Old 07-06-2011, 11:56 PM #1
jason in tn's Avatar
jason in tn jason in tn is offline
jason in tn is on a distinguished road
my 86 resto/buildup
just thought I would start out with some info and pics on my 86 I lost all my early pics so all I have is mid build to now but you will get the idea. the body on my runner was kinda beat rust in the quarters crused lower rear quarters etc so the body work has been a long prosses
still working on the body but its getting better, I have also rebuilt the 22re didnt have to do much machine work, I did replace the cam with a LCE rv style cam.
as you can see I have already painted the engine compartment to the new body color. I replaced the clutch with a luk/daikin heavy duty clutch,master and slave. other mods include bolted motor mounts, electric fan.
curently trying to work out a few bugs with the engine it ran but really rich while adjusting a few things now it wont start but Im just going to go back thru things till I figure it out.
next on the list is a v6 brake upgrade I already have most everything I need just waiting on that step. from there will be suspention, 1.5 ball joint spacers, new ball joints and ca bushings, idler arm still trying to decide on the rear suspention.then on to paint and apperance. I have started a few mods in that area
pickup truck tail gate swap
half top started.
well ther it is at this point let me know what you guys think. any ideas or suggetions are welcome.
jason in tn is offline   Reply With QuoteReply With Quote
Old 07-07-2011, 01:14 AM #2
T?@\7 T?@\7 is offline
T?@\7 is on a distinguished road
oh wow!
Im along for the ride
1987 dlx
SHAKKA
Originally Posted by SCRunner12 View Post
Where's T?@\7 at? He's always talking about bong rips in his posts. I thought he would be all over this post by now.
T?@\7 is offline   Reply With QuoteReply With Quote
Old 07-07-2011, 08:20 AM #3
Lil Red Yarder's Avatar
Lil Red Yarder Lil Red Yarder is offline
Lil Red Yarder is on a distinguished road
love the half top idea.
Lil Red Yarder is offline   Reply With QuoteReply With Quote
Old 07-07-2011, 09:59 AM #4
Originally Posted by T?@\7 View Post
oh wow!
haha thanks, with my job its been kind of a slow ride but its getting there. Im home for a few days and really hoping to figure out the not starting issue so I can move on to the front suspention and brakes.
Old 07-07-2011, 10:05 AM #5
thanks the half top is not an original idea of mine I seen a pic of one on another site and loved it, had a spare top that had been abused by its po and decided to give it a shot it needs some stiffening up around the back but I had to cut it to figure out what I would have to do to brace it up.
Old 07-07-2011, 02:04 PM #6
Nervo19's Avatar
Nervo19 Nervo19 is offline
Nervo19 is on a distinguished road
Nervo19's Avatar
It's good to see you here!
Nervo19 is offline   Reply With QuoteReply With Quote
Old 07-07-2011, 11:17 PM #7
hey nervo yeah I dont know why I didnt check this site out sooner thanks for checkin in.
Old 07-09-2011, 05:49 PM #8
need some help, I had it running but it was running really rich, in trying to figure that out it has gotten worse to the point it will not start, pulled the codes and got a 6 and 11 one is TPS the other is igniter. so I have changed the coil igniter assembly to a know working unit, changed the AFM to a known working part, checked for spark at plugs checked good, checked for fuel at the return line good stream while cranking, checked TPS checked ok, made sure dizzy was timed correctly. not sure where to go from here. the no start issue came after cleaning the AFM and throttle body. could really use some help, thanks in advance.
Old 07-10-2011, 12:55 PM #9
got it running its rough but running still not sure what the problem was, bad conection somewhere that for sure will come back to haunt me for sure.
Old 07-10-2011, 03:32 PM #10
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
Have you checked your 4 grounds on the motor? A bad ground could interfere with your ecu.
SV_Dude is offline   Reply With QuoteReply With Quote
Old 07-10-2011, 09:15 PM #11
that I need to do thank you, for some reason I keep over looking them.
Old 07-12-2012, 11:34 PM #12
wow its been a long time since Ive updated this sorry, the sad thing is it doesnt look a lot different LOL. Ive been working at it as much as I can but with the adition of my 97 runner i have had to spit my time, along the the purchase of the 97 came a change of plans for this project, I wheel my new runner and am really happy with how it performs so my direction for this one has turned into more of a restoration, I want to make it a nice clean dependable runner that I can dd and just enjoy that way. Im still not driveing but I did getting the running issues sorted out and have been focussing on body work mostly. ok so a few pics.
these pics were took not long after I intalled my b.j. spacers and did the zuk mod Im really happy with how it sits now.
the next few are of the doors getting jamed.
then came the underside of the hood.
the rest of the body should be coming along a lot quicker now, I decided to go back with the runner tail gate instead of the p/u gate that I had started to use, Im trying to put one together and should have it together soon.
A few other things Ive done, Installed mechanical oil presure and water temp gauges in my sr5 cluster.
this has been a painfully slow build up to this point but Im really hoping to make some big progress soon I really want to start driveing it and enjoying it rather than just working on it. thanks for checking in.
Old 07-13-2012, 09:27 PM #13
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
i guess i dont get it whats retro about it? not being rude i just dont understand.
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 07-14-2012, 12:52 AM #14
typo that I dont know how to fix I meant resto build as it is more of a stock build with a few mods. thanks for checking in.
Old 07-14-2012, 09:01 AM #15
RiFF RaFF's Avatar
RiFF RaFF RiFF RaFF is offline
RiFF RaFF is on a distinguished road
RiFF RaFF's Avatar
Did you get the rough running problems sorted out with the engine? If so - what was the cause(s)?
Also - "Slow and steady wins the race!"
Will be watching for more updates.
"People sometimes mistake their own shortcomings for those of society and to want to fix it because they don't know how to fix themselves."
Sir Isaac Asimov
Honey Badger Build Thread
RiFF RaFF is offline   Reply With QuoteReply With Quote
Chris' T4R Buildup chris360hawks 3rd gen T4Rs 92 03-24-2013 07:15 PM
1987 4Runner Rebuild/Resto Howitzer Classic T4Rs 2 09-07-2011 09:32 PM
Runner resto? vol4runner 3rd gen T4Rs 0 02-07-2011 02:12 PM
brush guard resto. jamr1 3rd gen T4Rs 5 09-05-2008 02:03 AM
resto pics 04 sc V8 Gallery 20 12-23-2007 11:40 AM
