Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 03-28-2009, 07:59 AM #1
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Checklist for Delivery of New Car
Hey all,
I found this useful (a bit anal) checklist on an Acura forum i visit:
Instructions
So you bought a new car and it's ready for you to pick up and drive off the lot. We know you're excited to get on the road, but it is important not to rush the delivery process. Below you'll find some general guidelines and a checklist for you to print out and use the day you pick up your new baby.
-- Call the salesperson ahead of time and let them know that you plan to perform a delivery check during daylight hours. Make an appointment -- getting through your checklist may take more than an hour.
-- Tell the salesperson that you don't want any dealer nameplates affixed to the vehicle in any way (painted, riveted, or adhesive bonded). The license plate holder is okay. Ask that the vehicle's plates remain the dealer's until after you've taken delivery.
1. Note the mileage. Before you do anything else, look at the odometer. It should be as close to zero as possible. After all, you're paying for a brand-new car. And that's exactly what you should get. But there's more than principle involved. The first few hundred miles on a fresh engine are critical if you want it to have a long, trouble-free life. Most manufacturers specify certain procedures during this break-in period; i.e., "Avoid full-throttle acceleration and excessive engine speeds," says one automaker. Unless you buy one that's just rolled off the delivery truck, most brand-new vehicles will have 10 or 20 miles on the clock - miles accumulated from shuffling the truck around the dealership, or from a few test drives. What you don't want is a car with 100 or 200 miles that's been a demonstrator vehicle to every lead-footed prospective buyer in town.
2. Look over the bodywork. Do it in the daylight. And it helps to have an eagle-eyed friend or relative along; four eyes are better than two. Again, you're buying a new car and you should expect a perfect finish. Take the car for a test drive with the dealership's plates installed on the car. The Uniform Commercial Code allows a reasonable opportunity to inspect goods before accepting delivery.
a. Carefully sight along the sides of the car, from front to rear and vice versa, looking for ripples, dimples and dings. Light scratches can be buffed out easily enough. But you certainly don't want a car that's had any repaired body damage.
b. Look for paint over-spray on door ledges or around the edges of the engine compartment that might indicate repairs. Make sure there are no paint swirls from dealer detailing.
c. Make sure seams and door lines are straight and true. Remember, a careful inspection is critical because after the car leaves the lot, the dealer could reasonably claim that any body damage was caused by you.
d. Are the trim, rubstrips, decals, chrome, hood ornaments, and other exterior features present, in good shape (defect-free), and properly attached?
3. Operate and inspect every item on the car:
a. Doors: Do they all work correctly? Do they seal properly?
b. Cruise control
c. Horn
d. Wipers
e. Do the locks work properly -- are they automatic, can they be operated remotely?
f. Does the hood release lever operate from the inside? Do you know the location? Can you open the hood yourself? Does it stay up on its own?
g. Is the engine compartment in perfect shape?
h. Is every dip stick, plastic cover, and wire harness present and properly secured?
i. All the fluids should be at optimal levels: oil, transmission, power steering, brake, windshield wash, and coolant.
j. There should be very little dirt and grime, and not a single sign of fluid leakage of any kind.
k. None of the engine components should show exterior wear or replacement -- things like one spark plug wire that is a completely different shade of black should draw a red flag and a question. They should replace them all with new items if that means you'll drive the vehicle away.
l. Battery: Is it filled properly? Or is it a "no-service" type? (Check the level or sight dot.) No corrosion should be present on the electrodes. It should be properly connected -- fastened to wire leads and properly secured -- tied down in the vehicle. 0 Ask about how to jump it properly. 0 Does it have a special separate warranty?
m. Is the trunk in perfect shape?
i. Is the carpeting properly fastened?
ii. Do the lights work correctly?
iii. Does the internal opening button work correctly?
iv. How about the outside lock?
v. If it has gas shocks to hold up the lid, are they working properly?
vi. Are the extras, such as cargo nets or trunk tray, present as you ordered?
n. Fuel System:
i. Which side is the filler door on?
ii. Can you open it from inside the vehicle?
iii. Does it lock?
iv. What grade of gasoline does the manufacturer recommend?
v. How big is the tank?
vi. At what level does the fuel gauge on the dash register? (Many dealers
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 03-28-2009, 10:21 AM #2
captdbg captdbg is offline
Location: Puerto Vallarta,Mexico/South Padre Island Texas
captdbg is an unknown quantity at this point
Check your date of purchase on the contract.I bought mine on March 02 after looking at the contract last week it was dated February 26.Dealer said don't worry about it WE will take care of you (right) after talking with toyota they said its a issue with the dealer? I feel i am screw out of 4 days of warranty. Good thing its a toyota
Danny B
08' Toyota 4Runner Titanium Urban Runner 4x4 Moon Roof Sirius Satellite Radio I Pod Interface INNO Surf Racks Weather Tech Floor Mats SeatShield Waterproof Seat Covers Westin Grill Guard & Hitch Safe
captdbg is offline   Reply With QuoteReply With Quote
Old 03-28-2009, 12:03 PM #3
Atlanta_man's Avatar
Atlanta_man Atlanta_man is offline
Atlanta_man is on a distinguished road
VIN number is important long before actual delivery
step one is to be sure the paperwork you sign has the right VIN number on it
just one of the tricks bad dealers will use on you in case you balk at a price increase late in the deal
Bill Heard (not a Toyota dealer) was notorious for changing the paperwork after you take delivery even if you had it in order. Good riddance to those bankrupt guys.
was: 2005 2wd V8 Limited, one owner (me), 155K miles
now: 2019 Kia Sorento SXL V6
Atlanta_man is offline   Reply With QuoteReply With Quote
Old 04-01-2009, 12:55 AM #4
thetaxguy's Avatar
thetaxguy thetaxguy is offline
thetaxguy is an unknown quantity at this point
thetaxguy's Avatar
Please explain.
-Shawn | 2010 Xterra - 4X4 "The Panda #2." Aka, "The #2."
--------| 2008 BW UR - 2WD "The Panda" (Sold)
SoCal 2WD Trail runs: http://www.toyota-4runner.org/so-cal...tml#post537475
4th Gen Stuff for Sale: http://www.toyota-4runner.org/classi...tuff-sale.html
thetaxguy is offline   Reply With QuoteReply With Quote
Old 06-16-2009, 08:30 PM #5
riverider riverider is offline
Banned
riverider is an unknown quantity at this point
Banned
Ha!!! Ha!!! Ha!!! burp!!! Yeah Baby. :awais:
riverider is offline   Reply With QuoteReply With Quote
Old 06-16-2009, 08:31 PM #6
banker1 banker1 is offline
banker1 is on a distinguished road
Originally posted by thetaxguy
Please explain.
x2 please :awais:
07 4Runner Sport
Shadow Mica, V6, Nav
banker1 is offline   Reply With QuoteReply With Quote
Old 02-03-2011, 02:57 AM #7
surfratsteve surfratsteve is offline
surfratsteve is on a distinguished road
Awesome...
This is great. I'm actually picking my new baby up tomorrow!!!
Thank you.
surfratsteve is offline   Reply With QuoteReply With Quote
Old 03-01-2011, 04:59 PM #8
JenDoh JenDoh is offline
JenDoh is on a distinguished road
Great stuff, picking mine up today! Printing this list out to take with me!
Thanks so much!
Biggest Mod: turned a 2006 Honda Element into a 2011 Toyota 4Runner.
JenDoh is offline   Reply With QuoteReply With Quote
Old 12-07-2015, 01:00 PM #9
BYEOFCR BYEOFCR is offline
BYEOFCR is on a distinguished road
This is great! I hope to be at the dealer when my rig is pulled off of the car hauler. Yeah, I will be that guy, taking pictures of the new ride as it comes off of the truck.
BYEOFCR is offline   Reply With QuoteReply With Quote
Old 05-13-2016, 12:43 PM #10
RWBlue01 RWBlue01 is offline
RWBlue01 is on a distinguished road
Thank you, this helps
RWBlue01 is offline   Reply With QuoteReply With Quote
Old 04-19-2017, 09:43 PM #11
ziababar ziababar is offline
ziababar is on a distinguished road
They were just meeting feb quotas but still not a legit move
ziababar is offline   Reply With QuoteReply With Quote
Old 10-03-2018, 07:53 AM #12
Montego Murph's Avatar
Montego Murph Montego Murph is offline
Montego Murph will become famous soon enough Montego Murph will become famous soon enough
Originally Posted by thetaxguy View Post
Please explain.
I know it's an old thread, but since nobody explained, I will:
Let's say you go test drive a brand new 4Runner. Bright red limited edition. You love it, everyone's happy, and you want to buy it. As the sale progresses, you become the customer from hell from the dealership's point of view. Not happy with the pricing, playing hardball, not falling for the "4-square" and "up to" nonsense, and you've kept them there past closing. It's late, they want you out of there, but they also want the sale. Sales manager says "Fine, we'll go with that price. Let's do it" and sends you home in a bright red SR5 or Sport edition, or maybe swaps you into the red Limited that was used as a demo with 1500 miles on it.
This actually happened to an ex-GF of mine years ago with a Mitsubishi Eclipse. She was the customer the sales staff always saw coming, and could get her into a new car at oil change time just by saying "you know, you've got nearly 25,000 miles on this old car. This is when things start nickel and diming you," and she would freak out and trade it in.
Anyway, she went in and test drove a top-of-the-line Eclipse with all the bells and whistles, made a deal based on those numbers, and drove home in what I called the "rental edition" with plastic hubcaps and "a premium CD player stereo that they threw in for free. Those guys are so nice!" She didn't even realize what happened until the first big rainstorm and she couldn't find the switch for the rear wiper (which was something she liked about the car she test drove.) "Sorry, nothing we can do, this is the car on your paperwork."
Montego Murph is offline   Reply With QuoteReply With Quote
