I'm moving on to a LT Tacoma so it's time to sell my 4Runner. There's a lot of money in it so I'm asking for $11,000. I just wanna get rid of it quickly because I already have a deal lined up for a Tacoma, so message me if your interested.
1996 Toyota 4Runner SR5
Perfect A/C And Heat
Power Windows And Locks
Rear Power Window
4 Speed Automatic With Overdrive
4WD
3.4L V6 With 98k Miles On Rebuilt Motor (
The Carfax Says That The Odometer Isn't Correct And That's Because The Aftermarket Gauge Doesn't Show the Correct Mileage, It Was Correct Until March Of 2009 When It Was Registered With The New Gauge That Didn't Have The Correct Mileage)
Here's the list of mods:
-Old Man Emu 3" Lift (6 Months Old)
-Camburg Upper Control Arms (2 Months Old)
-Newer 33x12.5x16 General Grabber Tires
-Axis Regulator Wheels
-LED Tail Lights
-Glassworks Unlimited Fiberglass Fenders
-Upgraded Kenwood Excelon Speakers All Around
-Custom Fold Down Roof Mounted Light Rack With 5 Hella Lights (2 Outside Lights Are Wired Up, Other 3 Just Need To Be Wired Up And They're Good To Go) (I May Wire The Last 3 Up But I Don't Want Them Killing The Battery)
-Lots Of New Front End Suspension Components (They Were Just Worn Out So A Lot Of It Was Replaced) (I Have Receipts For All The Work That Was Done, It's Over $1000)
-Airaid Throttle Body Spacer
-Sparco Bucket Seats With Harnesses
-New Master Brake Cylinder (Just Wore Out So I Took Care Of It Immediately)
-Full Professionally Built Race Ready Roll Cage (Set Up For Two Bucket Seats And Harnesses In The Back)
-Grant Racing Steering Wheel
-Custom Front And Rear Tube Bumpers (With Tow Points And 2 Light Holders On The Front)
-Tow Package With Receiver
-Skid Plates
-Custom Exhaust (Sounds Great)
-Tacoma Front End Conversion (Grill, Headlights And Hood With Sparco Hood Pins)
-Airaid Cold Air Intake
-Custom Mounted Axe And Shovel In Back
-Automate Security System With Remote Start
-Custom Dash (Digital Speedometer, RPM, Water Temperature, Oil Pressure And Fuel Gauges)
I may have forgotten some things because there's a lot to remember but that's everything for the most part. There's a few things that aren't in perfect condition on this truck but it doesn't affect it all. The front right fender is damaged, the hood is slightly bent, the grill and headlights have a lot of broken clips so they're zip tied and the paint has desert pin stripping in the clear coat. Those are all cosmetic problems though and if you are gonna use this truck for offroading then there is no need to even fix them. They don't cause any problems and by no means are they horribly noticeable. I will fix the grill, headlights, and hood(maybe with a scoop?) for the right price. I feel I've priced it fairly because the KBB is $5,500 which means your only paying $5,500 for everything extra that's been done to it. If you have any questions feel free to ask.
I'm in AZ but I may deliver to other states if the price is right..
Sorry that it's a little dirty in the pictures. It will be cleaned up nice and pretty for anyone that's interested. Alot of the wires you see poking out from under the dash aren't there anymore. They were from the old radio and it's all gone now.
