Old 07-09-2012, 04:11 PM #16
timon's Avatar
timon timon is offline
timon is on a distinguished road
timon's Avatar
Mr ahhweewee, Thank you so much sir for your super nice write up. I was able to install my back up camera following your instructions and your pictures. Again Thanks for sharing!
timon is offline   Reply With QuoteReply With Quote
Old 07-21-2012, 05:26 PM #17
Pope Pope is offline
Pope is on a distinguished road
OK first time poster, long time lurker. Can someone please tell me where you tapped in the cable that powers the camera.(colors of wires,location etc.). I got the LED to come on when lights come on, but the power cables are not long enough to get into the cab. I mounted the camera on the right side, when looking at the back of the runner. So I assume you tapped something in tailgate. I was disappointed the camera didn't come with any instructions.
Pope is offline   Reply With QuoteReply With Quote
Old 08-12-2012, 01:19 PM #18
JBottoms JBottoms is offline
JBottoms is on a distinguished road
Hey guys, I've got the same kind of camera and ran ino a little hiccup trying to put mine in yesterday. If anyone could help me figure out which wires to connect to power the light, and an easy way to get the wires of the camera connected to the reverse taillights, I'd greatly appreciate it!
As for the light on the camera... does it connect it to the original wires that powered the light taken out? (one was green and the other white w/black stripe) If so, what is the combination that should be used? (i.e. red to green and black to white/black or vice versa?)
Jeff
'04 SR5 Metallic Silver 4Runner
Complete Int LED swap - Pioneer AVIC-Z130BT Navi HU w/ Backup Cam - 7000K Xenon HID headlights - Vision Warrior Black Machined Wheels - BFG Rugged Terrain - Stainless Bull Bar - Flowmaster 50 Series
JBottoms is offline   Reply With QuoteReply With Quote
Old 08-26-2012, 11:49 PM #19
tjk925 tjk925 is offline
tjk925 is on a distinguished road
Green is positive (+) and white/black is negative (-), but you can always test with a meter/DMM. So, Red to Green and Black to White/Black. I assume you got it worked out by now anyway
I bought this camera: 2003-2010 Toyota 4Runner CCD NTSC Car Rear View Backup Reverse Waterproof Camera | eBay and completed the install today, with a Pioneer AVH-P4400BH in a 2004 4Runner SR5 4x4
tjk925 is offline   Reply With QuoteReply With Quote
Old 08-27-2012, 12:24 AM #20
Since they are short, I extended the power wires for the camera, fed them through the rubber channel described in the OP's install (not an easy task, I pulled the video and power wires, which were taped together, through with another wire). Then you can run them across and down the side channel on the left rear, or right I would think, to a round hole at the bottom in front of the reverse light. You can either use those pass-through connectors or connect the wires to the posts? that you see on the left and right of the light assembly. I have highlighted them in ahhweewee's original image.
I have a bunch of small screws around from building my desktop computers, so I just connected and crimped the wires into those circle connectors (electrical ring connectors?) and screwed them down, leaving slack on the wires so I can easily disconnect/replace any of the lights without unscrewing them.
The negative terminal is the one that has the black wire already going through the three of them (turn signal, brake and reverse lights).
More info:
I started with this connector for the HU: Scosche SMTA02PIO1603B 1987-Up Toyota Direct Connection Harness, but had to pop out some of the connectors on the connector that came with the unit (Pioneer AVH-P4400BH), because the direct connect harness did not include the reverse video wire (I assume the signal that comes from the reverse light), as well as some other wires. I then got them popped in to the Scosche connector (on the Pioneer hook-up side).
Old 02-08-2014, 05:18 PM #21
mcneezy mcneezy is offline
mcneezy is on a distinguished road
great upgrade, in the OP, what is the model of the camera used? I know you purchased it off eBay, was hoping to do the same project to my 4Runner
mcneezy is offline   Reply With QuoteReply With Quote
Old 02-11-2014, 12:26 PM #22
Brutalguyracing Brutalguyracing is offline
Real Name: 03 v8 Limited
Brutalguyracing is on a distinguished road
You guys who hooked up the camera
Can i cut the rca plug off the end and re splice down the line for the video feed?
Brutalguyracing is offline   Reply With QuoteReply With Quote
Old 02-24-2014, 01:35 PM #23
ahhweewee ahhweewee is offline
ahhweewee is an unknown quantity at this point
The one I odered was called SONY CCD CAR REAR VIEW REVERSE CAMERA TOYOTA 4Runner. If you can't find that one, any other cam will work but this one installed without drilling.
2005 Blk SR5 4x4 V6
ahhweewee is offline   Reply With QuoteReply With Quote
Old 02-24-2014, 01:38 PM #24
I did just that when I installed on for a friend. I eventually had to redo it because I'm thinking oxidation started to cause problems. I re-soldered, siliconed and heatsrinked it. Didn't have an issue after that. I would just suggest making it a good clean connection and making it stay clean and moisture free.
2005 Blk SR5 4x4 V6
Old 02-24-2014, 01:44 PM #25
Originally Posted by earthrealm View Post
os it water proof?..most users on amazon are complaining about moisture entering the camera..........
When I ordered I odered two incase I screwed one up. The first developed a cloudy lens. May be because I was rough with it during the install. I installed the second one a year later and it lasted through all of Virginia's 4 crazy seasons. We've been over a 100 a few times in summer and as low as 10 in the winter. Snow, Ice, Rain, Fog, its holding up. I emailed the eBay seller about the problem. He send another for free one in a week even after a year. So far no problems.
2005 Blk SR5 4x4 V6
Old 02-24-2014, 07:48 PM #26
sweet
thanks..
hope to get it all wrapped up this weekend....
Old 10-04-2015, 11:50 PM #27
loconzly's Avatar
loconzly loconzly is offline
loconzly is on a distinguished road
loconzly's Avatar
Just a note to say this is a very helpful write-up, even after three years. We did the same install tonight and man that rubber tunnel is a pain in the butt! We kept losing the wires from the fish tape since it was so tight. I eventually coated them with dish detergent and they went through. Messy, but effective.
loconzly is offline   Reply With QuoteReply With Quote
Old 10-06-2015, 06:55 PM #28
fullboogie fullboogie is offline
Real Name: David
fullboogie is on a distinguished road
Real Name: David
I'm doing a complete audio install soon, have everything picked out. Decided to do a rear camera as well and just found this thread - if the OP is still around, thanks a ton for the write up!
fullboogie is offline   Reply With QuoteReply With Quote
Old 10-12-2015, 09:01 AM #29
Vols77 Vols77 is offline
Vols77 is on a distinguished road
That turned out great
Vols77 is offline   Reply With QuoteReply With Quote
Old 11-28-2015, 07:29 PM #30
runnyeggsham runnyeggsham is offline
runnyeggsham is on a distinguished road
I think the camera is all set for me but where do you guys power up the display LCD with? I thought about splicing the camera and display to the wire feeding the brake light but then I thought about someday adding a front camera as well. If I just hook it up to the rear lights, it wont come on unless I am in reverse.
runnyeggsham is offline   Reply With QuoteReply With Quote
HTML code is Off
Backup Camera Install MNT4R 4th Gen T4Rs 15 02-23-2020 06:06 PM
Where to install a backup camera in a 2004 T4R? 4runner19 4th Gen T4Rs 3 01-05-2010 11:56 AM
Backup Camera Final Install (Pics) subzero 4th Gen T4Rs 4 12-10-2006 01:00 AM
Backup Camera subzero Engines / Suspension / Wheels / Tires / Audio / Accessories 14 12-09-2006 04:24 PM
Backup Camera ForRuner99 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 05-02-2006 10:29 AM
