Old 03-31-2011, 04:33 PM #1
dwmac64's Avatar
dwmac64 dwmac64 is offline
dwmac64 is on a distinguished road
dwmac64's Avatar
brakes locked up- help
the other day I was coming off the freeway to a red light, there was a light rain, roads were a little wet. started to brake ( I was not going over 30 mph at this point ) as I started to slow down (doing about 10 mph ) the front wheels locked up and I slid a little sideways, released the brakes and reapplied, locked up again, it felt like the brakes got to a certain point then got hard. I managed to not slide into the intersection. but am concerned about braking on wet roads. luckily there were no cars in front of me. And no I did not slam on the brakes. I am an experienced driver from the old school of no ABS days, so I know how to maneuver on slippery surfaces, ( brake- turn into skid- release. ) any one have any suggestions.
I just got this rig about 2 weeks ago so I am still shutting off lights. at this point they are all off except rear ABS.
95 4runner 3vz-e auto 2WD
dwmac64 is offline   Reply With QuoteReply With Quote
Old 03-31-2011, 09:55 PM #2
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
fourwd1 has a spectacular aura about fourwd1 has a spectacular aura about
Moderator
fourwd1's Avatar
Have you checked/replaced the front and rear brakes? pads/rotors/drums/shoes/etc.
FOUR WHEELER mag July 20xx and OFF-ROAD mag Feb 20xx
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 04-01-2011, 02:10 AM #3
off-roadtoyboy's Avatar
off-roadtoyboy off-roadtoyboy is offline
off-roadtoyboy is on a distinguished road
I have read this alot on fourms with the 2nd gens. I have heard anthing from grimy brake fluid, bad rubber lines, bad calipers, bad master cylinder, and a crumy ABS modudle. In every case it has been something differnet that fixed the problem.
1988 2.4 converted to a 5 speed and rear disk brakes
off-roadtoyboy is offline   Reply With QuoteReply With Quote
Old 04-02-2011, 06:24 PM #4
dwmac64's Avatar
dwmac64's Avatar
Have not replaced anything yet, no money, but I am fixing to do a bench bleed, and see how that goes. noticed a slight hiss when i hit the brakes today.
Old 04-02-2011, 06:56 PM #5
slipknoter106's Avatar
slipknoter106 slipknoter106 is offline
slipknoter106 is on a distinguished road
hey bro, im having he same damn problem i just replaced my brakes and my front passenger brake caliper and it didnt do **** still acts like it is catchin on something also since i put new brakes on it i can smell it burning the new brakes bad. Also the check engine light is on but its saying EGR tho(paperclip trick) So i bleed the brakes to, didnt do anything, the master cylinder looks like it has been replaced before tho, because its new and shiny. i have had my toyota for 2 months. and it hasnt been nothing but a piece of ****. anyways where is that abs sensor thing... the brake problem is coming from the front i know that much... next time im going to let them lock up after driving and then jack it up and spin the wheels which seem to be like they locking up. any tricks or secretes i should know please let me know!!
edit!!!
also the brakes work fine till after about 20 minutes of driving then brakes get hot then they seem to lock up
slipknoter106 is offline   Reply With QuoteReply With Quote
Old 04-02-2011, 08:13 PM #6
dwmac64's Avatar
dwmac64's Avatar
ABS speed sensor is on top of rear differential (10 mm I believe ). haven't been able to get mine off to clean/ check it tho. if you have any luck with that i would like to know the trick. and what's the paper clip trick on egr mine just popped up.
Old 04-03-2011, 06:44 PM #7
ill be sure to check that abs sensor thing tomorrow and get a 10mm to try and check it. thing is idk if theyll let me off duty tomorrow to go fix my truck. because im leaving tuesday. and my ass aint going anywhere with those ****ed up breaks! i replaced the front brakes and calipers and its still locking up. but not as bad as before and also the new smell of burning brakes is insane : /. the paper clip check is check the lil grey box that has diagnose on it behind the battery thing and stick it in TE and TE1 and your check engine light will start flashing and u can get the codes here online!
Old 04-04-2011, 04:15 PM #8
dwmac64's Avatar
dwmac64's Avatar
will do that tonight. thanks.
OEM brakes vs. Firestone/NTB/Midas Brakes for 00' ABS 4runner chico 3rd gen T4Rs 1 03-27-2006 12:23 PM
Disc vs. Drum Brakes Thai 3rd gen T4Rs 0 03-09-2006 01:33 AM
'90 with rear brakes locked ve9gra Classic T4Rs 4 12-02-2005 06:37 PM
Dragging brakes can be hazardous on slippery roads Thai Maintenance/Detailing 0 02-06-2004 01:09 AM
Disc & Drum Brakes Thai Maintenance/Detailing 0 11-20-2002 04:32 PM
