2001 4runner has speed sensor code error
qube53
I have a 2001 4runner that has speed sensor code error, the speedometer is not working and the check engine light, ABS, and most other dash lights on. I already changed the speed sensor on the back of the transmission. Any idea as to what else it may be. the code is still saying speed sensor
well this was posted in the wrong section but ill answer it anyway its called the ABS speed sensor on the wheel hub of all your wheels it sends the signal for speed and ABS control's
RockAuto Auto Parts
select your vehicle then type in ABS speed sensor to see all the prices for all 4 wheels.
download a Factory service manual for your year and read how to test the ABS speed sensor then you can narrow down what one failed and replace it!
