fuel injectors will wear out so that that squirt gas instead of mist gas (not the technical terms but you get the idea) Or they could be clogged up. My guess is that if someone already went to the trouble of messing with the computer for the injectors, they already tried cleaning out the fuel system, but you never know. I'm not sure if you could adjust them or not, it depends on what is wrong with them really.
You might have to replace them which would be the most expensive repalcement between everything I suggested you check. I don't know much about fuel injectors. More of a carb person.
I would consult someone else on this matter, or you could just replace them.
