Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 01-16-2004, 12:37 PM #16
uwf uwf is offline
uwf is an unknown quantity at this point
uwf uwf is offline
Hello,
This is actually my first post on this site. I have been watching since I bought my rig last August. I have not had anything to say until now. But, I wanted to give credit were it was due. I did this taillight mod. Looks great. If someone rear ends me now, they are blind!! Thanks again.
Joseph
uwf is offline   Reply With QuoteReply With Quote
Old 01-16-2004, 04:23 PM #17
toybox's Avatar
toybox toybox is offline
toybox is on a distinguished road
toybox's Avatar
Hey woodbert, is there anyway to get the factory part to make them the fogs like they are elsewhere. I don't really want another brake or marker light but I would like to turn them intp rear fogs.
toybox is offline   Reply With QuoteReply With Quote
Old 01-16-2004, 06:00 PM #18
uwf uwf is offline
uwf uwf is offline
THat is definitely able to do. If I had the manual, I would tell you what line you need to tap into. But that is definitely able to do. Hey, in case that anyone else has not tried it, I used those nifty little line tap connectors. It was quick and easy, I did not have to cut and strip anything. I can take some pics if anyone wants to see them.
Later,
Joseph
Old 01-16-2004, 09:41 PM #19
Biff's Avatar
Biff Biff is offline
Biff is on a distinguished road
Biff's Avatar
Later,
Joseph
How did you do it? I had to cut and strip all the lines.
Victor
08 FJ TT
94 FZJ80
Biff is offline   Reply With QuoteReply With Quote
Old 01-16-2004, 09:52 PM #20
uwf uwf is offline
uwf uwf is offline
I am going to see if I can find a pick of the connectors that I used. Otherwise, I will take a pic and post on here. I think that if someone is planning on doing this mod, these connectors will speed everything up.
Later,
joseph
Old 01-17-2004, 09:08 PM #21
gaslight's Avatar
gaslight gaslight is offline
gaslight is on a distinguished road
gaslight's Avatar
the connecters just clip onto the existing wires and basically act as a spice. nice and neat. no wire cutting.
04 Sport V8 Stratospere Mica
Volant Airbox, Gibson Exhaust.
93 Mustang GT 5.0L --TURBO
RWHP=470 RWTQ=512
2008 Harley VROD VRSCD
gaslight is offline   Reply With QuoteReply With Quote
Old 01-18-2004, 03:27 AM #22
sparky03 sparky03 is offline
sparky03 is an unknown quantity at this point
Borla Dual Exhaust
I couldn't help but notice the Borla Exhaust. I want to change from the stock muffler that exists straight out the back. When the windows are down, exhaust gas is sucked into the passenger compartment. The rotten egg smell the dealer says is caused by the gasoline may be just that. There is a law taking effect this spring that will make the gasoline compnies reduce the amount of sulphur.
Anyway, I have been wanting to change the muffler. The Borla site does not show a replacement. Also,, I had the 4Runner on a lift and could not figure out any way to route the tialpipe to the drivers side.
How did you do it?
How does it sound?
sparky03 is offline   Reply With QuoteReply With Quote
Old 01-18-2004, 10:01 AM #23
Biff's Avatar
Biff's Avatar
Sounds great, and I had installatation done at a store. I would highly recommend it.
Victor
08 FJ TT
94 FZJ80
Old 05-16-2004, 12:49 AM #24
yabedude's Avatar
yabedude yabedude is offline
yabedude is on a distinguished road
yabedude's Avatar
This is the coolest mod! The wiring and additional grounding wire were perfectly spec'd.
I chose to use a Dremel and hack the whole round end off so that I could mount the sockets properly. I also smeared Goop over all the holes that were left after mounting the sockets.
Goop works well. It dries fast and leaves a rubber solution that can be removed easily to change the bulbs. I have first hand knowledge of that as I forgot to install one of the bulbs!
Anyway, I took my time and did it right. All the wires for wrapped in that black spirly casing that is available everywhere. It's very clean and very cool! Here's some pics ...
Tip: Before installing, make sure you test the bulbs to identify the brake wire. It will be the brightest. As suggested earlier, ground wire to chassis and touch red battery post with one of the other wires. Good luck!
Putting the red bumper lenses to use-rearlight_before_after1-jpg
yabedude is offline   Reply With QuoteReply With Quote
Old 05-16-2004, 12:50 AM #25
yabedude's Avatar
yabedude's Avatar
Pic 2 ...
Putting the red bumper lenses to use-rearlight_before_after2-jpg
Old 05-16-2004, 12:52 AM #26
yabedude's Avatar
yabedude's Avatar
Last pic 3 showing the Goop ... The earlier pick of the lights in action on the other 4Runner is exactly the same as mine.
Putting the red bumper lenses to use-rearlightgoop-jpg
Old 05-17-2004, 10:39 AM #27
bryancos's Avatar
bryancos bryancos is offline
bryancos is on a distinguished road
bryancos's Avatar
Thanks for posting photos to show the mod process! As they say, a picture is worth a thousand words... (or, in my case, 1,463 of them to be exact!)
Black 2003 SR5 V6 4WD (Option Pkg C) ClearBra, painted pinstripes Mods: Rear glass limo tinted/ fronts 27%, Sunroof Deflector, Auto Dimming Mirror, VVT-i emblem, Homelink, Valor Tip -- Aftermarket: Weathertech Deflector, AVS Ventvisors & Tailshade tail light blackouts, Silver Star bulbs, 7.2" Widescreen TV/DVD, PNI Wayfinder Compass, K&N Air Filter (Part #33-2281), Husky Cargo Liner, Wood Trim Kit, Third Brake Light Flasher, Amber Whelen Slimlighter (aux. rear hazard warning) Rear foglamp housings modifed for aux. tail/brake/signals/hazard (See Rear Fog Mod Thread here : http://www.toyota-4runner.org/showth...threadid=1137)
bryancos is offline   Reply With QuoteReply With Quote
Old 06-13-2004, 09:27 PM #28
lojeff's Avatar
lojeff lojeff is offline
lojeff is an unknown quantity at this point
lojeff's Avatar
Any part number for the tail light socket on this mod or links to website?
2004 Black V8 4WD Sport Edition
Camry Navigation
Homelink
All Weather Mats
Bug Deflector
Yakima Ski Rack
Driver Side Handle
Footwell lighting
CO2 PowerTank
Red Bumper Lens Mod
Weathertech cargo mat
lojeff is offline   Reply With QuoteReply With Quote
Old 06-14-2004, 02:34 AM #29
yabedude's Avatar
yabedude's Avatar
No part number for the socket, but your local auto parts shop should be able to find the match for the bulbs. I can find the part number I used next time I'm in the store, but it will be a Canadian Tire part and probably not the same as what you'll have available.
Chris
Old 06-16-2004, 08:27 PM #30
WV4Runner WV4Runner is offline
WV4Runner is an unknown quantity at this point
For us less mechanically(electrically?) inclined, wouldn't it be nice if we could get a "kit" of everything we need (including the LED bulbs and whatever part holds the socket on the Japanese model)? I still might try to hunt down the parts and try this mod.
2004 V8 4Runner SE
Titanium, V8 AWD
35% tint, sport bumper trim,
weatherflectors, JDM tail's,
"Canadian" hood deflector, and
Valor tip.
WV4Runner is offline   Reply With QuoteReply With Quote
HTML code is Off
wrong year ARB bumper hoggy 4th Gen T4Rs 1 04-03-2009 02:08 AM
How to replace rear bumper red reflector? testrider 4th Gen T4Rs 11 01-10-2008 09:40 AM
Red Bumper Lenses Into Back-up Lights??? JGRIMBALL 4th Gen T4Rs 7 12-24-2003 02:33 PM
Adding rear lights in the bumper lenses.. BlkSS1755 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-05-2003 12:47 AM
aftermarket brake kit l8brkr Engines / Suspension / Wheels / Tires / Audio / Accessories 7 10-13-2003 06:17 PM
