" HD Coils -OME N98 (f) and N72F (r) Nitro Charged shocks -1.5" "custom" 2.5" magnaflow catback - BFG M/T 32" -mobil 1 oil -k&n air and oil filter -91 octane -
<-Soon->
2.25" mandrel muffler back - -custom 3" mandrel intake tube -radiater flush and service - ATF swap - custom roof rack -bull bar and undercarriage armor
->Some Day<-
2WICE is offline   Reply With QuoteReply With Quote
Brake Assist...what is it?? Thai 4th Gen T4Rs 3 02-01-2022 03:24 PM
My 4th Gen Front Brakes walkthrough Ducman Maintenance/Detailing 73 12-09-2021 07:58 AM
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
Can I return a brake caliper core for credit... jeober Problems & Warranty Issues 1 06-11-2009 12:14 PM
Disc & Drum Brakes Thai Maintenance/Detailing 0 11-20-2002 04:32 PM
