Old 05-05-2011, 07:24 PM #1
Kris-with-a-k Kris-with-a-k is offline
Kris-with-a-k is on a distinguished road
spark plug help!!!
soo im doing spark plugs. it needed them baaaad. So i got em. My first time doing them. Found em' took them off easily enough buuuuuuut 2 of the new ones wont screw in all the way as if the threads arent lining up? I get about half way in and it goes tight. I broke one already tried it again with an old one but that one broke too. double fail
Any tips or trick to get it to go in??
Thanks,
Kris
Kris-with-a-k is offline   Reply With QuoteReply With Quote
Old 05-05-2011, 07:28 PM #2
Lineman's Avatar
Lineman Lineman is offline
Lineman is on a distinguished road
Lineman's Avatar
Have you tried putting anti-seize on the threads?
Black 2003 Sport, V8, 4WD, 115K miles - as of June
2016, AMSOIL lubed, JVC Headunit 925BT, Rockford Fosgate Amp, Rockford Fosgate 10'' P2's in custom box
Lineman is offline   Reply With QuoteReply With Quote
Old 05-05-2011, 07:51 PM #3
assuming anti seize is an corrosive ridding oil? no I havnt yet.
Old 05-05-2011, 07:52 PM #4
4runner_kid's Avatar
4runner_kid 4runner_kid is offline
Real Name: John
4runner_kid is on a distinguished road
Real Name: John
Try anti seize, work's good.
4runner_kid is offline   Reply With QuoteReply With Quote
Old 05-05-2011, 09:46 PM #5
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice fourwd1 is just really nice
Moderator
fourwd1's Avatar
It's a silver paste that you'll get on you no matter how hard you try not to, and it works great.
But if you have broken 2 plugs trying to screw them in, you may have a bigger problem.
You might want to run a thread chaser thru there to make sure clean them up
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 05-06-2011, 03:52 PM #6
sooo tried the aiti seize buuuuuuut nothing.. It always stops and gets stuck in the same place as you can tell when you pull it out and see it in there.
Whats up?
Old 05-06-2011, 05:21 PM #7
masterzeke7 masterzeke7 is offline
masterzeke7 is on a distinguished road
sounds like the previous owner when he put them in ended up stripping the threads. If thats the case getting a new one in will be impossible without rethreading it. Those are a ***** to since you have to catch all the shavings so they dont fall in the block. Had to do it for a mitsubushi I had.
masterzeke7 is offline   Reply With QuoteReply With Quote
Old 05-07-2011, 10:46 PM #8
aj884runner aj884runner is offline
aj884runner is on a distinguished road
A chaser like the one shown in fourwd1 post will usually work. Dip the chaser in some grease to catch any filings that come off. If that doesn`t work you will have to use a spark plug repair kit.
aj884runner is offline   Reply With QuoteReply With Quote
Old 05-09-2011, 07:21 PM #9
didnt work
alright. So i changed my plugs. tuned it up aaaaand did some fixing on it.. The idle on it was bad and basically staleld out so I fixed that problem buuuuut my MAJOR problem still isnt fixed. I basically have to mash the peddle to the floor for it to go anywhere and even that is is sluggush. Also have to manually shift on an auto matic. The OVERDRIVE doesnt really work anymore. I click it on and it flashes OD off. Been like that for about a year... Whats up? Is it time for a new 4 runner??? 1992 165xxx miles on her..
Old 05-09-2011, 08:58 PM #10
Real Name: John
Real Name: John
Overdrive Shift solenoid is out.
Old 05-09-2011, 09:43 PM #11
$$$$??? aaaaand what about the slow, sluggush, pushing the pedal to the floor so it can even go??
Old 05-10-2011, 02:24 AM #12
T?@\7 T?@\7 is offline
T?@\7 is on a distinguished road
dude
i think you broke something...?
1987 dlx
SHAKKA
Originally Posted by SCRunner12 View Post
Where's T?@\7 at? He's always talking about bong rips in his posts. I thought he would be all over this post by now.
T?@\7 is offline   Reply With QuoteReply With Quote
Old 05-10-2011, 04:10 AM #13
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Is it stuck in 4th?
KidVermicious is offline   Reply With QuoteReply With Quote
Old 05-10-2011, 03:05 PM #14
Real Name: John
Real Name: John
I would take it to a shop and have them scan for transmission code's, if you can scan it yourself more power to you. Sound's like it's stuck in overdrive.
Old 05-10-2011, 03:29 PM #15
Ive taken it to the shop and they said something or another they cant figure it out because something is wrong. iiidk I will have to. Idk if I broke anything but more or less it broke itself?? I was just driving it one day turned it off went to work the next morning and bam.. Stuck in 3rd or 4th. Thats when I had to start manually shifting it.. It worked and ran, sped up and what not just fine.. Now. Even in first. Its slooooow as hell.. and takes it a bit to get up to speed.
which spark plug ? davem Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-20-2008 09:26 PM
Loose spark plug cornwallis Problems & Warranty Issues 4 05-24-2007 04:14 PM
'98 spark plug torque samk Maintenance/Detailing 2 10-15-2005 09:51 AM
spark plug gap muddybamayota88 Maintenance/Detailing 0 08-30-2005 10:02 AM
spark plug gap Armandi Maintenance/Detailing 3 02-06-2005 08:17 PM
