Old 09-19-2017, 11:54 PM #106
4Reak Show's Avatar
4Reak Show's Avatar
Originally Posted by Shpakproof View Post
Thanks so much for the reply.
So what your saying is that by switching the 2 plugs vise versa should either put my actuator in normal (2wd) and then when I switch them it will be in 4wd? That would be the easiest fix ever! That never even crossed my mind and I will give it a shot!
And ya both the brake lines go from master cylinder to passenger wheel well, and then go to a "T" type fitting, from there I have 2 lines that go to front brakes, one off either T. And then I have 2 lines that twin side by side along frame towards rear, then jog up over fuel tank (super corrosion) and then drop back down and go to separate "actuators?" you could say all this is hard piped in soft copper, which then goes from these final devices to the rear brakes. Idk why so complicated of a braking system.
Well I'm assuming your transfer case is working mechanically but electrically is NOT changing your solenoids. So it keeps the 2wd one energized no matter what. Problem is, if the 4wd IS switching power between vacuum valves properly then this won't work alone. You'd have to also switch the OUTPUT vacuum lines between them. (which would actually be a test to see if solenoid is frozen. Which could be your whole deal). Does that make sense? Pop the hood, switch the electrical and see what happens. It's not going to hurt anything. But for diagnostics you gotta start somewhere. Just mark stuff or take pictures before you start yanking on things hahah
As for brakes, I'll see if I can trace mine back soon. I should be back underneath it this week anyway. In the meantime, try and take a few pictures as best you can.
Old 09-21-2017, 10:43 AM #107
Shpakproof Shpakproof is offline
Shpakproof is on a distinguished road
Thanks so much for the info, when I get back home this weekend I will try it out. And I'll take some pics of the brakes as well.
Shpakproof is offline   Reply With QuoteReply With Quote
Old 12-13-2017, 08:01 PM #108
2lokey 2lokey is offline
2lokey is on a distinguished road
Q u e s t i o n
HI!
1990 22RE 4RUNNER
I swapped out the stock radiator for a CSF 2314 3-row.
(OEM one was crumbling to pieces)
It bolted in just fine but the stock fan shroud doesn't fit (too large).
anyone know which fan shroud will fit the CSF 2314 ?
1st gen T4R?
pickups?
Couldn't find anything about shroud fitment for these CSFs
2lokey is offline   Reply With QuoteReply With Quote
Old 02-18-2018, 05:28 PM #109
Pockets907's Avatar
Pockets907 Pockets907 is offline
Pockets907 is on a distinguished road
Pockets907's Avatar
Anyone happen to know what the wheel offset of a Gen 2 4Runner is?
Pockets907 is offline   Reply With QuoteReply With Quote
Old 03-03-2018, 10:57 AM #110
jmtigerfan jmtigerfan is offline
jmtigerfan is on a distinguished road
Found the FSM
Thanks SV Dude, found the FSM I needed for the 3VZ-E I needed at this link.
https://docs.google.com/folderview?i...S1Xdk5BWXdrY0k
jmtigerfan is offline   Reply With QuoteReply With Quote
Old 03-19-2018, 10:40 AM #111
Blind Cleric Blind Cleric is offline
Blind Cleric is on a distinguished road
I've read 8mm. Do you mean backspacing, by chance? That would be 4.75
Blind Cleric is offline   Reply With QuoteReply With Quote
Old 04-24-2018, 09:35 PM #112
Lemons87 Lemons87 is offline
Lemons87 is on a distinguished road
I have a 1995 4runner with the 3vze. I had a code 52 so i replaced the knock sensor and wire. The code is still there along with the CEL. Both pigtail and sensor replaced with brand new parts. Anyone have any clues as to what it could be. ECU maybe? Vacume leak possibly. Im at a loss
Sent from my SAMSUNG-SM-G930A using Tapatalk
Lemons87 is offline   Reply With QuoteReply With Quote
Old 04-24-2018, 09:43 PM #113
4RunnerAquasport's Avatar
4RunnerAquasport 4RunnerAquasport is online now
Real Name: Brett
4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of 4RunnerAquasport has much to be proud of
Real Name: Brett
I personally have no experience with the 3vze, but here is a quick search I did on the Yota tech page if you haven't seen that forum yet.
https://www.yotatech.com/forums/f116...sensor-184480/
1988 DLX 22RE AUTO BLACK-"Granny" - SOLD
2003 SR5 SPORT V8- Build- "Pearl" You Tube 2UZ 120
2012 LIMITED V6 "LE Mae" 5TH GEN BUILD THREAD
4RunnerAquasport is online now   Reply With QuoteReply With Quote
Old 04-24-2018, 10:12 PM #114
Thanks i have some more tests to run in the coming days after reading that thread. Ill do the resistance tests first being i have everything to do that already. If that all checks out ill try and get another ecu and go that route. Thanks
Old 04-24-2018, 10:30 PM #115
Real Name: Brett
Real Name: Brett
This might help if you haven't seen it:
Here is a way to search google for all related threads on that topic, as one thread might not have your situation exactly.
When I type this into the regular google search bar in your browser, several different threads pop up. Hopefully there is something in all of those that will help. Once I found this way of searching, I think it opens up more related pages.
So when you type in your question, put in
site:yotatech.com/
after your question or key word and it seems to work better. Good Luck!
Example:
code 52 knock sensor 3vze site:yotatech.com/
This is the page that pops up from google.
https://www.google.com/search?source....0.7orUaNYlLbs
Old 05-08-2018, 03:23 PM #116
xmindbender xmindbender is offline
xmindbender is on a distinguished road
good info
xmindbender is offline   Reply With QuoteReply With Quote
Old 05-10-2018, 10:29 PM #117
Nesseralla Nesseralla is offline
Nesseralla is on a distinguished road
Unhappy Help
I got a stock 4Runner from my bestfriend that passed away on June 4th 2017 so I’m doing everything he wanted To do to it but he was in the middle of putting a tranny in it and it’s a 95 he was putting a 97 in it but what I hured that they don’t work for other years so I got a parts truck and the tranny still won’t shift outta first gear even if I drop it In low and try shifting it but it won’t and I need help ASAP cause I’m trying to get it to his memorial the parts truck ran and drove fine but it won’t now
Nesseralla is offline   Reply With QuoteReply With Quote
Old 05-10-2018, 10:43 PM #118
4Reak Show's Avatar
4Reak Show's Avatar
Need more info. If you're trying to put a 97 trans into a 95 4Runner it won't work. Totally different. Different generations even.
Old 05-10-2018, 10:46 PM #119
I got a 95 parts truck and pulled the 2wd out of it and put it into My 95 4wd just won’t shift the 97 4wd did the same thing u help me out or someone can I’ll send them some cash
Old 05-13-2018, 07:08 PM #120
JAY4R's Avatar
JAY4R JAY4R is offline
JAY4R is on a distinguished road
JAY4R's Avatar
1st post - my ride.
85 DD
199K and some change
Not sure why all my pics upload upside down.. any suggestions?
1st & 2nd gen 4-runner tech (factory service manual and common fixes)-img_4034-jpg
JAY4R is offline   Reply With QuoteReply With Quote
Free 2003 & 2006 4-Runner factory service manual Sidney Classic T4Rs 4 01-29-2018 09:16 PM
Factory Service Manual 98stellarrunner 3rd gen T4Rs 0 07-29-2013 12:14 PM
Tech Help With a Service Manual! GalenMalek General Discussions 1 01-22-2013 03:51 PM
Factory Service Manual o11o1o1 Maintenance/Detailing 2 06-02-2009 07:30 PM
FSM - Factory Service Manual anyone? Hank 4th Gen T4Rs 15 11-29-2004 02:25 PM
