Old 12-25-2019, 05:25 AM #91
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about borfoo3 has a spectacular aura about
borfoo3's Avatar
I've been running my LT KO2s for a while at 35 psi, and always felt like it was under-inflated.
So after inflating my tires yesterday I went through a quick calculation to see what number makes sense.
The goal is to see, given the same load per tire, at what LT tire pressure we get the same as stock P-rated tire pressure? Here's how it went:
Stock 4runner suggested tire pressure is 32psi
Bridgestone A/T Revo (P 265/70 r17)
load @ max pressure = 2535lbs @ 44psi
My tires: BFG KO2 (LT 275/70/r17)
load @ max pressure = 3195lbs @ 80psi
going by per tire load @32psi = (32/44)* 2535 = ~1844 lbs per tire (meaning at 32 psi the stock tires can each carry this load)
to get the same above per tire load on the LT: (1844/3195)*80 = ~46 psi
The above assumes a linear relationship between tire pressure and tire load capacity, which may not be 100% true.
However, this tells us that the LT tire needs ~46psi to provide the same load rating per tire as the P-rated stock tire. Again, not 100% accurate, but to me seems like a good start point.
Ride will suffer (LT tires are stiffer) but may helps some mpgs. Plus they finally 'look' right!
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 05:57 PM #92
carlodonz's Avatar
carlodonz carlodonz is offline
Real Name: Carlo
carlodonz will become famous soon enough
carlodonz's Avatar
Real Name: Carlo
Nice reasoning, makes sense to me.
I got the 265 in C rating and after a few tests I ended up deciding running it at 38-40psi, which sits in between the stock 32psi and your range E 46psi, so I guess it was a good guess lol
2014 4Runner Trail Super White
carlodonz is offline   Reply With QuoteReply With Quote
Old 04-12-2020, 01:28 PM #93
Drift Monkey's Avatar
Drift Monkey Drift Monkey is offline
Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice Drift Monkey is just really nice
I recently moved to LT295/70R17 Patagonia MT (E) and was doing a little research on what the appropriate tire pressures should be. Discount Tire filled them to the door jam specs (bad) so I've been giving 40 psi a go driving around today but I decided to dig a bit deeper.
Using the calculations here and cross referencing the data from the Toyota load inflation tables I was able to calculate the stock P-Metric load value for the 4th gen (265/65R17 - load index 110) is 2260 lbs @ 32 psi.
Correcting for the P-Metric to LT-Metric (2250/1.1) we're left with 2055 lbs. The Patagonias are load index 121Q which hold 2215 lbs. @35 psi. This seems to show you could indeed safely run the 35 psi minimum in your LTs on 4th gens (which is the actually the minimum recommended on this size). The stock 5th gen size (265/70R17) is able to carry a bit more weight (2425/1.1 = 2205 lbs) but since 35 psi still satisfies this requirement (2215 lbs), it's the same.
35 psi puts me well within spec of both the factory recommendations and the tire manufacturer's recommendations so I'm moving to that.
Sorry for the hair splitting, but it was kinda fun for me lol.
Edit: Tire Pressure Calculator - this seems to be very accurate and based on industry load inflation tables. Interestingly enough the LT high flotation in sizes we might run can be run as low as 25psi (vs LT Metric tires that start at 35 psi). Something I'm now researching since I'm moving to 35s...
2006 4Runner Sport Edition V8 4WD
Drift Monkey is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 09:43 AM #94
MDobb79 MDobb79 is offline
Real Name: Matt
MDobb79 is on a distinguished road
Real Name: Matt
Long time lurker first time poster. I came across this thread while looking for cheap mods for the 4th gen. I decided I would chime in and give my .02 cents. I use the chalk method when I change model or size of tire. This has been the best way for me to make sure the tires are properly inflated. It's kind of a pain in the butt because you need the tires to be cold and you need a flat level spot to roll forward a couple of revolutions.
I recently discovered a calculator for get the pressure correct and I have tested it out on my Tundra, my GF's 4th Gen 4R, my buddies Tacoma and another buddies FJ Cruiser. We did the chalk method with all of the mentioned rigs and when I put the information in the online calculator I came up with the same PSI as I did with the chalk method. There are other useful tools on this website like gearing and speedo calculations as well as more. Check it out when you have a minute, I have found it very useful.
MDobb79 is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 12:58 PM #95
Smitty19TRD Smitty19TRD is offline
Smitty19TRD will become famous soon enough
This tool was within 1 PSI of what I had hand calculated for my tire change. Very nice.
Sent from my moto g power using Tapatalk
Smitty19TRD is offline   Reply With QuoteReply With Quote
Old 06-30-2020, 02:23 PM #96
Real Name: Matt
Real Name: Matt
As I already mentioned for me the chalk method has always been the most accurate way to ensure proper tire contact. I feel confident in using the calculator from now on instead of the chalk. They also have a wheel offset calculator that is pretty cool and gives a nice visual.
Old 07-29-2020, 10:34 AM #97
DontDrinknDerive DontDrinknDerive is offline
DontDrinknDerive is on a distinguished road
Solid break down! I was wondering what LT meant, thank you.
DontDrinknDerive is offline   Reply With QuoteReply With Quote
Old 07-29-2020, 11:49 AM #98
spartacus's Avatar
spartacus's Avatar
light truck.
Old 12-12-2020, 11:50 AM #99
jimgsmith jimgsmith is offline
Real Name: Jim
jimgsmith is on a distinguished road
Real Name: Jim
I’ve read this thread, and several others on the topic, and it seems to me there may be 2 different conversations happening. Hear me out...
One line of thinking is trying to determine the correct tire pressure based on load capacity. Either by converting from P to LT or working from the load characteristics of the LT and factoring in GVWR. This seems to land around 43-44psi. Higher if you are maxing out on vehicle weight.
The other line of thinking is trying to optimize road contact, either by chalking or heat measurements (or whatever). This seems to come in lower than the previous method, somewhere in the mid to high 30s.
If you’re towing, or otherwise heavily loaded, and need to ensure the tires can handle the weight, the first approach makes perfect sense...the tires need to be able to support the weight. But...for the majority of us (or the majority of the time) when it’s just a stock(ish) 4Runner and 1 or 2 people, doesn’t the 2nd approach make more sense? My runner is a bone stock 2020 with 265 K02s, and with the tires at 38psi, on a cool/cold day with wetish roads, there is a very noticeable lack of traction. The same pressure on a warm/hot day (yes, tires adjusted as temp changes) and the traction seems fine. So I have dropped the pressure to 34 to try that out, and it seems to be much improved.
Does this thinking make sense, or do you think 34 is just too low for an LT on this rig?
jimgsmith is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 12:05 PM #100
scanny's Avatar
scanny scanny is offline
scanny will become famous soon enough
scanny's Avatar
There's is 3rd line of thinking - chose LT tire inflation using Toyota 4runner manual which is says:
"Maximum load of tire
Check that the number given by dividing the maximum load by 1.10 of
the replacement tire is greater than 1/2 of the Gross Axle Weight Ratings
(GAWR) of either the front axle or the rear axle, whichever is greater."
If you use this line of thinking - the minimum tire pressure for C load stock size tire should be not less than 35 psi when you have your truck fully loaded..
2022 4Runner TRD Off Road, Lunar Rock
Goodyear Wrangler Duratracs
scanny is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 02:48 PM #101
Real Name: Jim
Real Name: Jim
So 35 psi fully loaded means what when not fully loaded? Seems like 34 might be ok?
Old 12-12-2020, 10:14 PM #102
scanny's Avatar
scanny's Avatar
I think so - yes, but as far as I remember those load vs. pressure graphs they are not linear, so 32 psi might be probably dangerous. Also it depends on speed and ambient temperature. For example if you driving on trails with walking speed you can go to 20 psi and you will be fine. But on highway your tire likely to overheat and blow up. So if I drive empty truck and have 34 psi on LT C load tires I wouldn't probably be too much concerned, but I prefer to keep tires at 36-38psi since for every 10 degrees of temperature drop, tires will drop 1-2 psi.
And with our weather we can have 10 degrees difference between early morning and noon on some days. That's my theory too, what I know for sure is that for past 9 years I have C load Duratracs I didn't have any issues running them at 36-38psi.
Old 12-13-2020, 11:45 AM #103
Real Name: Jim
Real Name: Jim
Thanks. Whenever I take it to Toyota for service they drop the pressure back to 32 to match what’s on the door. I would have thought they would understand the different type of tire but I guess not.
Old 12-13-2020, 12:13 PM #104
scanny's Avatar
scanny's Avatar
I found that not only Toyota dealership but also Goodyear tire dealers don't have good understanding of LT tires loading tables. I normally just tell them don't change tire pressure but still check it when get home after oil change : )
Old 02-16-2021, 08:35 PM #105
johnnygraphic johnnygraphic is online now
johnnygraphic has a spectacular aura about johnnygraphic has a spectacular aura about johnnygraphic has a spectacular aura about
This has been an education!
My 2020 Off Road Premium has the stock Bridgestone Dueler H/T tires-684II. Size is P265/70/17. When I looked at the TPMS system, they were set at 55 psi! Double-checked and sure enough, 55. I dropped them to 38 psi. We'll see how it drives.
From what I gathered in reading this thread, the "P" in the "P265" is what makes it a P-metric tire? If it was a LT tire, it would be LT265?
Thanks to all for the (overwhelming) information!
johnnygraphic is online now   Reply With QuoteReply With Quote
light truck , load range , load rating , passenger , ply rating
HTML code is Off
What tire pressure do you run in your stock size tires??? Jeff T 4th Gen T4Rs 2 07-27-2011 08:00 AM
What Tire Pressure do you run on your Stock Tires? New03formeh Polls 4 06-25-2008 09:29 AM
Got new tires and low pressure warning light will not go out arouth 4th Gen T4Rs 29 11-14-2006 06:23 AM
Tires pressure desertrat Classic T4Rs 3 06-12-2006 04:13 PM
New tires and tire pressure system issues Duc Hunter 4th Gen T4Rs 4 05-25-2005 03:11 AM
