Old 04-14-2011, 08:46 PM #1
grey squirrel grey squirrel is offline
grey squirrel is on a distinguished road
10w-40 oil and Purolator filter for '90 4Runner?
so ive got the 1990 4Runner V6 4WD with 182K mi.
ever since i got this T4R about 2 years ago ive given it 10w-30 quaker state and what ive learned unfortunately to be a terrible filter. ive always used a little too much oil and had a little too low oil pressure. my friend suggested i switch to 10w-40 and that should help with pressure and less oil usage. i just made the switch a couple days ago and can barely tell much difference. so now ive got Pennzoil High Mi 10w-40 and Purolator filter. any thoughts?
grey squirrel is offline   Reply With QuoteReply With Quote
Old 04-14-2011, 11:09 PM #2
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
the oil filter need to have a check valve in it i believe that the purilator does not have a check valve use Toyota OEM filters to solve this problem.
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
oil , oil filter , oil pressure
Diesel oils T4Rscott Maintenance/Detailing 1 10-22-2010 10:15 PM
Switching Oils andyboy 4th Gen T4Rs 2 09-03-2009 05:48 PM
Changing 12v outlets from switched to non-switched cowpaddy Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-18-2007 07:00 PM
Lucus Oils keithguts 4th Gen T4Rs 5 08-14-2006 09:01 PM
Factory oils Swaro Maintenance/Detailing 32 06-07-2006 12:23 PM
