Originally posted by blaine965
With regards to the Eclipse unit....is this as simple as swapping out my factory head unit with the Eclipse unit or is there more to it? I am not partial to XM it is just what I had previously. Sirius would be sufficient.
Do you have to purchase the head unit and then a seperate tuner for the sirius or is at all built in? Since the Eclipse unit is Sirius compatible does that mean it is integrated on the NAV screen?
I would be easier to swap out the factory 4Runner nav for a Factory Camery/Solara NAV. It is basically the same unit as the Eclipse... and it is Toyota's 4th Generation NAV (vs. the 3rd Generation that came with your 4Runner. And... the 4th Generation NAV supports XM (just buy a factory XM kit from toyota and you are good to go.)
