EDIT: the kit from pfran includes (2) 48Led panels for the dome light. These work with both SR5 dome lights. However since the limited has 2 bulbs for the middle row dome, the single panel is not the best option. Kit will be available for the 4th gen limited soon.
I wanted more light inside my 03 SR5 4runner and liked the LED swaps I had seen in other vehicles. I also liked the benefits of LEDs. They are longer lasting, brighter, and consume much less electricity a normal halogen bulb does. I bought a few eBay bulbs but there were hit or miss. Most of them burnt out and the colors didn't match perfectly so I put the project on the back burner. I found an 80 series land cruiser kit from PFRAN LEDs and bought a set for my fathers truck. After installing the kit and seeing how well all the lights worked I contacted PFRAN and bought a set for my rig. The install is easy and can be done with very little prior experience and a flat blade screwdriver. Latex gloves are a good precaution as well.
Link:
http://www.pfranleds.com/4runner-fou...eration-02-09/
1) First and easiest are the doors.
I found that the easiest way to remove the door lights was to gently pop off the arm rest cover. it has two clips and comes off fairly easy.
Once the rest cover is off the light housing is visible through the holes. Use the flat blade screwdriver to push the square tab and drop one side of the housing down out of the door panel. Gently pull the housing out of the door panel
When you have the housing out you can clearly see the tabs that are holding the lens on.
I found that you can pull the lens off using just your hands but if you can't, push your screwdriver between the housing and the lens at the tab. This will allow you to pull the lens off and access the bulb. Halogen and led bulbs can both get hot. Let the bulb cool for a good amount of time (5minutes to be sure) and pull the bulb straight out. Similarly, push the led bulb back in. LEDs are polarity-sensitive so if the bulb doesn't illuminate, turn it 180 degrees and reinsert it. Put everything back together the same way it came apart.
( this is the part where you stand back and think to your self "wow!.... I'm so cool. I just swapped my door light for and led, it looks awesome, and provides more light!" )
When you finish admiring your work, repeat the steps for the rest of the doors.
2) The dome lights are just as easy. Find the spots for your screwdriver and pry one side of the cover lens off.
Allow time for your halogen bulb to cool and drop it out of it's housing by spreading the metal contacts. Install the spring adapter and attach the led board. Test it before removing the adhesive. Turn the led panel side connector 180 degrees and reconnect.
Remove the adhesive backing cover and attach the dome. Be sure to get it right the first time or the adhesive will not work as well. Replace the lens and admire. (nice dome!)
3) EDIT: The map light lenses can be removed from the overhead console by using a small flat blade screwdriver wrapped in tape. The picture below shows how the lenses are attached (drivers side shown) Insert your screwdriver into the gap between the console and the outside edge of the lens and gently pop it off.
Let the halogen bulb cool and pull to remove. Insert the led bulb.
Repeat for the other lens and put everything back together.
nice interior lights!
If anyone finds a better way to do any of these steps. Definitely post how you did it.
EDIT: Thanks everyone for the input on the steps.
