03-27-2011, 02:23 PM
head gaskets again!
I replaced headgaskets back in '06 at 100000 miles. Now my '94 4runner has 141000 miles. I noticed that temp gauge takes a while to show a reading. A week later radiator was half empty. I know that I have about 2-3 weeks to go before oil and coolant will start mixing again.
So this is a third time it blew up. Dealer fixed it once at 60k, I did it in '06 and now again. Something is telling me that even if I do fix it now I'll be doing again after 40-50k miles. Please tell me I'm wrong!
Thanks
03-27-2011, 02:49 PM
I sure hope you are wrong! I am just about finished with replacing my HG and it is not something I want to do again....EVER!!!!!
04-01-2012, 11:13 PM
Update!
Found milkshake during last oil change. Pulled the heads and found HG blown again. Last set lasted 47k miles. I'm alomost done replacing them. Maybe, third time is a charm...
04-02-2012, 12:31 AM
Did I have the heads checked to see if they are flat? Maybe the block is no good...what did u do the last time u did the heads? Rebuild?
04-02-2012, 02:29 AM
Real Name: Cory
Real Name: Cory
Those are such a PITA. I would buy new heads, that's what I did in my 88 however I parted it out instead of fixing it.
1992 T4R SR5 22re SAR Rig, SAS, 63s, Duals, Twin Sticks, 5.29s, 36" Iroks, 14.5" LED Bar, TJM front Bumper, Marlin Crawler Rear Bumper, Detroit Locked, Trail Gear sliders, Cobra 29gtl CB, Yaesu FT-8800R VHF/UHF, Icom f521, Rola Roof Basket, LCE header w/ Flowmaster 44, LED Rock Lights, Smittybilt 9500k winch.
04-02-2012, 05:34 AM
I beg your pardon, that doesn't make sense. Did you part it out after you bought the new heads?
04-02-2012, 09:16 AM
Maybe you should invest in some headers this time around, 6cyliners. You'll pull the heat away from that back corner where the gasket usually fries, and you'll get a nice boost in power for the effort. That way you can consider the money spent as an investment, instead of merely an expensive repair.
Former owner of four Runners: three 2nd Gens and one 1st Gen. Idle for now, but will be back in one again before too long.
04-02-2012, 09:48 AM
Real Name: Nate
Real Name: Nate
I concur, headers are the way to go. That way you ditch the crossover pipe. Your heads will like the heat reduction that's for sure
04-02-2012, 11:39 AM
right on
I third that on headers it seems like most 3.0l head gaskets go out on driver side near cross over!!!!! I know thats where mine blew out as well. If you do redo the heads at least put a better heat shield around the cross over.
04-02-2012, 01:42 PM
Real Name: Cory
Real Name: Cory
I didn't feel like doing the same thing over again. That was the problem I had with that engine. The HG will blow again eventually even if you do fix it right. It wasn't worth it to me on a POS 4runner, I'd rather fix one that was a nice vehicle to begin with. I made more money parting it out than I had into the whole vehicle anyways.
04-02-2012, 11:17 PM
Last time I had the heads redone and check block with straight edge. Headgasket came from enginebuilder(sp?) Ted I believe. This time I was kinda pissed. So, I oredered a cheapest set from ebay with headbolts and slapped it back together. Hoping to get 2 more years out of it while looking for another core to rebuilt or ls 5.3 swap.
04-03-2012, 02:16 AM
Did u use new headbolts the first time?
04-03-2012, 03:06 AM
my 3.slo is at 318k and last time I had the HG replaced was more than 100k-150k miles ago... Check your block, the heads themselves, and if there's additional heat going to the HG's for possible leaks or anything of the sort.
'92 4runner 4x4
Rancho 9k's, Maxxis Mudds 32/10.5/15 3.56's | 2 10
Cobalts w/ an 800w amp, MA Audio speakers w/ 300w amp,
Soon to come - 3" lift, 35's on 4.88s, 350 swap.
