Old 06-13-2011, 12:50 PM #1
Rob503 Rob503 is offline
Rob503 is on a distinguished road
Angry Absolutely no power!
I have an 1987 4runner. The last couple months I have noticed that my truck doesn't always start. Sometimes I just hear a clicking and thats it, so I wait a couple minutes and it usually starts up. Well the other day this happened and after it fired up it started acting very strange. 1st I noticed my battery gauge was fluctuating rapidly. 2nd my check engine light was flickering. 3rd I was getting inconsistent power which led to erratic idling. I drove it back home and replaced the alternator and the battery, both the negative and positive battery cables and no I have no power at all. No lights, no radio, nothing. Before I replaced all this stuff I tried starting my truck up one last time to see if it would run correctly but it wouldnt even allow me to roll down my rear window. Obviously it some type of power failure. I have checked all the fuses and they seem to be fine. I am kind of an r&r guy I can remove and replace but do not have the knowledge to do more then the easier stuff.... Any help is much appreciated!!
-rob- Its a 5 speed
Last edited by Rob503; 06-13-2011 at 01:06 PM. Reason: Forgot to mention its a 5 speed
Rob503 is offline   Reply With QuoteReply With Quote
Old 06-13-2011, 01:05 PM #2
Thurlo76's Avatar
Thurlo76 Thurlo76 is offline
Thurlo76 is on a distinguished road
Thurlo76's Avatar
im assuming its EFI did u check all the plugs aroung the intake? make sure you have a good ground?
1987 SR5 rebuilt 2.4ltr, custom front and rear bumpers, ball joint spacers, coil spring rear lift, 4.88 gears, 33x12.5x15 General Grabbers AT2's, bunch other goodies- SOLD.........
1997 SR5 4runner, 3.4, 5 speed, 4x4, 265/75/16's on Tacoma TRD rims, pretty stock....but not for long
Thurlo76 is offline   Reply With QuoteReply With Quote
Old 06-13-2011, 01:34 PM #3
Illusive Illusive is offline
Illusive is on a distinguished road
I had an issue just last week with the no gauges and no power to the back window. I simply checked my fuses under the driver side kick panel and one was burnt out. I replaced it and my problem went away. something had shorted and thats what blew the fuse.
Now your problem sounds a little more complicated than that, but maybe this would give you an idea of where to start?
Illusive is offline   Reply With QuoteReply With Quote
Old 06-13-2011, 01:43 PM #4
Would a bad starter or relay be a cause??
Old 06-13-2011, 02:06 PM #5
Mr. Leary's Avatar
Mr. Leary Mr. Leary is offline
Mr. Leary is on a distinguished road
Mr. Leary's Avatar
Nope.
Fuses are either intact or not, which means that low current draw equals fuse still intact.
Sounds like it could be a faulty voltage regulator on your alternator. By now your battery may be toast as well.
Go get the alternator checked.
Mr. Leary is offline   Reply With QuoteReply With Quote
Old 06-13-2011, 05:11 PM #6
RotaMan2's Avatar
RotaMan2 RotaMan2 is offline
RotaMan2 is on a distinguished road
RotaMan2's Avatar
There is a white wire from the fuse box to the battery that is a fuseable link. It may have burned but will still look ok from the outside. check for volatge from battery to fusebox.
RotaMan2 is offline   Reply With QuoteReply With Quote
Old 06-13-2011, 06:34 PM #7
I changed both battery cables..The positive cable just bolted to the starter or starter relay, I don't recall any other wire coming from the battery except negative which is grounded to the lower part of the motor.
Old 06-13-2011, 07:41 PM #8
run4yota run4yota is offline
run4yota is on a distinguished road
to be honest it sounds like you have a bad voltage regulator and/or alternator (originally) and after changing the battery and alternator you accidentally put the battery in backwards. i'd check your posts one more time. assuming you have your battery in correct (and it's charged) i'd say it is probably something in the ignition switch or relay system.
run4yota is offline   Reply With QuoteReply With Quote
Old 03-29-2013, 02:13 PM #9
Mousecop Mousecop is offline
Mousecop is on a distinguished road
To all on this thread
ok Rob so I have the same 4runner. 1987 5 speed with the same problem. My only difference is before the winter, the truck ran just fine. there were no starting problems. Around the feb. time frame i went to start it up and had no power at all. No headlights, deck lights, dashlights. nothing at all. To everyone else, I have tried everything on this thread and nothing has been of use. The only thing i have not done is clean the terminal on the starter where the positive wire makes a connection. Rob did you ever figure out what your problem was? if so could you say how you fixed it?
Mousecop is offline   Reply With QuoteReply With Quote
Old 03-29-2013, 07:58 PM #10
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
Did you scrape and re bolt the grounds? These trucks are very picky about grounds
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 03-30-2013, 10:40 PM #11
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Fusible Link
The fusible link that RotaMan2 is talking about looks like this:
Ring terminal piggybacks on positive battery connector, on top of very thick starter wire. Thin, squarish copper plate goes inside fuse block.
Happy Easter!
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 06-30-2013, 12:59 AM #12
Ryanh15 Ryanh15 is offline
Ryanh15 is on a distinguished road
Was there an answer to this problem? I'm having the same issue with my 87 4runner.
Ryanh15 is offline   Reply With QuoteReply With Quote
dead , electrical , power
Absolutely cannot budge the upper ball joint (any ideas?) deedubb 4th Gen T4Rs 14 04-20-2011 05:41 PM
Absolutely Puzzled mr280zxt 3rd gen T4Rs 12 03-27-2011 11:23 PM
Added power ports to 1992, constant power surfcitylocal Classic T4Rs 4 07-21-2010 10:44 AM
Rear power window/ Power locks Brian Keeler 3rd gen T4Rs 2 06-01-2010 02:21 PM
Power windows, power door locks, sunroof, rear window ALL DEAD JAKE_S 3rd gen T4Rs 2 03-18-2009 12:30 PM
