I just mounted new tires and so I went and had an alignment thinking the visible front camber would be straightened out. Oddly the car came back with the same visible positive camber. The specs Firestone printed out for me(see below) shows that the camber is pretty much dead center of the specified range for 4runners. The toe was out of spec quite a bit though.
Also, my Runner has I believe a 4" ProComp lift kit.
I'm wondering if I should have them adjust camber to .2, but also wondering will that leave the front end camber looking straight. Mainly just looks goofy, but if it has a purpose and won't cause excessive/uneven wear, then I guess I'm fine with it.
Can anyone speak into the front positive camber being normal idea?
