Time for an update... I installed my LCE under drive pulley kit, deleted the A/C system and the belt driven fan, and installed an electric fan using a permacool unit and a 16" hayden fan.
Pics of the under drive kit:
Buh-bye air conditioner:
Here's the fan with all the wiring cut to length.
All connections soldered and heat shrink wrapped.
Built some quick brackets to hold the fan to the backside of the radiator. And of course, they had to be painted blue
Fan installed:
All wiring wrapped in split loom tubing:
For now the permacool unit is attached to the radiator using velcro. I'll keep an eye on it and if it seems as if it doesn't hold up then I'll build a permanent mount that will screw to the core support.
It's a little tight but everything fits well
So far everything works very well. The radiator hasn't gotten hot enough to turn the fan on (thermostat is set at 180*) but I used my heat gun on the sensor to get it hot enough to turn the fan on.
Between the under drive pulley taking nearly 10 lbs of rotating mass off of the crank shaft, deleting the a/c and belt driven fan, and all my previous motor mods and performance parts, the 4.10 gears ALMOST seem like they're supposed to be there for the 35" tires. I don't know what I'm at for power at the crank or the wheels but I would love to get it on a dyno and see what I'm getting for actual hp and tq numbers.
