Old 06-10-2012, 02:14 PM #1
mdterps44 mdterps44 is offline
mdterps44 is on a distinguished road
External amp installed to front speakers, now back speakers don't work
I purchased a new head unit, front speakers, and an amp. I installed the head unit and the new speakers in the front of the car first, and all the speakers were working, then I installed the amp a week later to power only the new front two speakers, and now only the front speakers work, nothing else. I think the problem is the internal amp which powers the back speakers is shutting off, since I am using a new amp but I am unsure how to fix this if that is the problem. Any feedback would be appreciated. thanks
mdterps44 is offline   Reply With QuoteReply With Quote
Old 06-12-2012, 10:49 PM #2
Bucket81's Avatar
Bucket81 Bucket81 is offline
Real Name: chris
Bucket81 is on a distinguished road
Bucket81's Avatar
Real Name: chris
the Head Unit should switch the internal amp on and off when ever you tell it not automatically, check your connections behind the head unit. it will be a separate plug.
Bucket81 is offline   Reply With QuoteReply With Quote
Old 06-13-2012, 05:48 PM #3
FireTruckGuy's Avatar
FireTruckGuy FireTruckGuy is offline
FireTruckGuy is on a distinguished road
Did you by chance splice into the front speaker wires without disconnecting the internal amp of the head unit?
07 Runner SR5 V8: H-9 bulbs, Bilstein Struts and Shocks, Tinted, Remote Start W/Fob To Roll Down Back Window, and LED Dome Lights w/Dome Light Mod
FireTruckGuy is offline   Reply With QuoteReply With Quote
Old 07-08-2012, 08:07 PM #4
A/V1's Avatar
A/V1 A/V1 is offline
Real Name: Brad
A/V1 is on a distinguished road
A/V1's Avatar
Real Name: Brad
Question
Ok. Instead of talking in general here, give us specifics. Do you have the factory speakers installed in back? Are you going from OEM JBL to aftermarket? Etc, etc.
What is the brand / model number of the aftermarket radio you installed?
What is the brand /model number of the amp you are installing?
Speakers?
Did you use a wiring adapter when you connected the deck to the OEM wiring?
There's no real turning off of the internal amp guys. If you don't have anything connected to the high-out (speakers), it doesn't see a load. It's not suggested to have speakers connected AND RCAs as this can cause the ICs to burn out, But in all my years installing it's always been just one or the other (connect speakers OR amp RCAs). No switching of internal amps on & off. Not to say there may be a few out there like that, however, MOST you don't need to do anything other than connect it correctly. Now, I'm not saying I am absolutely right, and you are wrong. I do remember an Alpine I had many years ago that you had to switch the EQ setting from deck to AI-Net if adding an external unit. Anything is possible. Which is why I'm asking for model numbers etc.
Anyway, how are you inputting the front audio signal to the amp? Are you using the high out input or low out (speaker level, or RCA)? If it was high out you would have used the white & white/black and grey & grey/black wires from the deck to the amp. If you used RCAs, you should now cap these wires out of the deck with heat shrink or tape because they won’t be used.
The green & green/black and purple & purple/black wires should be wired directly from your deck to the rear speakers. If there was a JBL amp in the system, bypass it by running your own wires to the rear speakers from the deck.
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
A/V1 is offline   Reply With QuoteReply With Quote
HTML code is Off
Amp front speakers but not back? CartersYota Engines / Suspension / Wheels / Tires / Audio / Accessories 3 04-10-2011 07:55 PM
Drivers side front/rear speakers dont work. Obvious stuff checked denvertoyota 3rd gen T4Rs 6 10-09-2010 12:17 AM
New Front Speakers Installed Lanzo 3rd gen T4Rs 30 06-03-2008 05:00 PM
Installing all new speakers with external amp..run wire through factory harness??? kickinasphalt Engines / Suspension / Wheels / Tires / Audio / Accessories 5 04-23-2007 07:32 AM
For Sale: 1999 4Runner Speakers (front and rear door mount factory speakers) tigertan Classifieds - buy & sell (no commercial ads please) 0 06-15-2005 03:23 PM
