Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 11-28-2016, 07:19 PM #136
louxwe louxwe is offline
louxwe is on a distinguished road
Bump any 5th gen
Any 5th gen done this mod and know where the right relay is at and how to get to it?
louxwe is offline   Reply With QuoteReply With Quote
Old 12-31-2016, 08:48 PM #137
4x4Homer's Avatar
4x4Homer 4x4Homer is offline
4x4Homer is on a distinguished road
4x4Homer's Avatar
An alternative to this if your need is only for cellphone charging is to replace one of the console blanks with a direct USB connection:
https://www.amazon.com/Mictuning-Toy.../dp/B013W8LQ7C
4x4Homer is offline   Reply With QuoteReply With Quote
Old 01-01-2017, 08:12 AM #138
reidbailey's Avatar
reidbailey reidbailey is offline
Real Name: Reid
reidbailey is on a distinguished road
reidbailey's Avatar
Real Name: Reid
I used a low profile mini fuse tap to isolate the circuit at the fuse box then a SwitchPro to back-feed power when I want it, independent of the acc circuit or in conjunction with it (configured via the SwitchPro). A bit overkill but works perfect and highly configurable.
2011 SR5 - Trail hood - Method NV wheels, 285,70-17 Duratracs - Toytec Boss lift - Shrockworks dimple sliders/trail trim/battery, ACR & Switch mounts/skids - Weathertech mats - LED bulbs - 18% tint - Gobi Stealth, cargo slider, ARB dual twin compressor with 1.5 gal tank, Retrofit head lights (MORIMOTO FX-R Stage III, XB 55, DS2 XB 5500k, XB LED Fogs, DDM LED high beams) Bussman box, Switchpros, Bluesea ACR, Odyssey second battery.
(Have but need to install: Seat heaters)
reidbailey is offline   Reply With QuoteReply With Quote
Old 01-18-2017, 02:54 PM #139
JoshuaDudee's Avatar
JoshuaDudee JoshuaDudee is offline
Real Name: Joshua
JoshuaDudee is on a distinguished road
Real Name: Joshua
I've been wondering about how to do it! My mustang is constantly hot and thats one bummer I had about the 4runner! Nice post!
JoshuaDudee is offline   Reply With QuoteReply With Quote
Old 03-11-2017, 10:24 PM #140
stever1000 stever1000 is offline
stever1000 is on a distinguished road
Cool trick! Now I can camp and charge my electronics without killing my battery
stever1000 is offline   Reply With QuoteReply With Quote
Old 03-11-2017, 10:40 PM #141
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
You can still run your battery into the ground with this mod... but it will just take a little longer when you don't have to key on.
If you hook up one up and rewire all your accessory loads to it... then you have leave it unattended and always come back with enough juice to start the car again.
https://www.bluesea.com/products/763...age_Disconnect
Old 05-28-2017, 09:33 PM #142
Flynnster Flynnster is offline
Flynnster is on a distinguished road
Hey guys, a bit confused on this. I've got a 2007 Limited with just the 12V in the compartment to the left of the shifter ("ashtray" area) and one by the back hatch. Will this mod make my front 12V outlet be constant? Just want to clarify since they OP said it was for only his rear outlet.
Flynnster is offline   Reply With QuoteReply With Quote
Old 06-03-2017, 04:10 PM #143
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
Maybe I wasn't totally clear. I did this mod mainly to keep the rear outlet on but this mod makes both the front and rear 12V outlets constantly on.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 12-28-2017, 05:22 PM #144
2006yamahar6 2006yamahar6 is offline
2006yamahar6 is on a distinguished road
Originally Posted by honda_nos View Post
Took a quick read on this thread. I haven't done the mod myself but I do have 10+ years of 12V experience and a bachelors and masters in EE. Something about the results from the thread doesn't seen right to me.
- First, my assumption is that the OP has bridge the high amp side of the relay. In a standard SPDT relay, this would be terminals 87 and 30. Generally speaking, either 87 or 30 is a fused 12+ constant. Bridging these terminals, you will effectively get 12V constant on the other pin.
- By this assumption, only the loads (accessories) that are on that circuit should light up. I don't understand why things like the compass comes on. Unless they on this circuit, but if this is true then why do some members have the compass on and others do not? (maybe different years or maybe some members just do not have the electronic compass.)
- If the compass is not on the same circuit, then perhaps some members are jumping the wrong terminals (i.e. 87 to 85 or 87 to 86.) But if that's the case then the outlets will not work.
Do you have any suggestions or alternative methods to achieve always on power to the rear dc outlet?
Sent from my Nexus 6P using Tapatalk
2006yamahar6 is offline   Reply With QuoteReply With Quote
Old 09-24-2018, 12:19 PM #145
JimR4 JimR4 is offline
JimR4 is on a distinguished road
Smile 12VDC continuously ON circuit
Originally Posted by Kmvreter View Post
10) Insert jumper from pins #3 to #5 (same location as copper blades on relay.) This bypasses the ignition/accessory circuit.
Could you post where you found the single blades with crimp sockets and wire ga. you used? Thanks for the great description and pictures!
JimR4 is offline   Reply With QuoteReply With Quote
Old 09-25-2018, 01:19 PM #146
Kmvreter's Avatar
Kmvreter's Avatar
Single blades are from any automotive supply store. Up here, I got them at Canadian Tire.
16 ga stranded wire.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 01-03-2019, 11:23 PM #147
ATLiott ATLiott is offline
ATLiott is on a distinguished road
This is helpful. I would really like to be able to have my phone charge while the car isn’t running. I’m going to try this one out.
ATLiott is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 11:21 AM #148
4thGenV8 4thGenV8 is offline
4thGenV8 is on a distinguished road
Thanks you. Great thread, makes it look super easy to get this done.
4thGenV8 is offline   Reply With QuoteReply With Quote
Old 06-09-2019, 06:25 PM #149
crackystride crackystride is offline
crackystride is on a distinguished road
Just did this, great mod! Hopefully no issues arise from it!
crackystride is offline   Reply With QuoteReply With Quote
Old 10-10-2019, 12:32 AM #150
CV4RNR's Avatar
CV4RNR CV4RNR is offline
Real Name: Richard
CV4RNR is on a distinguished road
CV4RNR's Avatar
Real Name: Richard
Great thread- Going to do this tomorrow!
Thanks KMVRETER
CV4RNR is offline   Reply With QuoteReply With Quote
HTML code is Off
Mods for Ipod, Garmin Nav, Valentine1 and move 12v power socket... jcage89 Engines / Suspension / Wheels / Tires / Audio / Accessories 14 02-13-2012 06:59 PM
Constant 12V power at the fuse (For limited 4R with compass) ginkang Engines / Suspension / Wheels / Tires / Audio / Accessories 5 04-24-2011 01:44 PM
12V power outlets LL21 4th Gen T4Rs 5 11-23-2008 03:32 AM
3rd gen constant 12v power oxfordethan Engines / Suspension / Wheels / Tires / Audio / Accessories 3 03-22-2007 11:42 AM
