Originally Posted by b79turner
Well I was able to put a rubber spacer just under the rubber seal that came with my replacement antenna mast. Problem solved. I'm not sure why that was necessary but oh well.
I have the same issue. I've tried to losen the whole motor assembly & play with it by raising it and retorqueing the bolt holding the assembly, but I can't really take out all the movement from that little black grommet. I don't see this behaviour on youtube videos, so not sure what's the issue here. Maybe I should use some needle nose pliers and torque the big silver plastic nut more? Now it's "only" torqued by my nails.
2, While the antenna now goes up and down perfectly by switching the radio on/off (and the motor stops at both limits), the down button is not working on the dash. Nothing happens when I press it. The up button does work though. The antenna is obviously fully erect when I'm pressing the buttons, and the up button clicks the relay, but the down does not. Both buttons click the relay if I leave the antenna assembly disconnected, so it is not an issue with the buttons or the relay I believe.
