Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 12-11-2016, 09:11 AM #76
CookieRoe's Avatar
CookieRoe CookieRoe is online now
Real Name: Ed
CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough CookieRoe is a jewel in the rough
CookieRoe's Avatar
Real Name: Ed
Originally Posted by Flyer View Post
I have asked a couple of places for RX350 retrofit quotes. Now that winter is here, I really need brighter lights. Where are you guys getting the harnesses built?
RX350 projectors are awesome (from what I've seen). A wire harness isnt really built, head to retrofit source and find which one applies to you (H11, H9, etc, bi high vs low beam only, whether you car requires CANBUS or not, etc etc etc), select one and purchse it. All must be accompanied by relays (all harnesses sold by TRS do). Period.
Hope this helps. Good luck on your retros!
EDIT: you will need a 9006 wire harness and HiBeam splitters for your 2005 4Runner.
CookieRoe is online now   Reply With QuoteReply With Quote
Old 02-26-2017, 06:09 PM #77
sa2017 sa2017 is offline
sa2017 is on a distinguished road
great post thanks
sa2017 is offline   Reply With QuoteReply With Quote
Old 07-26-2017, 05:15 PM #78
jkoo1982 jkoo1982 is offline
jkoo1982 is on a distinguished road
Wow thank you for this!
jkoo1982 is offline   Reply With QuoteReply With Quote
Old 08-23-2017, 07:11 PM #79
HanIsa97 HanIsa97 is offline
HanIsa97 is on a distinguished road
Thanks for the info
HanIsa97 is offline   Reply With QuoteReply With Quote
Old 10-08-2017, 04:49 PM #80
SkeyBall SkeyBall is offline
SkeyBall is on a distinguished road
Feedback on HID purchase before Install
Alright, I definitely should have looked over this forum before buying my HIDs. But I feel like I did alright. BUT, just to make sure could you guys make sure I'm in the clear? FIrst time doing HIDs and just wanting to make sure I purchased the correct items.
2006, Limited.
6000k and 55w for high beams and lo beams
6000k and 35w for fogs
Any and all feedback is welcome, just don't want to make a mistake and pay for it later.
Do I need to worry about my 55w getting to hot in stock housings?
Thanks in advance, always apprentice being able to come on here for new knowledge!
SkeyBall is offline   Reply With QuoteReply With Quote
Old 10-25-2017, 11:33 PM #81
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
2006, Limited.
6000K is a little "blue" to be effective (useable light). It has been said to use 4200K, but I do use the 5000K CBI bulb which are practically WHITE. Those are expensive, but well worth it. What specific bulb are you looking at?
I would stay away from HID for hibeams only due to "warm up time". I know ballasts (times) have improved, but unless you use them for a prolong period of time, I don't see the need for a dedicated HID bulb for the Hi's. Myself? I'm looking to get vLeds LEDs. Not the greatest, but should throw plenty of light ahead of me. I live near a lot of back roads and my rig is used to haul my little ones around. Beam pattern on LEDs apparently continue to be an issue (still scattery and not well defined), but these will be TONS better than the "factory spec" bulbs I have.
HIDs in the foglights? Most know that the fogs do basically nothing in terms of illuminating the road ahead of you. Mine are still stock and I have 0 plans on doing anything with them. The beam pattern is worthless even if you put airport landing lights in them. Realize that is my opinion, but do what you want with your rig. Just please just don't throw hi powered bulbs in everything thus resulting in blinding the piss out of on coming traffic.
Good luck!
AS far as the your stock projectors getting warm, I believe you'll be fine. Many run 55w with no issues.
Old 01-19-2018, 01:41 PM #82
Chato Chato is offline
Chato is on a distinguished road
Plan on purchasing an HID "kit" here soon for my 07 runner (has projectors)
Any recommendations on a good quality kit that wont break the bank?
Plan on using 35w with a 5000k bulb
Chato is offline   Reply With QuoteReply With Quote
Old 10-01-2018, 08:58 AM #83
Monisio Monisio is offline
Real Name: Manson
Monisio is on a distinguished road
Real Name: Manson
Hello. Iím new to all this and doing some research about what to get better for my pickup either hid or Leds found out this package which is really what Iím looking to get but not sure how to get it done myself. My only concern is the seal of the lamps because I donít want to get moisture or ay type of issues. Has anyone involved into these custom hid retrofit kit products or anyone have done it themselves? How to get it right and tips will be appreciate it.
https://youtu.be/sDJW8bUyYTY
https://www.hidretrofitkit.com/custo...ed-headlights/
Monisio is offline   Reply With QuoteReply With Quote
Old 10-11-2018, 10:41 AM #84
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
The only retrofitter that I can recommend without hesitation is Lightwerkz. If you want to DIY, head over to hidplanet.com. You WILL find all of the information you need over there.
You won't be sorry.
Old 10-11-2018, 04:15 PM #85
jonb2 jonb2 is offline
jonb2 is on a distinguished road
I can highly recommend www.xenondepot.com . Purchased HID kit from them as well as an LED kit for another vehicle. Though definitely not the cheapest, the products appear to be well made and function great. Also their customer service is top notch.
jonb2 is offline   Reply With QuoteReply With Quote
Old 10-14-2018, 01:57 AM #86
Keanu Keanu is offline
Keanu is on a distinguished road
Thank you for sharing this information! Iíve been wanting to get HIDs for my 4R but wasnít sure if it would be worth it
2018 Toyota 4R Off Road Super White
TRD CAI, Husky Floor Liners, AVS Window Deflectors, Phillips LED Interior, Memphis Audio M-Class
Keanu is offline   Reply With QuoteReply With Quote
Old 10-15-2018, 11:38 AM #87
CookieRoe's Avatar
Real Name: Ed
CookieRoe's Avatar
Real Name: Ed
Totally worth it if done right! Good luck!
Old 12-03-2018, 06:11 PM #88
Hoff1965 Hoff1965 is offline
Hoff1965 is on a distinguished road
Anyone have an idea about LEDís what make and site to purchase? Want to swap out on my 2019 TRD PRO. Lowís and High beams.
Thanks
Hoff1965 is offline   Reply With QuoteReply With Quote
Old 08-05-2019, 08:59 PM #89
Gilla81 Gilla81 is offline
Gilla81 is on a distinguished road
Great info. Thanks for being so thorough.
Gilla81 is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 11:37 AM #90
thenameiszac thenameiszac is offline
Real Name: Zachariah
thenameiszac is on a distinguished road
Great info. Informative breakdown and explanations!
thenameiszac is offline   Reply With QuoteReply With Quote
HTML code is Off
Ddm hids TAMPA_4RUNNER 4th Gen T4Rs 27 04-26-2011 09:07 PM
Installed My HIDs Husker Z 4th Gen T4Rs 19 02-06-2011 01:12 AM
HIDs dnbprofessor 3rd gen T4Rs 9 09-24-2010 01:46 PM
HIDs in 4th Gen iFORCE Gallery 22 10-05-2005 10:28 PM
HIDs in a 3rd gen? ilandcruza Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-11-2005 01:04 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
