Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
Old 09-02-2006, 10:02 PM #31
nmtt92 nmtt92 is offline
nmtt92 is an unknown quantity at this point
Antenna Relay
Has anyone sourced an antenna relay? I have one where the antenna motor continues to run for 15-20 seconds after the antenna is fully extended. The motor shuts off properly when it retracts, but not when it extends.
There's a power antenna relay on the inside of the firewall behind the brake pedal. Based on when the relay clicks off, I'm guessing this is the culprit, but I haven't found a source for one yet.
Any ideas? Thanks.
nmtt92 is offline   Reply With QuoteReply With Quote
Old 01-05-2007, 03:52 PM #32
goose17's Avatar
goose17 goose17 is offline
goose17 is on a distinguished road
goose17's Avatar
Help with Limited
I have a 2000 4runner limited. I need to replace the antenna. Does anyone know the extra steps needed to remove the wheel fender flares? I removed all the bolts and it will not budge.
Thanks!
goose17 is offline   Reply With QuoteReply With Quote
Old 01-06-2007, 04:11 PM #33
goose17's Avatar
goose17's Avatar
Originally posted by Rice Rocket
Ok, this may be dumb, but how do you get the square plugs out with out destroying them?
Rice Rocket, were you able to get the plugs out? Mine will not budge and are breaking apart. I might just rip them out and buy new ones.
2000 4Runner Limited 4x2 - Sold
2006 4Runner Sport 4x4 - Sold
2016 4Runner TRD Pro - Sold
2006 4Runner Sport 4x4 - Praying for frame recall - Sold
2008 4Runner Sport 4x4 - Sold
Old 01-08-2007, 08:41 AM #34
Rice Rocket Rice Rocket is offline
Rice Rocket is an unknown quantity at this point
I had the same problem.. I broke a few of them and others came out fine. Once I got some of them out I saw how they worked but they are still a pain to deal with. Id just rip them out and get some new ones, it will save time :-)
Rice Rocket is offline   Reply With QuoteReply With Quote
Old 02-17-2007, 02:33 PM #35
vn082c vn082c is offline
vn082c is an unknown quantity at this point
Thumbs up Differences in '02 SR5
I have a
vn082c is offline   Reply With QuoteReply With Quote
Old 03-19-2007, 10:06 PM #36
Seca Seca is offline
Seca is an unknown quantity at this point
Thanks for the write up. Took all of about 20 minutes to replace.
Seca is offline   Reply With QuoteReply With Quote
Old 04-07-2007, 03:43 PM #37
Daveed Daveed is offline
Daveed is an unknown quantity at this point
Re: Antenna Relay
Any ideas? Thanks.
This is what mine is doing. Retract is fine and it shuts off right away. Extending it keeps going after the antenna is fully extended and GRINDS GRINDS GRINDS as the teeth are slipping over each other. Sounds horrible. Does it for about 10 seconds.
My first thought was the plastic tooth line was too long but I remember it being exactly the same length as the stock one I took out (wasn't broken inside...just the mast got bent/broken from a branch). If I trim it and it then the motor can't grab it to retract it then I have to buy another antenna and still don't have the problem fixed.
Anyone figured out how to deal with this?
I also can hear the clicks from relays? down by my left foot...
I'm gonna go disconnect the power to the antenna tomorrow morning (wait...it is morning so I'll do it in about 9 hours when I get up )
Daveed is offline   Reply With QuoteReply With Quote
Old 04-10-2007, 05:15 PM #38
beck609 beck609 is offline
beck609 is an unknown quantity at this point
Thanks..
This is a great post....the only trouble i had was getting the "chrome" trim back on....It didn't quite go as planned. I can't figure out how the snap works on the one closest to the front of the truck...99 t4r sr5.
beck609 is offline   Reply With QuoteReply With Quote
Old 04-23-2007, 01:09 AM #39
crimsonking32's Avatar
crimsonking32 crimsonking32 is offline
crimsonking32 is an unknown quantity at this point
Thanks for the great advice and pictures. Made replacement a snap on my 90 4Runner
A++
crimsonking32 is offline   Reply With QuoteReply With Quote
Old 04-26-2007, 08:38 PM #40
slacker's Avatar
slacker slacker is offline
slacker is on a distinguished road
slacker's Avatar
seems like you guys went threw a LOT of hassle to me ..
I hate to break this to ya .. BUT those antennas can be replaced way easier then that .
The 1 piece antenna , and cable ... can be wound in .. right at the source ...
you need to remove the top nut as pictured in the first post .. but then you simply turn on the radio .. the antenna will wind out .
Then simply push in the new cable , and turn OFF the radio .. making sure the teeth are facing the correct direction .. it will wind it back in .
put the top nut back on .. done deal .
geeezzzz.
nice post .
slacker is offline   Reply With QuoteReply With Quote
Old 05-02-2007, 02:35 PM #41
ruinit3's Avatar
ruinit3 ruinit3 is offline
ruinit3 is an unknown quantity at this point
ruinit3's Avatar
geeezzzz.
nice post .
not if you have broken pieces of the mast still in the motor. The directions off of antennamastsrus.com say to remove the motor if the old mast isn't the same size as the new mast to get the broken pieces out.
I think i'll be removing the motor and taking a look since I know my mast broke off.
2000 4Runner SR5 4wd Black
ruinit3 is offline   Reply With QuoteReply With Quote
Old 05-02-2007, 02:58 PM #42
slacker's Avatar
slacker's Avatar
the many I have done were all broken ..
removing the top nut and turning it ON .. will push the old antenna out .
just try it .. if it dont work , you have to pull out the motor anyway . I'll lay MONEY on it .
Old 05-02-2007, 04:13 PM #43
ruinit3's Avatar
ruinit3's Avatar
haha i love laying MONEY on things. you sound very convincing, so I'll try it. I'll let you know if it worked. Thanks
Old 05-02-2007, 07:16 PM #44
slacker's Avatar
slacker's Avatar
absitivily .. post up your results .
just a little tip .. best to have someone sitting in the drivers seat .. to turn on the power , then once the nut is off , have them push the radio button to enguage the antenna . MAKE sure you see which way the teeth on the cable are facing (should be towards the windshield) ........ then push the new cable in till it stops , and have your friend turn off the radio .. you'll have to be carefull to follow the cable in and then the mast all in one motion , like threading a needle . but on the nut , and viola , your done ..
should take about 2 mins .
Old 06-28-2007, 03:00 PM #45
kingbiscuit kingbiscuit is offline
kingbiscuit is an unknown quantity at this point
Im having them disconnect the power to my motor today. It is very irritating.
1998 4runner v6 4x4 stock
kingbiscuit is offline   Reply With QuoteReply With Quote
power antenna with new radio airden Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-13-2010 11:25 PM
97 4runner power radio antenna help Skizor1337 3rd gen T4Rs 10 07-26-2010 07:15 PM
Power antenna issue.. voltageGSR 3rd gen T4Rs 3 03-02-2008 12:40 AM
'93 power antenna modification unibody Classic T4Rs 1 06-12-2006 04:17 PM
Power antenna estradacg Engines / Suspension / Wheels / Tires / Audio / Accessories 3 08-13-2003 09:53 AM
