Originally Posted by fourwd1
If one is from a 22R engine and the other is from a 22RE engine, you would have to swap the trans and t-case as a set.
If both engines are the same, the t-case or trans could be swapped separately.
I was concerned that the straight axle drive shaft on the 85' would not work on the 86' transfer case . My 85 has just developed a knocking sound in rev coming from the trans. it is not loud or binding but noticable. The vehicle i am getting parts from had a bad motor so I am hopping the trans mission is ok.
thanks for all of the input.
