Old 03-05-2011, 03:10 AM #1
ironmaidn23's Avatar
ironmaidn23 ironmaidn23 is offline
Location: Huntersville/charlotte/lincolnton good ol north carolina
ironmaidn23 is on a distinguished road
Exclamation Radiator leak, and oil leak maybe tranny? Not sure what should I do?
Hey guys I got a very clean 89 runner and it just had a engine rebuilt with all imprtant parts head gaskets polished and done, radiator and altinater and much more,done by professionals. and now I got the couple of things I personally was afraid of leaks. It could be a easy fix Idk haha maybe it's gaskets? Or tubing? Or I got a radiator Leak it's green fluid and what can I do or what needs to be checked or done to fix it? And I have a oil leak (I think) it's up front close to front axile, it could be tranny? What's your best guess or how could I tell what it is?. What should I get replaced to help a oil leak or tranny leak? Thanks yota bros and btw it's a 3.0 v6
ironmaidn23 is offline   Reply With QuoteReply With Quote
Old 03-05-2011, 03:23 AM #2
A.Wilson013's Avatar
A.Wilson013 A.Wilson013 is offline
Real Name: Alex
A.Wilson013 will become famous soon enough
Real Name: Alex
Honestly man, that description of your problem makes it very hard to help you out.
What engine do you have?
Take off your skid plate... Can you see where the leaks are coming from?
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
A.Wilson013 is offline   Reply With QuoteReply With Quote
Old 03-05-2011, 03:28 AM #3
Hey man sorry I don't know much about engines, it's a 3.0 v6 and I haven't tried that but for the problems I listed theres 2 leaks one I know is the radiator(green fluid) and one is ether the tranny or oil, I think, the best thing that would help me man is if you told me how I can fix all three Or what need to be replaced probably or what I could look at. thanks!
Old 03-05-2011, 03:37 AM #4
They are coming from the front of the vehicle dripping down the right side mostly to the middle, I see more wetness on right side of the engine from under the car and it's dripping off
Old 03-05-2011, 03:38 AM #5
Real Name: Alex
Real Name: Alex
If your radiator is leaking, GENERALLY there will be water droplets beading up along the lowest points of the radiator.
If the green is coming from somewhere else, well, there may be a problem. Check that all of your coolant hoses are secure, for starters. After that, you'll have to get a bit more in depth with mechanical parts i.e. your water pump.
As far as oil... In the 1st Gen 4Runners typically your oil leaks will run from where they originate, down to the oil pan, drip onto your differential, and then drip to the ground from there.
If I were you, I would try and wipe off my engine pretty well, and monitor it for a day or two to see if you can notice any oil appearing, where you previously cleaned up.
Is your runner an Auto or Manual?
Old 03-05-2011, 03:40 AM #6
Real Name: Alex
Real Name: Alex
I hate to ask... But is it a drop of oil with a little green drip inside of it? Or are they separate?
Old 03-05-2011, 03:42 AM #7
Talking
MY runner Is manual, and the green fluid if coming from the very front under the car
Old 03-05-2011, 03:44 AM #8
They are separate
Old 03-05-2011, 03:50 AM #9
Real Name: Alex
Real Name: Alex
That is a good sign. What I am about to tell you, I am sure I will get a lot of crap for, but, it has worked for me on more than one occasion.
Head to autozone and get a bottle of radiator stop leak. Read the instructions, and follow them. In a day or two, flush your coolant system. See if that solves it =)
Old 03-05-2011, 03:57 AM #10
Thanks I'll defiantly consider it man sounds good, I just hope it holds afterword, still gotta figure out the other leak
Old 03-05-2011, 03:59 AM #11
Real Name: Alex
Real Name: Alex
Honestly man, there are 1,000,000 things that could be leaking oil. ESPECIALLY with the 3.0. It is nearly impossible for me to help you out with that one, since I cannot physically be there to poke around. My best advice would be to do some cleaning of your engine, and just look for where the oil reappears.
Old 03-05-2011, 04:16 AM #12
Wh does everyone hate the 3.0?
Old 03-05-2011, 04:25 AM #13
markfagus's Avatar
markfagus markfagus is offline
markfagus is on a distinguished road
markfagus's Avatar
not a lot of power, head gasket issues, and the durability of the 22RE is legendary.
and I too have a 3.0 with an auto. I find that it has enough power to do what I need it to. Before I bought mine I test drove 2 that I did not buy that were 22RE motors and manual trans. I found both of them to be completely underpowered and it was even worse when I put the A/C on. Brought me back to the days when I had a Mercedes 190 with a 2.2 non turbo diesel and it didnt have enough power to get out of its own way
markfagus is offline   Reply With QuoteReply With Quote
Old 06-24-2013, 09:46 PM #14
T_Craun62 T_Craun62 is offline
T_Craun62 is on a distinguished road
I'm having the same problem with mine leaking oil to right out of the front near the axle I was told that it could be coming from the oil pan gasket. I don't know much about working on vehicles. I can change my oil, brakes and a few other small things maybe this will help
T_Craun62 is offline   Reply With QuoteReply With Quote
Old 06-25-2013, 10:34 AM #15
goatfarmer's Avatar
goatfarmer goatfarmer is offline
goatfarmer is on a distinguished road
goatfarmer's Avatar
I would pull the skid plate and attempt to locate source of coolant leak, not a fan of additives as a fix; particularly if source is unknown, my experience has been usually short term and eventually will have to deal with results when it comes to making the repair?? Secondly, need to determine if transmission, or engine leak and not sure if able to determine difference between the manual trans gear oil to that of the lower viscosity engine oil; perhaps more knowledgeable member can advise?
Dave
'The problem with engaging in useless activity is never knowing when you are done'
1990 T4r, SR5, Auto, 4X4
goatfarmer is offline   Reply With QuoteReply With Quote
leak 1989 4runner
Synthetic Engine Oil Thai Maintenance/Detailing 114 02-18-2023 01:39 PM
The trouble with oil additives Thai Maintenance/Detailing 4 07-18-2018 07:02 PM
4th Gen 4.0L $30 Oil Change and Filter Cross Refrence 074.0Runner Maintenance/Detailing 55 01-18-2017 12:20 PM
Pinpointing oil leak SDHNTR Classic T4Rs 7 11-23-2010 04:05 AM
Know which automatic transmission oil to use Thai Maintenance/Detailing 0 01-29-2004 08:54 AM
