Old 07-30-2013, 04:53 PM #31
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
Originally Posted by JB. View Post
That could be a problem because it, too, requires reading.
But this thread isn't really about any "solution" to LT tire pressure because there is no single answer. However, for set and forget simplicity, it's hard to go wrong with simply matching factory load reserve.
This thread was simply intended to make known a non-intuitive fact about the load carrying differences between P and LT tires. Since it's a non-intuitive fact that has been shown over time to not stick easily, I attempted to make it easier by making it visual.
What people do with the information is a separate subject, but it's information worth knowing.
I for one appreciate your thread on LT tires. I have learned quite a bit from your link to the tire engineer and your posts and as I am getting old it's tough to teach me new things lol. Thanks!
1engineer is offline   Reply With QuoteReply With Quote
Old 07-30-2013, 04:56 PM #32
Canazes9's Avatar
Canazes9 Canazes9 is offline
Real Name: David
Canazes9 is on a distinguished road
Canazes9's Avatar
Real Name: David
Excellent information presented. Glad you posted the graphs so the data is preserved if the links eventually go dead.
Thanks,
David
Canazes9 is offline   Reply With QuoteReply With Quote
Old 07-30-2013, 07:02 PM #33
scanny's Avatar
scanny scanny is offline
scanny will become famous soon enough
scanny's Avatar
That's what I completely agree with.
Good info and it's up to people what to do with it : )
2022 4Runner TRD Off Road, Lunar Rock
Goodyear Wrangler Duratracs
scanny is offline   Reply With QuoteReply With Quote
Old 12-09-2014, 04:54 PM #34
dirtysparks dirtysparks is offline
dirtysparks is on a distinguished road
Crossposting for visibility from my other thread. 265/70/17 C load.
I'm not understanding this footprint for LT load range tire here. I know to get the same load rating as stock I need to be at 44psi, but this doesn't look right to me. Shouldn't I have even wear all the way across to the end of the lugs?
The first pic is my chalk test at 40psi.
The second is my tire footprint on a dirty paved road at 44 psi. You can see an inch or so on each side that has no contact.
Now, I think I get a fairy flat footprint at 38 psi (no pic), but I feel like that's a little low + it ends up driving a little wiggly and loose.
LT tires need more air pressure.-photo-dec-08-5-11-07-pm-jpg  LT tires need more air pressure.-photo-dec-09-1-26-30-pm-jpg
dirtysparks is offline   Reply With QuoteReply With Quote
Old 12-09-2014, 05:28 PM #35
scanny's Avatar
scanny's Avatar
On mine LT C load I keep around 36psi for the past 3 years (80,000km /50,000 miles) with no issues. No trying get stock load rating though, simply using Gross Axle Weight Ratings as per manual.
Old 12-09-2014, 05:42 PM #36
Thanks, I was driving at 35 psi for awhile which prompted me to make a thread on why my 4R was so touchy on the highway. I found that pressure to affect my ride negatively on the highway. Bumping the pressure up really helped stability. My main concern now is traction and safety through the winter.
Old 12-09-2014, 08:18 PM #37
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
For your sanity, forget the chalk test.
Just monitor wear, it works much better. It's a direct indicator that utilizes time and takes driving habits into account. Any possible sub-optimum wear will happen so slowly that you'll have plenty of time to make any psi adjustments if you rotate normally, but adjustments probably won't be necessary.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 12-10-2014, 11:10 AM #38
Thanks for the reply.
So is it possible that driving at 35 psi for the first 5K miles has worn the outer edges to the point that at proper psi would leave the edges of the treadblocks with minimal contact? It doesn't seem like it would wear that fast - i'll have to get out the tread depth guage and check. I'm having a hard time looking at the dirt pattern on the tire and thinking I'm getting the best traction/footprint possible.
At 44 psi, it rides great, handles fine and has good road manners. BUT now that winter is here, I don't want to be rolling down the snow and ice on a doughnut shape that doesn't utlize all the tread. I'm sure after driving enough the center will wear and the outer edges will start to make contact.
I'm also not quite sure how to monitor for sub optimum wear.
Old 12-10-2014, 06:03 PM #39
JB.'s Avatar
JB. JB. is offline
JB. JB. is offline
JB.'s Avatar
If you want to play around with all this, that's fine.
If you'd like to be done with it, just pick the psi that gives you the handling you want (since you're in a reasonable psi range) and then pay attention to the wear at whatever interval makes you comfortable (not going longer than rotation schedule). To track the wear over time, pick two or three spots on the tire and take a few guage measurements to establish a consistent reading and note the readings and measurement location. Pictures make it easy to keep track.
Within a reasonable psi range, the tread wear effect due solely to pressure is very subtle and the evenness of the wear over time will be dominated by driving conditions, so trying to take care of it up front with a chalk test is not very useful.
As for the winter footprint, the difference in footprint coverage between 38 and 44 psi would be very small, and the slightly more concentrated ground pressure at 44psi might well give you better winter road performance.
2005 Limited V8
5th gen SR5 springs
Hanna sliders
Old 03-12-2015, 01:44 PM #40
jicko jicko is offline
jicko is on a distinguished road
So, what pressure should I be running LT265/70R17 BFG TA KO2 on stock 2015 SR5P here in San Diego?
35?
44?
jicko is offline   Reply With QuoteReply With Quote
Old 03-12-2015, 11:01 PM #41
mo_mo mo_mo is offline
mo_mo has a spectacular aura about mo_mo has a spectacular aura about
35?
44?
What did the shop set them at?
Since that tire comes in both C and E Ranges with different load indexes, then somewhere between 34.8 and 52.2
***bad math with no idea what I'm doing below***
Using the Toyota axle weight / 2 method:
C Range (Load Index 112) = 34.8
E Range (Load Index 116) = 43.1
Using the Toyota stock P load scaling method:
C range = 42.2
E Range = 52.2
Let us know what you find works best for you.
FYI: I'm getting LT265/70R17 C Range Load Index 112 Duratracs installed and plan on running 42 psi to start. I might drop them down and then crank them back up depending upon how they break-in.
2014 T4R TE Nav KDSS Super White
Demello Hybrid Bolt On Sliders | Toyo Open Country AT III LT285/70R17 C | Ironman 4x4 Foam Cell Pro Stage 2 | Durobumps | Rago Molle Panels | Leather steering wheel cover | RCI Full Skids (Aluminum) | Drawer less drawer system and sleeping platform. | TRD CAI | RAV4 Sideview Mirrors: 87961-42D20 & 87931-42D50 | Blackvue DR650S-2CH | Cobra 75 WX ST with 4’ Firestik + Magnet Roof Top Mount | MXT275 Midland GMRS radio | 3M Crystalline: Front CR70, A-B CR50, B-Aft CR40 | RRW Leather Seat Covers w/Besond Seat Heaters| 3DMax Floor Mats and Rear Husky Liner | former LT265/70R17 C Duratracs
mo_mo is offline   Reply With QuoteReply With Quote
Old 08-14-2015, 08:01 AM #42
2GOFAST 2GOFAST is offline
2GOFAST is on a distinguished road
thanks for the info
2GOFAST is offline   Reply With QuoteReply With Quote
Old 09-12-2015, 04:16 AM #43
freeflight freeflight is offline
freeflight is on a distinguished road
Nice work, tagged
2004 4Runner, 4WD, V6
freeflight is offline   Reply With QuoteReply With Quote
Old 09-12-2015, 04:30 PM #44
35?
44?
Discount tires set them at 40psi.
I am currently running 45psi, after starting at 44 (prorated from the pressure of P tires), and going +/-1, +/-2 etc.. testing.... and finding that 45psi runs the best for me.
2015 SR5 Premium 4x4 / 3rd row seat
Jicko's Build & Adventure Thread
"Group buy, anyone?"
Old 09-13-2015, 03:13 AM #45
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Maybe I missed it while skimming this thread, but I didn't see any mention of the fact that a P-metric rated tire's load carrying capacity, is derated by a factor of 1.10 (approx. 9%) when used in a Van, Pick up, or SUV application. As required by Federal Motor Vehicle Safety Standards.
So when looking at a load inflation table for a P-metric tire, reduce the load carrying capacity of the tire by a factor of 1.10, to arrive at the true load carrying capacity in a Van, Pick up, or SUV application, for a given inflation PSI.
02SE is offline   Reply With QuoteReply With Quote
light truck , load range , load rating , passenger , ply rating
HTML code is Off
What tire pressure do you run in your stock size tires??? Jeff T 4th Gen T4Rs 2 07-27-2011 08:00 AM
What Tire Pressure do you run on your Stock Tires? New03formeh Polls 4 06-25-2008 09:29 AM
Got new tires and low pressure warning light will not go out arouth 4th Gen T4Rs 29 11-14-2006 06:23 AM
Tires pressure desertrat Classic T4Rs 3 06-12-2006 04:13 PM
New tires and tire pressure system issues Duc Hunter 4th Gen T4Rs 4 05-25-2005 03:11 AM
