02-18-2011, 01:34 AM
FS: 3rd gen 4runner front ToyTec lift spacers
The spacers are the TAC25 2.5" spacers that sit on top of the front coils.
I no longer need them since I installed Tundra TRD coils in the front of my 4Runner.
They are in great shape and need a new home.
They are normally $119.99 but you can have them for $60 shipped.
Add the top plate spacer kit TOP1-T from ToyTec and you have a 3" lift.
Thanks.
99 4Runner Ltd 4x4, 3.4 V6, Gen 1 TRD supercharger, URD fuel kit w/ 2.2 pulley, IPT VB trans upgrade, Hayden 1679 tranny cooler, Dual Exhaust from muffler back, Deckplate w/Amsoil filter, Air Raid Intake, Lotek dual gauge pod with Boost and Tranny temp gauges, TRD Tundra Front Coil Lift w/Tundra Bilsteins, OME 891's rear with Monroe air shocks, ARB Sahara front bumper w/IPT fogs, MM 9500# winch, 285x75R16's Maxxis Bighorn Radials on Ivan Stewart TRD wheels, and front Clear corners. - SOLD
02-21-2011, 11:59 PM
Pics of the spacers.... $60 shipped.
I washed them since I took them off my 4Runner, but they could be polished up or run them as is.
Let me know.
Thanks.
03-25-2011, 03:22 AM
Bump....Still available...
04-05-2011, 02:24 PM
$50 shipped now
04-05-2011, 07:50 PM
do you have the top plate to net 3''?
2003 Nissan 350z Track/Autocross
2014 4runner SR5
04-05-2011, 10:39 PM
No I don't. I reused them on my tundra coils, otherwise I'd sell them for a more money if it included the top plates and bolts.
04-05-2011, 11:51 PM
-- removed by admin --
84' Honda Interceptor 1000 -=|=- 86' 4runner 22re (7mge soon) -=|=- 85' 4runner Shell for sale -=|=- 87' MR2 MK1 4age
04-07-2011, 12:04 AM
The spacers are fine as is for 2.5" of lift. The top 1/4" spacers are only to get that extra 1/2" of lift.
I decided to rip the tile out and do something else, so I didn't bother grouting it.
04-07-2011, 12:06 AM
04-07-2011, 04:18 PM
The longer bolts are only for adding top plate spacers. You have to remove the stock bolts and then use longer bolts with the factory top plate and the top plate spacers.
So as these are, you just reuse your factory bolts and top plate. You have to compress the spring and add these spacers to the top of your spring and then put the top plate and rubber gasket parts back on top of that and bolt it all together again.
04-07-2011, 10:15 PM
04-07-2011, 11:05 PM
Nope stock struts is all I've had on my 4Runner.
04-07-2011, 11:10 PM
