Old 07-16-2011, 05:37 PM #1
ricoman's Avatar
ricoman ricoman is offline
ricoman is an unknown quantity at this point
ricoman's Avatar
thermostat or water pump
I have a 95 4runner with the v6 engine. I noticed coolant leaking in my driveway. I assumed it was the water pump but when I look at the manual, it look like it's coming from higher up where the thermostat is (the housing where the hose hooks up). The temperature guage hasn't really changed. Can I assume it's the thermostat? I'm just mediocre mechanical-wise so trouble shooting isn't my strong point and I don't want to start "fixing" things that aren't broke. Does changing the thermostat and putting in a new gasket sound like the right place to start? Or are there other things to check as well?
Thanks.
ricoman is offline   Reply With QuoteReply With Quote
Old 07-16-2011, 05:53 PM #2
blaniac22's Avatar
blaniac22 blaniac22 is offline
blaniac22 is on a distinguished road
blaniac22's Avatar
Typically, when I replace a water pump, I'll throw a new thermostat and gasket in anyway because I've already drained the coolant and it's easier to do so at that point.
So, if it looks like it's coming from there, I'd change it first and it's really nothing lost if it doesn't fix the problem. Make sure you check all the hoses and clamps. It may be blowing back from somewhere or running from a hose.
Honestly, I've never worked on that engine, so I'm not really familiar with it. I've changed out pumps, hoses and thermostats on other vehicles though. So, my advice is pretty generic. I'm sure someone will come along soon that can help more - but that's just my 2 cents.
2007 SR5 V6, Nautical Blue, 17in wheels, 35 Tint front, Toyota Hood Shield - Only mods for now.
blaniac22 is offline   Reply With QuoteReply With Quote
Old 07-16-2011, 06:13 PM #3
ricoman's Avatar
ricoman's Avatar
I've been looking at online parts for a thermostat. There seems to be several for the 3ve engine from 180 degrees to 195. How do I tell which one I need. I live in CT and winters are pretty bad here it that make a difference.
Old 07-16-2011, 06:35 PM #4
hoe_nah hoe_nah is offline
hoe_nah is on a distinguished road
how many miles does your truck have?
if its time to do a timing belt you should just tackle everything all one time
hoe_nah is offline   Reply With QuoteReply With Quote
Old 07-16-2011, 08:15 PM #5
ricoman's Avatar
ricoman's Avatar
I've only had the truck for about 3 yrs. It has 178k on it, but I believe the guy I bought it from said that he replaced the timing belt & head gasket just before I bought it with 158k on it. Anyway, that might be a little over my head skill-wise.
Old 07-16-2011, 09:43 PM #6
okay if you want to find the source of the leak do a coolant pressure test...it'll show were the coolant is coming from
Old 07-18-2011, 03:32 AM #7
Camokid84 Camokid84 is offline
Camokid84 is on a distinguished road
I work at a Toyota dealership and I mostly deal with newer vehicles, so I dont know if this advice applys to you situation but heres what I know. When a coolant leak is present you will see a coral looking crusty around the point of leaking. From what I understand between the heat, and the exposure to air causes this. Its an awesome way to find the source of the leak. Its a good idea to give the engine compartment a good look through, before throwing parts at it. You can do a radiator pressure test, but that only tells you that there IS a leak and not where it is.
Camokid84 is offline   Reply With QuoteReply With Quote
Old 07-18-2011, 02:45 PM #8
kzink's Avatar
kzink kzink is offline
kzink is on a distinguished road
kzink's Avatar
I had the same thing happen it looked like it was coming from the tstat but couldn't really tell because it's so clustered up down there and the tstat mounts onto the waterpump ended up being a leaking waterpump
kzink is offline   Reply With QuoteReply With Quote
Old 07-18-2011, 03:09 PM #9
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
I like this ideal. Find the leak and solve that issue before you start throwing parts at it.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 07-19-2011, 08:33 PM #10
true but if you suspect the thermostat then you can do the test and if you do lose pressure, just check the thermostat area as coolant will probably be dripping from the area...if not then you need to search a diff area
Old 03-18-2014, 04:19 PM #11
gnuorder gnuorder is offline
gnuorder is on a distinguished road
I think my 94 4runner has the same engine and I have the same problem. I replaced the tstat but it still leaks. I did notice one of the bolts was crusty and there was staining running down from that end of the tstat housing. I put anti seize on the bolts when I re-installed and that didn't make a difference. Could the housing itself be warped in either of our cases?
gnuorder is offline   Reply With QuoteReply With Quote
Old 03-18-2014, 05:02 PM #12
Footofgod's Avatar
Footofgod Footofgod is offline
Footofgod is on a distinguished road
Footofgod's Avatar
The 3.0 has as many coolant passages as it does vacuum hoses, that leak could actually be coming from several different spots in that area of the engine. Trust me, chased one for over a year. DO THE LEAK TEST! Be sure before you waste hours of time and hundreds of dollars trying to throw parts at it.
Originally Posted by dorton View Post
I wish I had a 2nd gen.
Originally Posted by BucknutBob View Post
I find myself wishing I had waited and picked up a 2nd Gen instead
Originally Posted by KidVermicious View Post
I want to convert my '85 to IFS.
Footofgod is offline   Reply With QuoteReply With Quote
Old 03-18-2014, 07:58 PM #13
Thought this thread was recent. Anyway, I can see the leak, just not where it's coming from. I don't think a leak test will help in my case. It's dark now but tomorrow I'll take the housing completely off and look at it. I'll also try and get a mirror down there. I'm thinking from other threads that it's the water pump seal.
Water Pump jojoford New Members 1 06-15-2011 03:43 PM
Help! New timing belt, water pump, and spark plugs = higher water temps??? vthokie 3rd gen T4Rs 15 05-16-2011 10:59 PM
thermostat/water pump gaskets freshley 3rd gen T4Rs 6 12-09-2010 05:34 AM
water pump superooster Classic T4Rs 3 02-11-2010 07:14 PM
water pump FCSCouto 3rd gen T4Rs 9 04-06-2005 12:25 PM
