Ft. Drum
I used to be stationed @ Ft. Drum 1989 -1991. It gets very cold but not cold enough to have an engine block heater. Just change your oils according to the seasons. But you will definitely benefit from the 4WD as I had a 4WD Jeep Cherokee. I was with 3/25 aviation brigade, Huey crewchief/ door gunner.
-04 4runner, V8, NAV, Limited, 4WD, Galactic Grey.
-Revtek 3" front lift, 2.5" rear.
-1.5" Fred Goesk Wheel spacers.
-265/70/17 BFG A/T KO.
-Cabin filter modification.
-Silverstars all around.
-Relocated 115volt inverter outlet.
-Modified DRL/ fogligts switches.
-TRD airfilter, modified intake.
-Hella super tone horns installed.
-Toyota dual power outlet installed.
