Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 06-05-2011, 06:28 PM #1
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
87 4 Runner Build
Here it is... this is my 87 4runner that I bought originally with a 22rte motor in it. I spun the #3 rod bearing so I am in the mix of rebuilding the motor. I am ditching the turbo setup and going with a mildly built 22re.
As the 4runner sits now I put in a 5 inch TG lift in the rear:
I took the axle apart and cleaned everything up. Sanded the axle down to the metal and repainted it. The guts are stock (for now).
While I was working in the read end I couldn't stand to look at the old nasty gas tank. Plus, I had to pull it to grind and weld the new rear spring mounts. So It got a good cleaning, and sanded down to the metal. I re coated it in a rubberized undercoating. Now it looks brand spanking new
4 inch rough country IFS lift in the front (only till I do my SAS):
Yes, the p/o had an intercooler on a t4 turbo that was too big for this motor, not to mention any time I gave it gas the ECU would cut the fuel. That turbo didn't last long. I put a stock turbo on it ASAP!
Engine before (best pic I could find):
I picked up a rebuildable assembled 22re short block for $50. That block, crank, and connecting rods are at the machine shop now. The machine shop is going to deck the block, bore .030 over, hot tank and chase all the threads. They are also going to grind the crank .010, R&R all the sludge traps and recondition the rods. All the other little misc parts and pieces are going to them tomorrow for a bath in their hot tank.
As for the engine build, I ordered my rebuild kit from engnbldr along with a 268 cam. I am also going to order a street RV head tomorrow. Hopefully with the block being .030 over, 268 cam, and a street RV head, this should give me about 140HP.
So here's the progress:
Engine bay as it sits right now:
Today I'll clean the snot out of the whole area and make it all new and pretty.
The wiring harness:
The plans here are to clean the whole harness and re-wrap it in some new loom. The plug for the fuel injector is rigged by twisted wire (thanks to the po), so that will get soldered and cleaned up.
And a rusted out battery tray from a po's bad battery:
I'll find a replacement from someone who is willing to cut that section out from a parts truck and weld it in.
That's about all I have for now. I'll hopefully the engine done in a week or so... then it's on to the interior.
I am kinda new to all of this, this is the first vehicle I have taken on as a project. I have been bending wrenches on various things for a while, but never anything like this. So, any input is welcomed and even if it seems to be common sense, your input is appreciated!
**if anyone cares (it's still a toyota forum), here's a build thread I did on my 2010 tundra. I needed a spot for some 12" sub woofers and couldn't fit them under the rear seat. I cut the floor board and put some subs under the carpet:
Subs in the FLOOR!!! - TundraTalk.net - Toyota Tundra Discussion Forum
SV_Dude is offline   Reply With QuoteReply With Quote
Old 06-05-2011, 08:41 PM #2
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Looks nice! What are you running for gears?
...you should keep the turbo setup. You dont see to many turbo runners on the road...
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 06-05-2011, 11:20 PM #3
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
I have the stock 22re gears. The rte motor was a swap by the p/o. I am getting rid of the turbo because I want minimal moving parts and pieces. I want a good reliable trail rig that will get me home and also be a daily driver. Besides, with my current build I will get more power than the stock rte will put out.
Old 06-06-2011, 02:08 PM #4
dj6759 dj6759 is offline
dj6759 is on a distinguished road
Question Knock Senser
Have a knock in my 22RE. Was told poss. knock senser unplugged? Need to locate knock senser.
dj6759 is offline   Reply With QuoteReply With Quote
Old 06-06-2011, 09:13 PM #5
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
So I pretty much have nothing but busy work until next week when I get my motor and parts back from the engine shop. So, I pressure washed the engine bay and the undercarriage of the 4runner 3 times after letting it soak a few times with a ZEP industrial concentrate de-greaser.
It's not perfect, but it is MUCH better:
I also cleaned the snot out of the distributor and put some paint on it:
That's all for now. Tomorrow I'm going to make a trip to the machine shop to deliver a box of misc parts for the hot tank. I'll probably clean up some of the wiring and hoses in the engine bay. I didn't take any pictures, but I also re-wrapped the engine wiring harness with new electrical tape. I have some wire loom on order so everything under the hood will get new wire loom.
Old 06-06-2011, 09:20 PM #6
4runner_kid's Avatar
4runner_kid 4runner_kid is offline
Real Name: John
4runner_kid is on a distinguished road
Real Name: John
I can't wait to see where this goes, however i think you should keep the turbo setup to.
4runner_kid is offline   Reply With QuoteReply With Quote
Old 06-06-2011, 09:23 PM #7
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
I did like the idea of having a rare turbo in my 4runner. But... I want the simplicity. I don't want to worry about a turbo going south when I'm out on a trail or driving around. Plus, it would have cost me more to rebuild this with keeping the turbo (turbo needs to be rebuilt ($500-$600)). This whole project is costing me roughly $1800-$1900 including some new long tube headers that will be ordered soon. For less money I am able to get more power than the rte setup will give.
Old 06-11-2011, 05:20 PM #8
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Still waiting on the machine shop to give me my junk back.
But I scrubbed the engine bay again to try and get it better. I also picked up a n/a AFM, cleaned it up and threw on a nice coat of gloss black.
I may end up yanking the p/s res. and pump and cleaning them up a bit. Maybe the ac compressor too.
Old 06-12-2011, 04:05 AM #9
nashville67's Avatar
nashville67 nashville67 is offline
nashville67 is on a distinguished road
how hard was the lift to put on iam thinking the same one i was wondering wht size tires are on it and if you could post some meassure ments and some side shots
nashville67 is offline   Reply With QuoteReply With Quote
Old 06-12-2011, 08:54 AM #10
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
What lift, front or rear? The rear was a lot easier than the front. All I had to do for the rear was cut the stock leaf spring mounts off of the frame and grind the frame smooth, then weld on new ones for the longer springs. Do a little cutting, sanding, welding on the axle and I'm good to go.
The front was a pain in the @$$!! I was taking hardware off that hasn't been off in 25 years, I had to replace a couple of steering knuckles because they were impossible to get off. Overall on the front, it wasn't too bad but it was still a pain in the arse. If you have air tools it will be much easier.
Old 06-15-2011, 11:47 PM #11
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Well... I haven't got much done lately. I've had a fever since saturday and I think I finally broke it. So I spent some time in the garage today! I picked up my block and connecting rods from the shop today, I got my rebuild kit in on Monday, and my Street RV head in yesterday. I wasn't happy with the hot tank job that was done on the motor so I taped the snot out of it and plugged all the bolt holes. I'm going to carefully sand blast the block before painting it.
I am however very happy with how all my little parts came out from the hot tank. They will be getting painted tomorrow.
I needed to order a new crank shaft, and I also ordered an LCE Header but they are on backorder for 3-4 weeks. Too bad, I was excited about driving my 4runner sooner!
Here's what I got for the porn so far:
New head, there's a box beside it that has a 268 cam in it too
I painted the p/s reservoir (already installed in the engine bay), p/s pump, and other brackets with it:
The block all prepped and ready for sand blasting then paint:
Old 06-15-2011, 11:59 PM #12
dem dem is offline
dem is on a distinguished road
dem dem is offline
Nice job ! I like parts when there cleaned up and painted, It shows detail and you take care of your stuff.
84 4WD , 90 4WD 4Runner, 02 Prerunner
dem is offline   Reply With QuoteReply With Quote
Old 06-16-2011, 12:45 AM #13
T?@\7 T?@\7 is offline
T?@\7 is on a distinguished road
my '87 is ready when you are mate.
1987 dlx
SHAKKA
Originally Posted by SCRunner12 View Post
Where's T?@\7 at? He's always talking about bong rips in his posts. I thought he would be all over this post by now.
T?@\7 is offline   Reply With QuoteReply With Quote
Old 06-16-2011, 08:21 PM #14
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
Progress is slow but detailed... I think.
I'm not in too much of a hurry, I don't have my crankshaft yet so I cannot do too much in the way of assembly. My pile of painted parts on the bench is growing and I put some high temp paint on the block. The block is fit for a smurf
Pile of cleaned and painted parts
Pretty fuel rail
And the blue block!
Old 07-01-2011, 10:33 PM #15
Moderator
Real Name: Jonathan
Moderator
Real Name: Jonathan
So for the last week or so I have been waiting on parts to come in the mail to start putting this motor together. I got the new crank in but then I had to send the over sized main and rod bearings back and get standard ones, had to wait for them. Thanks to Ted at engnbldr he shipped the new bearings right away, before I sent him money for shipping or sent him the over sized bearings. Thanks Ted! (fiy: engnbldr is by far the best place to work with to get parts or answers about the 22re!)
Anyways, I got some assembly done today. I put the crank shaft, pistons, and a few external goodies bolted on. I took some measurements of the quench on the pistons and I am very happy with the results!
Quench Measurements:
Cyl #1: .017
Cyl #2: .018
Cyl #3: .020
Cyl #4: .017
According to an article that I found that was written by Ted at engnbldr, anything within +/- .006 is excellent! Mine is +/- .003! So far I am happy with the work that was done by the machine shop!
Anyways, enough talk, here's some porn:
I need to get some crank keys because the new crank shaft didn't come with any keys! ARGH!!
jam23r1's Runner build jam23r1 5th gen T4Rs 80 02-18-2016 05:40 PM
Enigma's 1st runner build MaverickTRD 3rd gen T4Rs 40 02-02-2016 04:32 PM
And So it Begins:) 99 Runner build Rockdawg84 3rd gen T4Rs 125 07-30-2014 02:53 PM
The Runner build thread Jander 3rd gen T4Rs 6 04-26-2013 09:45 AM
My new runner / build thread Wakeborder556 5th gen T4Rs 5 04-03-2012 12:38 PM
