Old 03-08-2012, 06:08 AM #1
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
LT tires need more air pressure.
...to match the load capacity of a P-metric tire.*
*A Standard Load tire (SL), usually P-metric (or metric, euro-metric -- a nearly identical twin). This is the tire found on nearly every new car, SUV, and Light Truck. On the sidewall it looks like P265/70/17 (or 265/70/17) as opposed to LT265/70/17.
How much more pressure?
  • 10-15lbs, if an LT is switched for a P-metric tire with the same dimensions.
  • LT load range (C,D,E) doesn't affect this.
  • Tire size does.
This continues to come up and is often a source of confusion.
Not surprising though, considering that both of the following statements are true:
LTs carry less load than P-metric.
LTs carry more load than P-metric.
Throw Load Range into the discussion and things get nice and tangled. Describing the relationships in words doesn't paint a clear picture so I thought I'd try to make some -- pictures, that is.
The charts are based on tire size 265/70/17 and, in the 2nd chart, how it relates to the 5th gen 4Runner because that proved easiest, but the application to other generations is obvious and not too dissimilar. The curves should be reasonably accurate and more than good enough to illustrate the point. P-metric tires get load capacity de-rated 9% when used on an SUV and the curves reflect that. The tables used for reference come from this.
Hopefully it's easy to see how an LT can carry both less and more load than P-metric. It's all about air pressure and, for this tire size, it takes about 12psi added to the LT to match the load capacity of the P-metric tire. Hopefully it's also clear how pretty much the only distinction that matters is between P and LT. Load Range doesn't meaningfully affect the choice of air pressure for LT -- unless very high pressures are desired -- since the the longer load E curve is overlapped by the shorter D and C curves.There may, however, be implications for speed capability in the selection of load range. See Baldwin here.
Extending the line for LT down past where it ends (because load tables stop there) in this chart might seem to imply that making a pressure adjustment when switching to LT isn't important since it appears there would still be load reserve at 32psi even if no additional pressure was added, but that doesn't mean there's no benefit to adding more pressure (leaving it at 32 would be the equivalent of around 20psi in the stock tire). For one thing, the curve bends more as it goes down the chart towards zero psi, so calculating it as a straight line overestimates load capacity. Secondly, having plenty of load reserve is desirable since tires change over time -- and they don't get stronger. Lower pressures result in more heat which speeds the process. The cumulative effects of dynamic loading, speed, heat, age, hard use -- not to mention the inevitably lower speed rating in an LT -- are all good reasons the load reserve established by the factory tire at recommended pressure should be given due consideration. If nothing else, the level where the tpms triggers should be a good clue to that. Most of this is covered in the doc already linked. There is also the option to Ask a tire engineer - Toyota 4Runner Forum - Largest 4Runner Forum. The horizontal lines on the P-metric tires represent the ability to add pressure for special conditions (like high speed) but the extra psi assigns no additional load capacity. The language in load tables indicates that extra pressure for LTs at high speed is recommended, as well, and at lower speed thresholds than P-metric. The capability of a tire in both load and speed necessarily overlap each other.
Tire size makes a difference. More air equals more load capacity, whether it's a bigger tire or more pressure in a given tire. The grey curve extends the full distance, so it would be Load E
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
Last edited by JB.; 10-13-2019 at 06:36 PM. Reason: Experimenting to ultimately fix blurred pics
JB. is offline   Reply With QuoteReply With Quote
Old 03-08-2012, 06:31 AM #2
JB.'s Avatar
JB. JB. is offline
JB. JB. is offline
JB.'s Avatar
Reserve
2005 Limited V8
5th gen SR5 springs
Hanna sliders
Old 03-08-2012, 11:57 AM #3
1engineer's Avatar
1engineer 1engineer is offline
Moderator
Real Name: Greg
1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light 1engineer is a glorious beacon of light
Moderator
1engineer's Avatar
Real Name: Greg
Where did the charts originate? Copy this over to the 5G side please. I'm sure it will help some of those guys. Good stuff.
1engineer is offline   Reply With QuoteReply With Quote
Old 03-08-2012, 03:37 PM #4
JB.'s Avatar
JB. JB. is offline
JB. JB. is offline
JB.'s Avatar
I'm under the impression that would be against forum rules.
Good catch. I'll edit the intro to include the source of the numbers.
2005 Limited V8
5th gen SR5 springs
Hanna sliders
Old 03-08-2012, 03:40 PM #5
Gerdo's Avatar
Gerdo Gerdo is offline
Gerdo will become famous soon enough
Gerdo's Avatar
Good work JB.
2000 4runner Sport, SAS/4wheel Underground 3 link, Diamond axle, 14" Radflo coilovers, double locked, Custom rear 3 link, 12" Fox shocks, full armor Gerdo's Build Thread
Real Fuel Tank Skidplates for sale Lil' Skip's OffRoad
Rear control arm mount skids and Hi-Lift adapter for sale Lotus Development
Gerdo is offline   Reply With QuoteReply With Quote
Old 03-08-2012, 03:40 PM #6
philsey's Avatar
philsey philsey is offline
Real Name: Um, Phil?
philsey has a spectacular aura about philsey has a spectacular aura about
philsey's Avatar
Whohooo 1E - charts, graphs, statistics, fax & figgers.
2010 Blizzard Pearl SR5/P - traded
2018 Superwhite SR5/P ... IS350 retrofit.
philsey is offline   Reply With QuoteReply With Quote
Old 03-08-2012, 04:54 PM #7
scanny's Avatar
scanny scanny is offline
scanny will become famous soon enough
scanny's Avatar
good charts. The only thing is not clear to me is a maximum pressure when tires still keep enough traction to make a stable ride and especially stable turns let say on rain. Becasue as I see it if I pump tires up at let say 50 psi I might like bumpy ride and it's going to be safe from load capacity point of view but I'm sure that I'll reduce traction at least by half. And I'm going to regret it if I have to make sharp turn on wet pavement. Or hit an icy path on the road.
But I guess that nobody knows it for sure.
2022 4Runner TRD Off Road, Lunar Rock
Goodyear Wrangler Duratracs
scanny is offline   Reply With QuoteReply With Quote
Old 03-08-2012, 05:08 PM #8
Bahnstoermer's Avatar
Bahnstoermer Bahnstoermer is offline
Bahnstoermer is an unknown quantity at this point
Someone's on a tire research mission! This is good info, a gap in my auto knowledge apparently! Nice to fill it in some, I can make sure I'm at 22 PSI or greater when towing my boat now after some quick mental math... :P
Should be 5000lb 4 Runner / 4 tires = 1250 / tire, adding 200 per rear tire for a 400 lb tongue weight (obviously conservative by ignoring fronts) = about 1450 lbs / tire --> ~22 PSI?
Anyway, cool to see some numbers, take away seems to be there's plenty of room for error before things get bad... unless you have a Firestone Exploder and love to run 12 PSI ahahaha...
Bahnstoermer is offline   Reply With QuoteReply With Quote
Old 07-28-2012, 04:04 AM #9
JB.'s Avatar
JB. JB. is offline
JB. JB. is offline
JB.'s Avatar
Was playing around with a small compressor in the garage a few weeks ago. One thing led to another and I ended up measuring tire deflection on the passenger front in 5lb increments from 80psi down to 5psi. The result is the graph below. One thing I wanted to know is what the curve looked like below 35psi where the load tables end for LT tires. I originally drew the lines in the charts, above, straight down to 20psi to make the relationships more obvious at a glance. They are a little too straight as it is, but continuing them straight past the end of the load tables needed to be fixed, and now it is.
It's interesting to me how 35psi is just about the spot where the curve below really starts to bend. I'm assuming it's no coincidence that's where the LT load tables end.
2005 Limited V8
5th gen SR5 springs
Hanna sliders
Old 07-29-2013, 03:47 PM #10
the great him's Avatar
the great him the great him is offline
Real Name: Isaac
the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all the great him is a name known to all
Real Name: Isaac
idk where you got those graphs but they are way off... E rate tires typically hold 3600+lbs, at 80-85psi your graphs are showing tires maxing out at around 3000-3100lbs @80psi... thus throwing off your entire graph. having worked a both independent tuner shops and dealers, and been apart of several race teams and having also worked for a tire shop, i have been around tires of all makes types and styles, E rated tires can support the equivilant load of a P tire with lesser amount of psi. its in the construction of the LT type tire, now the same is true for D and C rated tires, although the gap is much less the lower the rating you go. also not all tires are created equal, one tire manufacture might say their D rated tire is able to hold 3450lbs while another manufacture will say 3500lbs... same is also true with the P tires as well, -and its not can also change within the same tire manufacture one style or design of tire might hold more or less than another(all in the same aspect ratio size)
just some food for thought. i dont know where you got the info, but its more than a little misleading...
if a*sholes could fly this place would be an airport -2004 GX470 spm -97 SR5 3.4, SCS Stealth 6's w/305 70 17s MTRs, Icon 2.5" RR w/700#coils, OME861s w/Icon tacoma 2.0 RR, ARBs w/nitro 4.88, PIAA LED lights, 170amp CS144, ARB snorkel, ARB bumper w/xd9000ce, CBI swingout loaded, BudBuilt skids, lil skip tank skid, sliders, LCE 231s(d&s), first gen roll bar mod, LED interior/dash lighting, B&M 70624+perma cool w/electric fan, dual electric fanshttp://www.toyota-4runner.org/3rd-ge...ld-thread.html
http://www.metaltech4x4.com/
the great him is offline   Reply With QuoteReply With Quote
Old 07-29-2013, 04:04 PM #11
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
Color me confused too. I check my street air pressure by looking to see if the tire bulges where it touches the ground, and if it does, I add air. My E rated KM2s require about 10 PSI less than the P-rated BigO Bigfoot ATs they replaced, so I don't get it.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 07-29-2013, 04:08 PM #12
eddiebx's Avatar
eddiebx eddiebx is offline
eddiebx will become famous soon enough eddiebx will become famous soon enough
eddiebx's Avatar
Tsk tsk, I don't think you can visually check tire pressure
http://www.tirerack.com/tires/tirete...e.jsp?techid=1
eddiebx is offline   Reply With QuoteReply With Quote
Old 07-29-2013, 04:11 PM #13
eddiebx's Avatar
eddiebx's Avatar
I am not positive, but I think the max load for E rated tires really depends on the size and not the load rating...the chart @JB. seems pretty spot on for the 265/70R17 tire size...
Old 07-29-2013, 04:28 PM #14
gm350reratliff's Avatar
gm350reratliff gm350reratliff is offline
gm350reratliff has a spectacular aura about gm350reratliff has a spectacular aura about
I believe the numbers are correct for the 265/70/17 size. Other sizes in load range E will be rated higher, some less. I know for a fact my 285/70/17 BFG ATs (load range E) that were on my silverado were rated at 3195lbs @80 psi. The same size BFG ATs that were on previously (load range D) were rated at 3195lbs @ 65psi. I have seen some load range E tires with over 4000lbs rated capacity while others less than 3000. His chart seems ok to me.
2014 Super White Trail Premium My build thread: http://www.toyota-4runner.org/5th-ge...ld-thread.html
2008 SR5 4X4 V6 Better late than never build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
gm350reratliff is offline   Reply With QuoteReply With Quote
Old 07-29-2013, 04:48 PM #15
JB.'s Avatar
JB. JB. is offline
JB. JB. is offline
JB.'s Avatar
Your post highlights why I made the thread. This continues to be an area of great confusion.
A careful reading of the first post and the linked load/inflation table should clarify things. The problem is, it kind of flips the things you posted upside down so it may be difficult to believe.
LTs carry less load (size and psi being equal) than Ps because they create more heat and the rubber, due to thickness and composition, is more prone to long term cracking when flexed.
There is also a link above to a Q&A page for a tire engineer.
2005 Limited V8
5th gen SR5 springs
Hanna sliders
light truck , load range , load rating , passenger , ply rating
HTML code is Off
What tire pressure do you run in your stock size tires??? Jeff T 4th Gen T4Rs 2 07-27-2011 08:00 AM
What Tire Pressure do you run on your Stock Tires? New03formeh Polls 4 06-25-2008 09:29 AM
Got new tires and low pressure warning light will not go out arouth 4th Gen T4Rs 29 11-14-2006 06:23 AM
Tires pressure desertrat Classic T4Rs 3 06-12-2006 04:13 PM
New tires and tire pressure system issues Duc Hunter 4th Gen T4Rs 4 05-25-2005 03:11 AM
