Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 06-01-2005, 09:42 PM #1
Kmvreter's Avatar
Kmvreter Kmvreter is offline
Kmvreter will become famous soon enough Kmvreter will become famous soon enough
Kmvreter's Avatar
Constant 12V power outlets
One thing that is annoying with the T4R on any road trip is that the 12V power cuts off when you turn the vehicle off to make a pit stop. This has a negative impact on the temperature of the libations (and other assorted items) in the Koolatron or when trying to charge a cell phone. Searched around here and found a lot of frustration with this but couldn't find anyone who tried it yet so here goes...
I was able to turn the existing 12V outlets to be constantly on (like in the old days with cigarette lighters) be removing a relay. Quite simple actually.
Tools required: 10mm nut driver/socket and a wire crimper.
Material req'd: 2 - 1/4" blade male connectors and a short piece of wire.
1) Disconnect the battery (a must.)
2) Remove the driver's side lower dash cover panel (2 bolts.)
Constant 12V power outlets-t4r12vpower1-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
Kmvreter is offline   Reply With QuoteReply With Quote
Old 06-01-2005, 09:44 PM #2
Kmvreter's Avatar
Kmvreter's Avatar
3) Remove black metal brace below steering column (2 bolts.)
4) Remove wiring harnesses from front of fuse junction block.
Constant 12V power outlets-t4r12vpower2-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 06-01-2005, 09:46 PM #3
Kmvreter's Avatar
Kmvreter's Avatar
5) Remove 2 nuts and 1 bolt holding unit to framework.
6) Tilt and adjust forward to expose relays on back of junction block.
Constant 12V power outlets-t4r12vpower3-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 06-01-2005, 09:49 PM #4
Kmvreter's Avatar
Kmvreter's Avatar
7) Remove other wiring harnesses to make room to work (optional.)
8) Remove DC SKT relay (closest to you.)
Constant 12V power outlets-t4r12vpower4-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 06-01-2005, 09:50 PM #5
Kmvreter's Avatar
Kmvreter's Avatar
9) Construct jumper wire.
Constant 12V power outlets-t4r12vpower5-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 06-01-2005, 09:52 PM #6
Kmvreter's Avatar
Kmvreter's Avatar
10) Insert jumper from pins #3 to #5 (same location as copper blades on relay.) This bypasses the ignition/accessory circuit.
Constant 12V power outlets-t4r12vpower6-jpg
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 06-01-2005, 09:55 PM #7
Kmvreter's Avatar
Kmvreter's Avatar
Last but not least put everything back the way you found it. The result is 1 spare relay... Oh yeah, now I have constant power to keep the liquids cool!
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 06-01-2005, 10:03 PM #8
jharris2 jharris2 is offline
Super Moderator
jharris2 is on a distinguished road
Super Moderator
Excellent!
Now I have to decide -- add an extra one up front or do this mod.....decisions, decisions.
2003 SR5 V6 4WD Titanium with cladding
jharris2 is offline   Reply With QuoteReply With Quote
Old 06-01-2005, 10:14 PM #9
sharp4runr's Avatar
sharp4runr sharp4runr is offline
sharp4runr is on a distinguished road
sharp4runr's Avatar
The stuff the members come up with amazes me
sharp4runr is offline   Reply With QuoteReply With Quote
Old 06-01-2005, 10:20 PM #10
Super Moderator
Super Moderator
Even better that they are willing to share so we don't have to figure it out ourselves. So good to learn from people smarter than me!
:arrow:
Old 06-01-2005, 10:34 PM #11
sharp4runr's Avatar
sharp4runr's Avatar
:arrow:
and AMEN to that! I don't have the cajones to try some of the stuff other members do, but this even I can do
Old 06-01-2005, 10:42 PM #12
Kmvreter's Avatar
Kmvreter's Avatar
Do both: add the ashtray and have 3 outlets always on.
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
Old 06-01-2005, 10:53 PM #13
Super Moderator
Super Moderator
Actually, I have the ashtray. What thinking about 3 outlets up front. The new Camrys have them, why not the 4Runner?
Old 06-02-2005, 05:43 PM #14
rivertrek's Avatar
rivertrek rivertrek is offline
rivertrek is on a distinguished road
rivertrek's Avatar
Shouldn't there be an inline fuse installed though for safety!!?? No reason to melt the rest of the wiring harness.
rivertrek is offline   Reply With QuoteReply With Quote
Old 06-02-2005, 07:37 PM #15
Super Moderator
Super Moderator
The front outlets have a capacity of 120W combined. Since the relay is on the back of the fuse box, I believe the fuses in the fuse box will still protect the circuit.
HTML code is Off
Mods for Ipod, Garmin Nav, Valentine1 and move 12v power socket... jcage89 Engines / Suspension / Wheels / Tires / Audio / Accessories 14 02-13-2012 06:59 PM
Constant 12V power at the fuse (For limited 4R with compass) ginkang Engines / Suspension / Wheels / Tires / Audio / Accessories 5 04-24-2011 01:44 PM
12V power outlets LL21 4th Gen T4Rs 5 11-23-2008 03:32 AM
3rd gen constant 12v power oxfordethan Engines / Suspension / Wheels / Tires / Audio / Accessories 3 03-22-2007 11:42 AM
