Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 07-25-2013, 04:27 PM #46
CookieRoe's Avatar
CookieRoe CookieRoe is offline
Real Name: Ed
CookieRoe has a spectacular aura about CookieRoe has a spectacular aura about CookieRoe has a spectacular aura about
CookieRoe's Avatar
Real Name: Ed
Originally Posted by EuroDriver View Post
^ What projectors did you use on your T4R? I kind of have an itch to retro mine, but I really like the reflected light output of the stock halogens, vs the very focused beam of the projectors. Still mulling it over though...
Currently using Acura TLs bixenons. I KEEP getting the polarity mixed up resulting in me FRYING the high/low beam solenoid....... URGHHHHH..... So I only have low beams which is fine by me. My headlights are starting to yellow ever so slightly, so I might do another retro, but with LS460 bixenons. Beam pattern/spread is supposed to be on par with the TLs and are NOT polarity sensitive......... WIN. My wallet is just empty for the time being, hahahhaha
CookieRoe is offline   Reply With QuoteReply With Quote
Old 07-25-2013, 06:40 PM #47
EuroDriver EuroDriver is offline
EuroDriver is an unknown quantity at this point
I had the same problem when I retro'd my maxima - I got the bixenon wiring harness form TRS (not the one with the "smart" chip - I got the one with the dual relays). Al I had to do was swap the 2 parallel spades on the headlight connector and everything worked fine from there.
How much work did you have to put into adapting the projectors? On my Maxima, it was hours & hours worth of modding, which is what's keeping me from contemplating new project...
Nathan
05 4Runner SR5 2X4 V6 (Salsa Red, 35K mi)
01 Nissan Maxima w/bixenon HID retrofit
90 BMW 735I - RIP
99 Volvo S80 T6 - traded in the POS for 4Runner & will never buy Volvo again!)
EuroDriver is offline   Reply With QuoteReply With Quote
Old 07-26-2013, 10:55 AM #48
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Zero, I had a retrofit shop do them (lightmodz). Components are too expensive for me "just to practice" on, hahahaa.
PRICE is what is keeping me from moving on to the next retro project.
Old 01-07-2014, 11:04 PM #49
Bkt4runner's Avatar
Bkt4runner Bkt4runner is offline
Bkt4runner is on a distinguished road
Bkt4runner's Avatar
Hid retrofit on a 2003 4Runner
Has anyone here done a retrofit on a 2003 4Runner using either:
-Lexus LS430 projectors
-Honda S2000 projectors
I'm thinking about one of those two options both of which are single beam projectors. If you guys have any picture please post them. I 've seen one guy on here with a black 99 4runner with a hid retrofit using the bixenon FXR projectors from the Retrofit Source. I want to go with a single beam instead of a bixenon setup.
Big question is which projector will give me the best performance and is the easiest to work with?
-2003 SR5 V8, white with grey trims
Bkt4runner is offline   Reply With QuoteReply With Quote
Old 01-08-2014, 01:38 AM #50
Aelfwine's Avatar
Aelfwine Aelfwine is offline
Aelfwine is on a distinguished road
Aelfwine's Avatar
I know this thread is on HIDs, but it would be awesome to get some info on LED bulbs that replace the stock headlight bulbs. So, LED vs HID???))) I would imagine LEDs are a lot cheaper but are they worth it?
Aelfwine is offline   Reply With QuoteReply With Quote
Old 01-08-2014, 12:23 PM #51
sigepbiker's Avatar
sigepbiker sigepbiker is offline
sigepbiker is on a distinguished road
sigepbiker's Avatar
Acura TL Retrofit
I used Acura TL's on my retrofit. There's a link to pictures, comments, and frustrations in my signature. As for time - A LOT! The fit had to be perfect to the 1/4 inch. Need a lot of patience and free time.
I may get flamed for suggesting this as they aren't OEM but The Retrofit Source developed a TL-R that has an internal solenoid. Those will be a lot easier to fit. Someone else will need to chime in on their performance.
2016 Trail Premium Tires and sliders and some interior mods...
2005 SR5 Silver mod list
FOR SALE: Rear Diff Breather Fitting; 4th Gen Center Diff Switch w/ pigtails
sigepbiker is offline   Reply With QuoteReply With Quote
Old 12-09-2014, 12:19 AM #52
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Customer service top notch. Lightwerkz.
DC area?? Lightwerkz and lightmodz are in the Patterson, NJ area. I've dealt with both of them and I can recommend lightmodz 100%. Lightwerkz did my civic and the some details were not good. They installed the projectors without taking into consideration that the high beams were now pointing upwards (still somewhat useful, but annoying). ......
Lightwerkz saw a thread about my Honda Civic retros that I had mentioned in a recent post here on t4r.org. The owner of the company contacted me and wanted to make things right. He offered to basically RE-DO my retro.............. almost 4 years after the fact!! I was pleasantly surprised. Long story short: I sent in my lights, got them back and were MAJORLY improved!
1) Light restoration of the clear plastic lens. Looks brand new. They were sent in with a lot of oxidation.
2) High beam now in line with low beam. (main issue fixed)
3) Projector/bulb were tweaked for improved performance. Not sure what they did exactly, but my output is VASTLY improved. Something about fiddling with a shield? I'm not a retrofitter, but wow, whatta difference!
4) New high beam bulb. They threw in a more powerful high beam halogen bulb. Nice.
The retrofit was done in the spring of 2011 and the work/craftsmanship stood the test of time. The only "weathered" issues were the lenses.
#Lightwerkz truly came through. Customer Service through the roof!!!! I'm still in shock. Anyway, looking for a retro-fitter? Look no further than Caesar @LightWerkz .
I consider myself a LW customer. If you are looking for a retrofitter, you should too!
Old 12-28-2014, 05:36 PM #53
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Professional retrofit services
..........Lightwerkz and lightmodz are in the Patterson, NJ area. I've dealt with both of them and I can recommend lightmodz 100%........
It appears as though Lightmodz is no longer around. That's fine, Lightwerkz is still going and strong. Other professional retrofitters include:
1) Lightwerkz click here for: HIDPLANET page
2) Black Flame Customs: click here for HID Planet page.
3) HID Illusions: Click here for HID Planet page.
Just keeping this thread alive with up to date info.
Old 12-29-2014, 03:16 AM #54
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho has a spectacular aura about riceandpho has a spectacular aura about
riceandpho's Avatar
need pics of the improved output, pretty sure its a shield mod. maybe they had someone do a curved shield and drop it like 1 mm or lil more to give extra light intensity at the cutoff.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofited S2000 projectors,Osram 66240CBB,Morimoto 5Five Ballast.2 pairs of Hella Supertones.Blue cluster and climate controls.Full led conversion on interior and exterior.HAWK LTS pads f+r, Stoptech slotted rotors and stainless steel lines f+r.Firestone CoilRite 4135.Bilstien 5100 @0.85, MOOG FJ Springs.
riceandpho is offline   Reply With QuoteReply With Quote
Old 01-01-2015, 11:29 AM #55
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Yep.......
I'll take some pics and post here, but I really don't have any "before" picture to compare. However, the "hotspots" are definitely brighter. They just seem to be much brighter. I do remember Caesar (Lightwerkz) saying something about fiddling with the shield. Not sure exact what they do to it.
Old 01-03-2015, 02:45 AM #56
riceandpho's Avatar
riceandpho's Avatar
@CookieRoe
It's just make the whole spread of light brighter than before. I can't believe your lights will be brighter than mines, if only I did the shield mod, it will so bright with the osram svs/cbi with 50watt ballast.
Old 12-02-2015, 04:16 PM #57
danba danba is offline
danba is on a distinguished road
nice
danba is offline   Reply With QuoteReply With Quote
Old 01-30-2016, 12:20 AM #58
CenCalTrail's Avatar
CenCalTrail CenCalTrail is offline
CenCalTrail is on a distinguished road
Any one used xenonsupply? ... they have a plug-n-play kit that seems pretty affordable amd good reviews just wanted to know if anyone had first hand experience.
CenCalTrail is offline   Reply With QuoteReply With Quote
Old 01-30-2016, 12:56 AM #59
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Never heard of them.
Old 01-31-2016, 02:48 PM #60
That doesn't inspire confidence ..... maybe ill have to shop around a bit more
HTML code is Off
Ddm hids TAMPA_4RUNNER 4th Gen T4Rs 27 04-26-2011 09:07 PM
Installed My HIDs Husker Z 4th Gen T4Rs 19 02-06-2011 01:12 AM
HIDs dnbprofessor 3rd gen T4Rs 9 09-24-2010 01:46 PM
HIDs in 4th Gen iFORCE Gallery 22 10-05-2005 10:28 PM
HIDs in a 3rd gen? ilandcruza Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-11-2005 01:04 AM
