Old 01-15-2016, 06:45 PM #31
hendy.27 hendy.27 is offline
hendy.27 is on a distinguished road
Needing some serious help..
The planets aligned today and both of my kids were napping at the same time so I figured I'd be able to get it done in 2-3 hours. I got the wires ran and my camera installed but (thankfully) I decided to test the rear window before I buttoned everything up. Whenever I roll down the rear window, it snags on the cord and would snap it. I reran the wire 3 times and fixed my connections 3 times before giving up. So now I have a camera installed, and the wires ran into the inside of the 4runner, but their not connected because the window keeps cutting them. What am I doing wrong?!
hendy.27 is offline   Reply With QuoteReply With Quote
Old 01-16-2016, 10:09 AM #32
Anyone have any ideas? I've never read that anyone had had this issue before.
Old 01-19-2016, 01:47 PM #33
paraordnance's Avatar
paraordnance paraordnance is offline
paraordnance is on a distinguished road
May sound obvious but, did you try running longer wire? Also, whats more important is that you run your wire while window is down, this way you know exactly where obstructions are on the path and route accordingly.
2004 4Runner Limited V8 4WD
Toytec Ultimate 3" (X-REAS & RAS - delete). LS460 + STi retrofit, Switchback Halos, LEDs in/out, Fog light mod.
CBI front bumper. 285/70/17 Duratracs.
JVC KW-V50BT with Hertz HCP4D & Hertz HCP1D, Hertz ESK-165 components and JL 10TW3 in custom stealth enclosure. Backup camera and steering wheel controls.
paraordnance is offline   Reply With QuoteReply With Quote
Old 05-30-2016, 04:02 AM #34
heiser heiser is offline
heiser is on a distinguished road
For such an old post it's still helpful. I used it for most of my recent install. Thank!
heiser is offline   Reply With QuoteReply With Quote
Old 08-10-2016, 12:15 PM #35
hawk-i hawk-i is offline
hawk-i is on a distinguished road
Dash switch
Just an idea, but for the reverse sensor wire, could you just hook that up to a switch on the dash with a little current feeding through so that it's entirely manually operated, but you can turn it on anytime?
I only need my camera about 10% of the time when parallel parking into those spots that are usually a touch too small so the non-auto-reverse-on wouldn't Inconvienence me.
Anyone have an idea what kind of power that wire needs for it to realize its backing up?
hawk-i is offline   Reply With QuoteReply With Quote
Old 02-26-2017, 07:52 AM #36
Kaner747's Avatar
Kaner747 Kaner747 is offline
Kaner747 is on a distinguished road
Kaner747's Avatar
Thanks. Was a big help
Kaner747 is offline   Reply With QuoteReply With Quote
Old 03-31-2017, 11:35 AM #37
jediwebdude's Avatar
jediwebdude jediwebdude is offline
jediwebdude is on a distinguished road
Where did all the photos in the tutorial go?
TCT Magazine
2019 TRD Pro Tacoma - Voodoo Blue
2018 Shelby GT350
jediwebdude is offline   Reply With QuoteReply With Quote
Old 04-24-2017, 09:42 AM #38
mstreck mstreck is offline
mstreck is on a distinguished road
Yes, can you please make them available again? Thank you!
mstreck is offline   Reply With QuoteReply With Quote
Old 01-27-2018, 10:18 PM #39
ohjj13 ohjj13 is offline
ohjj13 is on a distinguished road
I'd also find the photos helpful if you could repost them
ohjj13 is offline   Reply With QuoteReply With Quote
Old 06-27-2019, 09:26 AM #40
RickF RickF is offline
RickF is on a distinguished road
Getting ready to do this - backup camera comes with the Boss 755 radio I am getting ready to install. Like everyone else I'm hoping to see some pictures if possible, and see if anyone has an answer to the gentleman who has the wire snapping problem when rolling the rear window down.
Anyone have any experience installing the Boss 755 radio and backup camera?
Thanks in advance!
RickF is offline   Reply With QuoteReply With Quote
Old 07-01-2019, 05:21 PM #41
dschan dschan is offline
dschan is on a distinguished road
Backup camera - rear window cutting wires
Finished my backup camera install this past weekend. Zip tie your camera wires to the existing wire harness. Do not have any slack dangling in the hatch cavity. If the camera wires are snug against the existing harness, they won't get caught on the window.
The attached photo shows rubber grommet where the camera wire feeds into cavity from exterior camera. Wire is zip tied to existing harness and runs to driver side of cavity. You can see the red and yellow RCA plugs running to the left (they are loose in the photo since I wasn't done yet, but the final install has the wires very snug against the harness).
My Backup Camera install-img_20190629_173620344-jpg
2006 SR5 V6 4WD
dschan is offline   Reply With QuoteReply With Quote
Old 07-01-2019, 05:31 PM #42
Backup camera install tutorial
Don't know what happened to the photos, but this YouTube video helped me with my install:
YouTube
2006 SR5 V6 4WD
Old 08-08-2019, 11:55 AM #43
_HoeRunner_ _HoeRunner_ is offline
Real Name: Hampton
_HoeRunner_ is on a distinguished road
Real Name: Hampton
Has anybody gotten hyper flash after installing the backup camera? I tapped into the reverse wire at the tail light so I didn’t have to worry about running power all the way to the front. I’ve looked everywhere but I can find out how to fix it for a backup camera. I’m considering putting in a load resistor but I wanted to see if anybody knew that would work before i did that.
_HoeRunner_ is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 07:56 PM #44
toyoman25's Avatar
toyoman25 toyoman25 is offline
toyoman25 is on a distinguished road
toyoman25's Avatar
I am not sure how a camera install would cause this. Where did you set up the power wire ? seen people tapping into the backup light power source. if you go that route there is a tap that does not require any cutting. I know Cructhfield sells them.
https://www.crutchfield.com/p_669PP6...onnectors.html
Toyo is my Name and My Ride
toyoman25 is offline   Reply With QuoteReply With Quote
Old 11-11-2019, 07:35 PM #45
Brutalguyracing Brutalguyracing is offline
Real Name: 03 v8 Limited
Brutalguyracing is on a distinguished road
I used my.power for reverse fro. Trailer wiring harness without aNy issue
Sent from my SM-G950U using Tapatalk
Brutalguyracing is offline   Reply With QuoteReply With Quote
HTML code is Off
Backup Camera Install MNT4R 4th Gen T4Rs 15 02-23-2020 06:06 PM
Where to install a backup camera in a 2004 T4R? 4runner19 4th Gen T4Rs 3 01-05-2010 11:56 AM
Backup Camera Final Install (Pics) subzero 4th Gen T4Rs 4 12-10-2006 01:00 AM
Backup Camera subzero Engines / Suspension / Wheels / Tires / Audio / Accessories 14 12-09-2006 04:24 PM
Backup Camera ForRuner99 Engines / Suspension / Wheels / Tires / Audio / Accessories 9 05-02-2006 10:29 AM
