Old 10-22-2018, 06:08 PM #31
906-Runner's Avatar
906-Runner 906-Runner is offline
Real Name: Blayne
906-Runner is on a distinguished road
906-Runner's Avatar
Real Name: Blayne
I installed a new head unit in my 4Runner and now the back window wont roll down with the key. Before putting in the new head unit I could put my key into the lock the hatch and turn and hold it on either side and it would roll up and down, but after the new stereo that function no longer works. So my question is does the wiring of the back window have anything to do with the stock radio?
906-Runner is offline   Reply With QuoteReply With Quote
Old 10-22-2018, 08:25 PM #32
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
helps to say what year 4runner you have, but no the window wiring doesn't usually run behind the radio. Hard to say what previous owners have hacked up though
does it work from the switch on your center console? both 1st and 2nd gens have the switch there. Did you remove the center console and run any speaker or amp wiring along the tunnel?
How were your fuses?
Is it possible you have the power window lock on? if so it won't roll down (not sure if that is true for using the key)
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 10-23-2018, 09:36 AM #33
906-Runner's Avatar
Real Name: Blayne
906-Runner's Avatar
Real Name: Blayne
I have a 2000, but the power window lock is not turned on, and it works from the button in the center of the dash. The previous owner had it wired for subs and an amp but there was no wiring running along the tunnel. It’s not that big of a deal I was just wondering if the radio had anything to do with the radio.
Old 10-23-2018, 09:50 AM #34
Dropzone's Avatar
Dropzone's Avatar
might wanna post this in the 3rd gen folder
this one covers 84-95
@503dropzone on IG
Old 10-31-2018, 10:07 PM #35
Fullfathom5 Fullfathom5 is offline
Fullfathom5 is on a distinguished road
This is an old thread but I had a problem with my window not rolling down from the button on the console in my '88. It turned out the rear wiper hadn't returned all the way up. I adjusted it, and it may have been coincidence but I haven't had another issue in 6 months.
Fullfathom5 is offline   Reply With QuoteReply With Quote
Old 11-29-2018, 07:18 PM #36
Voltan73's Avatar
Voltan73 Voltan73 is offline
Real Name: Jason
Voltan73 has a spectacular aura about Voltan73 has a spectacular aura about
Voltan73's Avatar
Real Name: Jason
I had this issue with my '88 a few years ago. When using the key, if I banged my fist on the tailgate, it would work sometimes. I had one of our techs check it out (I work at a Toyota dealership), to no avail. The problem went away on it's own...
A year or so later, the problem returned. I had a different tech check it out...he found that the plug to the motor wasn't fully clicked into place. Haven't had a problem since.
Voltan73 is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 10:35 AM #37
ChrisBengua ChrisBengua is offline
ChrisBengua is on a distinguished road
Rear window
Does anyone here experience this, my 4th gen 4runner rearwindow only rolls down6" inches but it goes up...It wont go all the way down.
ChrisBengua is offline   Reply With QuoteReply With Quote
Old 02-06-2019, 02:49 AM #38
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Sorry, wrong forum. You'll have better luck posting on 4th gen forum.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 03-31-2019, 05:21 PM #39
MBZ300CD's Avatar
MBZ300CD MBZ300CD is offline
Real Name: Gary
MBZ300CD will become famous soon enough
MBZ300CD's Avatar
Real Name: Gary
Originally Posted by rustED_ View Post
^^^not my picture, but this is how I jumpered my back window on my 87' ...no more problems. This is the plug that goes to the up/down switch in the console. The jumper bypasses all the safety switches, so if the top is off or the tailgate is down it will still operate, but that doesn't really bother me, it's pretty common sense not to mess with the window in those situations.
Thank you, thank you, thank you. Made for a very quick fix. This is why I'm here.
1987 4Runner 22RE 5 spd
Gary
MBZ300CD is offline   Reply With QuoteReply With Quote
Old 11-20-2019, 06:13 PM #40
rrsnotyours rrsnotyours is offline
rrsnotyours is on a distinguished road
Maybe this can help someone out..if you remove the top, and replace it, there is a switch that is engaged by putting one of the bolts back ( covered many times )..
However, make sure to use the right bolt (longer) as the shorter bolts will not reach the plunger and engage the switch. EASY FIX. Or just take driver rear inside panel off , unscrew the switch, push plunger by hand to test. Hope it helps anyone...
rrsnotyours is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 01:15 PM #41
JohnDeer81 JohnDeer81 is offline
JohnDeer81 is on a distinguished road
Originally Posted by 91'runner View Post
im having the same issue , except i can hear a noise itll buzz 3 times for about 15 seconds, and i can hear my window motor click, now i know my back wiper doesnt work and i cant figure out what fuse controls the back window controls/ back wiper
Hey man, I know this is really old here but I just figured out what was wrong with mine. I heard the little buzzing and clicks in the rear so I knew it was getting power. My rear wiper also works fine so I thought to raise the gate and pull back the rubber shroud that is around the harness. Low and behold the ground wire was snapped in two and power wire just about the same. With the gate up I could roll the window down so I know motor is good.
Reviving old threads!
JohnDeer81 is offline   Reply With QuoteReply With Quote
Old 10-13-2020, 01:19 PM #42
Rear window fix/culprit
I know many of your comments in here are older, but having this issue just arise for myself I thought to post my findings in hopes it will help others with this issues.
My rear window on my 3rd gen recently stopped working but I could hear buzzing/clicking in the rear of the truck so my assumption was power was reaching the target but for some reason the window wouldn't go down. My rear wiper also works just fine - to note. I thought to raise the gate and then try rolling down the window again from inside the cab and IT WORKED! This made me think there might be an issue with the wiring harness that comes from inside the truck to the back gate which is easily seen when you raised the gate. I pulled back this rubber shroud and the ground wire was snapped in two, power wire not far off. Opening the hatch must have pushed the ground together to make contact.
I am going to solder some fresh wire in here to keep the length and rubber wrap it.
Hope this helps the community!
Old 10-21-2020, 11:31 AM #43
Griswald's Avatar
Griswald Griswald is offline
Griswald is on a distinguished road
Griswald's Avatar
A couple years ago I had a similar issue in my 89 where the rear window would not roll back up. Wiper was in place, bolt was in.
I wound up taking it to a guy who said there was an issue with the grounding. He was able to locate it and fix it pretty cheap.
Griswald is offline   Reply With QuoteReply With Quote
Old 10-24-2020, 05:15 AM #44
4RunnerNorway 4RunnerNorway is offline
4RunnerNorway is on a distinguished road
Rear window
my rear window does work downwards with the key, but not upwards. Works fine with the button(up and down). What to do?
4RunnerNorway is offline   Reply With QuoteReply With Quote
Old 11-11-2020, 06:44 PM #45
86yota4Runner 86yota4Runner is offline
86yota4Runner is on a distinguished road
86 Yota 4Runner
Switches work for back window, but the key does nothing to the back window. It would be so convenient if it worked LOL. please somebody help
86yota4Runner is offline   Reply With QuoteReply With Quote
Rear window won't roll down collin 3rd gen T4Rs 37 04-04-2024 11:37 AM
Rear Window Wont Roll Down by Inside Button... antidentite 4th Gen T4Rs 8 04-04-2015 04:16 PM
Passenger side window wont roll down Mason Fresh Maintenance/Detailing 2 01-19-2010 03:54 PM
Rear window won't roll down :( laureena23 3rd gen T4Rs 8 11-04-2009 02:33 PM
98 back window wont roll up hamster_13 4th Gen T4Rs 1 01-29-2005 03:07 PM
