Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 02-14-2012, 04:37 PM #61
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Diggin' it.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 10:20 PM #62
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
Originally Posted by KidVermicious View Post
Diggin' it.
Thanks!
SV_Dude is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 10:27 PM #63
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Battery box is done!
I drew a template with cardboard then cut it out of sheet metal:
Started bending the sheet metal into the battery box:
Only the best of high tech tools to bend this stuff
Box formed and a test fit with the battery:
Now to start building the base. I cut out the center of the box leaving a 1" perimeter for the battery to sit on. I used some 1/2"x1/8" strap to lower the base to give the mounting hardware clearance from the battery then welded the base back on.
All welds on all edges were ground smooth:
Battery tie down strap bent up and another test fit of the battery:
Then a test fit in the engine bay:
Right now I'm waiting on paint to dry. I'll post finished and installed pics tomorrow.
Old 02-14-2012, 11:07 PM #64
ToyoTech's Avatar
ToyoTech ToyoTech is offline
ToyoTech is on a distinguished road
ToyoTech's Avatar
nice rust repair and battery box. should clean up the engine bay
ToyoTech is offline   Reply With QuoteReply With Quote
Old 02-14-2012, 11:17 PM #65
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Thanks! I'm painting it the same blue that I painted the engine with so it should look good in there.
Old 02-14-2012, 11:48 PM #66
Footofgod's Avatar
Footofgod Footofgod is offline
Footofgod is on a distinguished road
Footofgod's Avatar
Sweet! I really need to learn how to weld.
Footofgod is offline   Reply With QuoteReply With Quote
Old 02-15-2012, 04:06 PM #67
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Thanks! Learning how to work with steel and reading a LOT on pirate4x4 has completely opened my eyes to endless possibilities of what can be done on these rigs. I have more fun working/building my runner than I do driving it.
So... The battery box is done and installed. Looks right at home in a rust free fender!
Old 02-15-2012, 04:11 PM #68
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Now on to the next project
Interior before:
All stripped out:
Gross!!
And the exterior:
The plans are to give this runner a pretty good cleaning and a little bit of a make over. I'll clean the snot out of the whole entire lower half of the interior then line it with some chassis saver and some monstaliner. I'll also put a coating of dark gray monstaliner alone the bottom edge and the fenders of the runner.
That should clean things up and make the inside a lot better looking and stop any future rust from showing its ugly face!
Old 02-15-2012, 05:24 PM #69
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
For anyone wanting to strip the factory sound deadening... use an air hammer! I started chipping away at it with a flat head and a small hammer until I remembered that I have a chisel tip for my air hammer. All I can say is wow! This stuff peeled and jumped off with ease. About 30 minutes with the air hammer and all of the factory sound deadening in the whole runner was gone. I love air tools!!
Old 02-15-2012, 10:03 PM #70
jakejjs's Avatar
jakejjs jakejjs is offline
jakejjs is on a distinguished road
jakejjs's Avatar
Wow love the dedication and attention to detail. And that battery box....fits like a glove! Build me one?
I joined the site so i could comment on your truck. If you saw my 85 you'd gringe at the rock damage to the body. I'll be keeping my eye on this thread, can't wait to see the SAS.
jakejjs is offline   Reply With QuoteReply With Quote
Old 02-15-2012, 11:09 PM #71
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Thanks!
haha... maybe before too long I'll have some body damage too. But I couldn't leave it damaged. I would have to fix it as soon as I destroy it. After all, I am building something that is supposed to get destroyed and fixed again.
Old 02-16-2012, 12:22 AM #72
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Man that box is sick! Nice work!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 02-16-2012, 07:52 PM #73
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Thanks! It turned out well but I wouldn't do it again. For something that cheap to buy it definitely wasn't worth the time it took.
Old 02-16-2012, 07:59 PM #74
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
So I got the runner all prepped, inside and out. The use of a 4" flapper disc on the inside and some 80 grit on a palm sander on the outside made really light work of everything.
The next part is where I get to show off a cool little trick I learned a while ago. If you have a hole in sheet metal that you need to fill, do the following: Get a small piece of copper plate and secure it to the inside of the hole:
Sand down to bare metal to attach the ground for the welder and clean the area around the holes:
Then just fill in the holes with a little bit of weld. The filler metal does not stick to the copper and it will sand down nice and smooth.
The brown truck of goodness showed up just as it was getting dark so I will have to wait until tomorrow to apply the liner. Hopefully my masking tape will stay on over night and not get all messed up due to condensation.
More tomorrow
Old 02-16-2012, 08:38 PM #75
Footofgod's Avatar
Footofgod's Avatar
More tomorrow
Are you doing the liner in the lower half like I did? should look sweet!
Originally Posted by dorton View Post
I wish I had a 2nd gen.
Originally Posted by BucknutBob View Post
I find myself wishing I had waited and picked up a 2nd Gen instead
I want to convert my '85 to IFS.
jam23r1's Runner build jam23r1 5th gen T4Rs 80 02-18-2016 05:40 PM
Enigma's 1st runner build MaverickTRD 3rd gen T4Rs 40 02-02-2016 04:32 PM
And So it Begins:) 99 Runner build Rockdawg84 3rd gen T4Rs 125 07-30-2014 02:53 PM
The Runner build thread Jander 3rd gen T4Rs 6 04-26-2013 09:45 AM
My new runner / build thread Wakeborder556 5th gen T4Rs 5 04-03-2012 12:38 PM
